Ford 5610 Injector Pump Leaking - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-30-2012, 03:17 AM   post #1 of 4
ajwgator
MTF Member
MTF Member # 57962
Default Ford 5610 Injector Pump Leaking
I have a 5610 Ford and the injector pump is leaking fuel when the tractor is just sitting. The fuel is seeping up out of the shut off lever shaft and drips off the pump housing. My questions are as follows:
Is it possible to remove the control cover off the top of the injector pump without removing the injector pump from the tractor?
Can the seals on the shut off & throttle lever shafts be replaced without having to make adjustments internally to the injector pump?
Has anyone here attempted a repair like this before? If so I would appreciate any tips one might have.
Thanks!
ajwgator is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-30-2012, 09:38 AM   post #2 of 4
Tx Jim
Proud Member of the 1K Club
MTF Member # 53811
Default Re: Ford 5610 Injector Pump Leaking
If your 5610 has a CAV inj pump this will help. As you raise cover there is a spring that must be unhooked. When reattaching spring be sure to attach it in "exactly the same hole".
Tx Jim is offline   Reply With Quote Quick reply to this message
Old 03-31-2012, 12:41 AM   post #3 of 4
ajwgator
MTF Member
MTF Member # 57962
Thanks Tx Jim for the reply and the attached image. Yes the pump is a CAV and I assume the spring you are refering to is the governor spring that attaches to the throttle shaft (77). Looking closely at the image it looks as though the cover is only held down with two nuts about in the middle of it. I attempt this repair this weekend and keep a close watch on where the spring is attached before disconnecting it. Thanks again!
Sponsored Links
Advertisement
Old 04-18-2012, 01:02 PM   post #4 of 4
ajwgator
MTF Member
MTF Member # 57962
Quote:
Tx Jim or anyone, do you know where one can obtain the o-rings and top gasket for the CAV pumps without having to purchase a complete rebuild kit for the them? I've not been able to locate any parts here in town. Thanks.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
