LA 130 with K46 tranny issues - Page 2 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-28-2012, 06:01 PM   post #16 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Default Re: LA 130 with K46 tranny issues
Quote:
Originally Posted by stladrill View Post
If you take in consideration that the transaxle will run with synthetic oil after the rebuilt and if the oil change it's performed regularly it should hold for quite awhile.
Hmmm, would you recommend I replace the transmission oil in my LT150 with synthetic to avoid having to rebuild it down the road? I just got it and have no issues right now, but it would seem that doing a simple change to synthetic would be better (and cheaper) than doing a rebuild.
BTW - I didn't realize that the K46 could be rebuilt fairly easily. According to the owner's manual, there's nothing to maintain with the transmission as it is a "sealed component".
__________________
Need info on a JD tractor? Go here:Link
Need a free online owner's manual? Go here: Link
Buying JD parts? Go here for the latest coupons: Link
Current
2002 John Deere LT150 Hydro
Kohler Command CV15S 15 HP single
38" deck, material collection system, G6 Gator blades
Previous
1987 John Deere 130
Kawasaki FC290V 9HP Single
30" deck, Tri-Cycler Mulching Kit
sjlee is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-28-2012, 06:06 PM   post #17 of 45
davidg
The Travelin' Mod
davidg's Avatar
MTF Member # 807
Images: 2
it is "sealed" because Deere does not sell user serviceable parts for it, when one goes they sell a new transmission. but TT sells the parts and even makes a K46 with a filter. last time i counted, it was well over 2 DOZEN various K46 models out there for various design needs.
__________________
Check out our new HOMEPAGE
davidg is online now   Reply With Quote Quick reply to this message
Old 03-28-2012, 09:06 PM   post #18 of 45
stladrill
Run ahead of the pack
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
According to JD you have a K46C, and yes you should change the oil in it for the synthetic one.
According to TT it extend the transaxle life.
__________________
Forum Rules
Welcome Canadians Sign in!!
(Click on the image to get there)
The information provided is without warranty of any kind. In no event shall I be liable for any direct, indirect, incidental or consequential loss, damage, liability or expense incurred or suffered, claimed to have resulted from use of this information.
stladrill is offline   Reply With Quote Quick reply to this message
Old 03-29-2012, 01:53 AM   post #19 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Will do. I'm still waiting on my Gator blades to arrive, so the deck is still off... should make removing the transaxle go quicker.
BTW, I found your article on doing the oil change.
http://www.mytractorforum.com/showthread.php?t=161413
Anything you'd change since you posted it or maybe some additional advice?
I do have a question about the fill line though. I can't quite tell from the diagram where the fill line is.
__________________
Current
Previous
1987 John Deere 130
Old 03-29-2012, 09:03 AM   post #20 of 45
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
Maybe one thing to add, put a little bit of anti seize grease on the pulley splines.
The transaxle filler hole don't have a mark (line), you have to measure it (use the magnet) from the top, 20mm it's "~ and 25mm is 1".
__________________
Forum Rules
Old 03-29-2012, 10:49 AM   post #21 of 45
mikgran
Proud Member of the 1K Club
mikgran's Avatar
MTF Member # 61817
As you`re taking apart your transaxle, take pix and notes during the process. It`s easier than you think to forget just in just what order something came apart during reassembly.
Mike- Guy with CRS (can`t remember s**t)
mikgran is online now   Reply With Quote Quick reply to this message
Old 03-29-2012, 12:45 PM   post #22 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
I guess I'm still missing something. Which level do I fill it to... 20mm or 25mm?
__________________
Current
Previous
1987 John Deere 130
Old 03-29-2012, 12:47 PM   post #23 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Thanks for the advice. I get CRS many times while disassembling things. I'm actually considering filming the entire process just so that I can go back and watch it when I start forgetting where parts go.
__________________
Current
Previous
1987 John Deere 130
Old 03-29-2012, 05:50 PM   post #24 of 45
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
You fill it at 20mm, after the bleeding procedure the oil should be at 25mm "line/mark"
It do not matter if the oil level is not perfectly at the exact level, just do your best to respect it.
on pictures or video, one small piece as tendency to drop on the floor, it is demonstrated on the previous video.
__________________
Forum Rules
Old 03-29-2012, 08:34 PM   post #25 of 45
DeereRider
Senior MTF Member
DeereRider's Avatar
MTF Member # 55538
About a year ago I removed my K46 from my X300, opened it up, cleaned the insides and the magnets, filled it with Castrol 5W50 and re-assembled and reinstalled. It was a pretty easy job and I think its good preventative maintenace. I do a lot with my X300 and the trans still preforms like it did the first day. I did this oil change at 200 hours and I will continue to do it every 150 to 200 hours. Putting the 5W50 is a big improvement over the 30 or 40 weight thats in it from the factory.
__________________
2012 X500, 48" Edge Deck, 44" Snow Blower, 48" Plow Blade, De-thatcher, 42" Lawn Sweeper, 4 John Deere Suitcase weights, wheel weights, chains and HDAP's
2007 X300 with 245 hours, 42" deck SOLD
30" Mechanical Tiller SOLD
DeereRider is offline   Reply With Quote Quick reply to this message
Old 03-30-2012, 05:29 PM   post #26 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Thanks for all your advice. I might have a free day this weekend to change the oil in the K46. Hopefully I'll have good news on Monday about how it went.
__________________
Current
Previous
1987 John Deere 130
Old 03-30-2012, 09:24 PM   post #27 of 45
stladrill
stladrill's Avatar
MTF Member # 31914
Images: 4
Garage
I'm sure everything will go well.
__________________
Forum Rules
Old 04-01-2012, 09:05 PM   post #28 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Well, I just got back in from the garage... and unfortunately things didn't quite go smoothly.
The removal of the transaxle wasn't too bad. The problem came when removing the fill cap. I couldn't figure out how to remove it and ended up tearing it, so I have to order a replacement now. I didn't realize that there was a metal ring on the cap.
The other thing I found out was that the previous owner likely already changed the oil and replaced it with synthetic... likely Royal Purple. The oil was very clean looking and had a purplish tint to it. Unfortunately, I didn't know this until I started to drain it. Oh well, at least it'll have fresh Castrol in it going forward.
Hopefully the new fill cap comes quickly... I need to get the mower back together and now the grass.
__________________
Current
Previous
1987 John Deere 130
Old 04-01-2012, 10:26 PM   post #29 of 45
wally2q
2000 Posts and climbing!!!
wally2q's Avatar
MTF Member # 45
purple?... sounds like ATF !!
wally2q is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-02-2012, 01:05 AM   post #30 of 45
sjlee
Senior MTF Member
sjlee's Avatar
MTF Member # 33716
Quote:
Maybe Royal Purple ATF... I'm not aware of any other brands that color their ATF purple.
__________________
Current
Previous
1987 John Deere 130
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
