How do I remove the steering wheel off my John Deere 160? Any help appreciated - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-15-2012, 02:26 PM   post #1 of 6
GeorgeL
MTF Junior Poster
MTF Member # 48359
Default How do I remove the steering wheel off my John Deere 160? Any help appreciated
I have a 160 with that crappy wheel which has the rubber splitting, its about to fall off. I have another wheel but Im not sure how to replace. I removed the little hex nut and there is a large phillips head screen on the other side. Seems like aftermarket hack job. I cant budge it even after lubing it up. The plastic cover is off the top of the wheel but it looks like the wheel is welded to the column. Do I have to pull the whole column or am I missing something? Do the wheels just come off these things or do i need to remove the wheel with column?
thanks for any help and if you need pics I can take some with my phone and post them. Thanks
George
GeorgeL is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-15-2012, 02:50 PM   post #2 of 6
KATT
5000 Strong & Climbing
KATT's Avatar
MTF Member # 34056
Default Re: How do I remove the steering wheel off my John Deere 160? Any help appreciated
http://www.mytractorforum.com/showthread.php?t=229231 Page 6 near bottom.
I had the same problem the nut and bolt have to come out of course, then you can try pounding up with a 2X4 .
After a week of PB Blaster and pounding for a couple of minutes after work and spreading it with a BIG screwdriver, and some BAD words it came off. But I suspect you will have to do what he did in that thread.
__________________
" 09 " X520 with 48" Deck, #44 Snow Blower, Weather Enclosure, Wheel Weights, Chains, drift cutter, Brush Guard, #36 Tow Behind Spreader, Single bucket holder, #7 #80 and #50 Trailers,
Previous JD's
"86' 318 #44 Front End Loader, #49 Snow Blower. TY15380 Hard Cab, Wheel weights Chains Weight box ( 6 suitcases ) "99"LX279 Liquid Cooled /48"Deck."87"SX95 / Rear Bagger, 165 Hydro, STX38, LX188. Toy a 175 Hydro #38 snow blower #38 mower deck
and of course
"87" JD 175
- Rusty -
KATT is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 03:52 PM   post #3 of 6
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
I've used a 3-jaw puller, lots of PB Blaster and every curse word I know + a few I've made up and sometimes that will get the steering wheels off
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Old 04-15-2012, 05:24 PM   post #4 of 6
MXZRXP
3K Poster!!!!
MXZRXP's Avatar
MTF Member # 48748
not that it helps, but this is a problem with a whole lot of models and deere should make a better design!
it woudl be easy to do!
It should pop right off with a puller, the fact that even with a puller it needs some persuasion means poor design!
good luck! and wear gloves to protect those knuckels!!
__________________
STX38 (yellow deck)
345 48C Deck, 42" Blower, Curtis Cab
Propane HEAT (sweet!)
Blower in action here:
http://www.youtube.com/watch?v=8dyoup-StaA
MXZRXP is online now   Reply With Quote Quick reply to this message
Old 04-15-2012, 07:00 PM   post #5 of 6
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
Agfter the nut is off an out of the opening get yourself a drift punch and attempt to drive the bolt out and then the wheel should come off.
__________________
GT275
GT235
JRJ is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-15-2012, 08:00 PM   post #6 of 6
Jgj5150
Proud Member of the 1K Club
Jgj5150's Avatar
MTF Member # 41313
I had to cut mine off with a die grinder/ cut off wheel. Took me all day. I put a gob of anti seize on the end before I put the new wheel on.
__________________
JD 455 Diesel
JD 332 Diesel.
JD 330 Diesel
JD 1964 110 RF (my baby, s/n 11300 restored)
JD 1965 110 x2 no engines.
JD 1966 110 RF non running
JD 1967 110 RF non running
JD 1968 110 SF non running
JD 111 non running.
JD 60 x2 non running
JD RX95 bought new by my dad in 1984
JD SX75 not running
JD 68 wore out
JD 1957 720LP
Jgj5150 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
