EZ VAC Restore - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-11-2012, 01:54 PM   post #1 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Default EZ VAC Restore
I started working on my ez vac model 70 restoration. This is the 8HP version, the big one! The engine purrs like a kitten so all I am doing is taking off the periferials, changing fuel lines, filters, oil, clean degrease, prime and paint. Her is what I have so far. Once the engine is complete I'll start on the trailer and sides. This should be a pretty straight forward restoration. I'll update as I move along.
ID:	207956   Click image for larger version
ID:	207957   Click image for larger version
ID:	207958   Click image for larger version
__________________
CLICK HERE
Restored:
853, 1556, 1556 Loader, custom 1856, 1669, 1886, HT23
Restored:
tillers, 3pt, sleeve hitch, E-Z Vac, mowers, single & 2 stage blowers, moldboard, front and rear pto chippers/shredders, wheelbarrow attachment, aerator
ed-nh is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-11-2012, 02:14 PM   post #2 of 48
BOSMECH
Proud Member of the 1K Club
BOSMECH's Avatar
MTF Member # 38136
Default Re: EZ VAC Restore
Sounds like the right time to do it because as you know fall will be here in New England soon enough and so will all the leaves on the grond. : (
BOSMECH is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 07:05 PM   post #3 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Here are a few more pics. From all the paint I could find on the starter and starter guard it was gold so that is what I went with. Looks good even if not the right color.
ID:	207983   Click image for larger version
ID:	207984   Click image for larger version
ID:	207985   Click image for larger version
__________________
CLICK HERE
Restored:
Restored:
Old 04-11-2012, 09:09 PM   post #4 of 48
Deerlope
3K Poster!!!!
Deerlope's Avatar
MTF Member # 20931
It is looking mighty good Ed!!!!!!!!!!!!!
__________________
"1886 Upper Heat Shrouds Available"
Operational 2486,1886: 1455; 900;DGT1700, Kubota RTV900; Kubota M-5040; Kubota excavator KX 057; B-2650 Kubota, JD332 diesel
]Deerlope's Bolens on YouTube[
Till the soil til I am soil.
Deerlope is offline   Reply With Quote Quick reply to this message
Old 04-12-2012, 10:04 AM   post #5 of 48
BOSMECH
BOSMECH's Avatar
MTF Member # 38136
That looks great.
Old 04-12-2012, 01:40 PM   post #6 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
I'm not liking the red tank straps. They may come back off and go with white or black. I'll have more pics soon now that it is all back together. Next will be all the blower tins and mounting supports.
__________________
CLICK HERE
Restored:
Restored:
Old 04-13-2012, 08:54 PM   post #7 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
All done with the blower and engine. Here's a few more pictures. Will start on the trailer and sides next
ID:	208347   Click image for larger version
ID:	208348   Click image for larger version
ID:	208349   Click image for larger version
__________________
CLICK HERE
Restored:
Restored:
Old 04-13-2012, 10:26 PM   post #8 of 48
Deerlope
3K Poster!!!!
Deerlope's Avatar
MTF Member # 20931
Ed, Does the blower and engine mount onto the rear of the tractor or tongue of the trailer?
__________________
Old 04-16-2012, 08:58 PM   post #9 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Quote:
I made a special adapter that goes onto the tractor, mounts on the transaxle tabs. Then this engine and mount assy hang off of that and the trailer connects onto it. I'll post some pictures of the mount. It came from a Bolens 1600 so I needed to modify it to work on my tube frame. Stay tuned for some pictures.
__________________
CLICK HERE
Restored:
Restored:
Old 04-16-2012, 09:56 PM   post #10 of 48
oldmossinger
Senior MTF Member
MTF Member # 65888
looking real good so far!
__________________
G154
2 1256-01
1 1050
oldmossinger is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 10:55 PM   post #11 of 48
OldBuzzard
OldBuzzard's Avatar
MTF Member # 47201
Ed, I have an EZ-Vac mounted on one of my 1256s.
Would you like for me to post pics of what that mount looks like?
__________________
Bolens TF: 800, G10-04, G11-01(3), 1256-02(2), H14-02
Bolens LF: 1886-01 w/FEL, 1886-01 w/Forklift, 1886-01, 1886-02, 1250-01 (2), HT20D, HDT1000.
Bolens Estate Keeper 7
Attachments: More than I can list.
OldBuzzard is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 08:03 AM   post #12 of 48
Deerlope
3K Poster!!!!
Deerlope's Avatar
MTF Member # 20931
Well of course, we all like seeing pic's of any type.
Fred
__________________
Old 04-17-2012, 08:50 AM   post #13 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
If you look at that black adapter it is the one that came with the 1600. The base was a home made piece that I salvaged from another tube frame that someone made. It hooks to the transaxle tabs using the 1/2" clevis pins. The uprights were some scrap that I cut and welded in place. The horizontal piece connecting the two uprights is the original Bolens ez vac mount. I cut it off of the old base and welded it in place on the uprights.
Now, the white engine base rests in the two uprights in those little slots. Then there is a 3/4" bolt that connects the white engine base to the black base. Then on the white base there is another tab with a 1/2" hole where the trailer receiver connects. If you look closely on the white base you will see the 3/4" bolt on one end and the 1/2" hole on the other end for the trailer. It took a bit of time to get all the measurements correct but all in all it is a pretty good setup.
ID:	208941   Click image for larger version
ID:	208942   Click image for larger version
ID:	208943   Click image for larger version
__________________
CLICK HERE
Restored:
Restored:
Old 04-17-2012, 12:35 PM   post #14 of 48
OldBuzzard
OldBuzzard's Avatar
MTF Member # 47201
Looks good Ed.
Here's what the original mount for a tube frame looks like when it's mounted on the tractor.
ID:	208967   Click image for larger version
ID:	208968   Click image for larger version
__________________
Sponsored Links
Advertisement
Old 04-17-2012, 01:54 PM   post #15 of 48
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Quote:
Originally Posted by OldBuzzard View Post
Looks good Ed.
Hi Old Buzzard, you were kind enough last year to send me a lot of pictures and even some literature on this. I thank you for the pictures. I did use your pictures as a guide when I built my base. The only original piece on my base is the thing with the slots in it. I'm anxious to have it done and see how it works. I wonder if I can get the decals that went on the blower. The previous owner painted over them and I could not restore them I tried.
__________________
CLICK HERE
Restored:
Restored:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
