TN70 4x4 Problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-22-2012, 10:46 PM   post #1 of 5
Tabasco
MTF Junior Poster
MTF Member # 67182
Default TN70 4x4 Problem
Just purchased a 2003 TN70 and I am having problems getting the 4x4 to engage. It is the pull up lever style with no indicator light. The book says to pull up while decelerating but that is not getting it done. I have tried clutching, not clutching as well as various speeds. Can someone help please?
Tabasco is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-28-2012, 01:54 PM   post #2 of 5
Larry from MT
Senior MTF Member
MTF Member # 44441
Default Re: TN70 4x4 Problem
Sorry you haven't gotten any help. My D40 Case has the same system. I usually engage 4WD while standing still with the clutch depressed. Sometimes I've had to move the tractor a bit to engage -- but seldom. I disengage while still or moving with the clutch depressed.
If I was having a problem I'd check the exposed linkage first to make sure it had enough adjustment to engage. Total movement on my lever is probably 2-3".
Are you SURE that it's not engaging? You can't tell on mine unless you load it up to the point that you need 4WD ---- as in when I'm using a 6' tilling implement or in deep snow.
__________________
Case D40
John Deere 111
Rumely 25-40
McCormick Deering 15-30
Larry from MT is offline   Reply With Quote Quick reply to this message
Old 03-28-2012, 10:43 PM   post #3 of 5
Tabasco
MTF Junior Poster
MTF Member # 67182
Thanks for taking the time to reply. I had checked the linkage and it seemed adequate. I tried engaging from a dead stop once before and it did not work. I will try that again as i usually am rolling as the book recommends. Thanks again.
Old 02-18-2013, 02:42 PM   post #4 of 5
SandsFarms
MTF Junior Poster
MTF Member # 83373
Hello,
Were you able to resolve the 4x4 engagement problem?
We have a TN70 with the same issue. Thanks. Scott
SandsFarms is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-18-2013, 09:29 PM   post #5 of 5
Tabasco
MTF Junior Poster
MTF Member # 67182
Scott,
Yes, I figured out the best way for my particular tractor. I travel at a moderate speed and then decelerate quickly as I pull up hard on the lever. Do not engage the clutch. I find it helps to do this on a slight decline or down slope. Maybe it will work for you.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
