432 Commercial - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 03-12-2012, 06:28 PM   post #1 of 23
Billmac001
MTF Member
MTF Member # 70593
Default 432 Commercial
Hello all, I have a few Gravely related questions. I have an early 432 commercial. It has the rear mounted attachment lift. I found the schematic here :
http://www.oldgravelys.net/pdf/Rear_...t_IPL_1071.pdf..
I have the hitch and almost everything to make it complete, however I am missing part #'s 14721P1 which is the clevis rod, 14719, which is the clevis. Anybody out there able to help me locate these parts?
Also looking for the attachment to hook up the rotary plow and the roto tiller to the front of this machine as well. I just picked up L today with the brush mower, the rotary plow and the rototiller and would like to mount them to the front of my 432 if possible.
Billmac001 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 03-12-2012, 10:06 PM   post #2 of 23
canadian.gravelynut
Senior MTF Member
canadian.gravelynut's Avatar
MTF Member # 43243
Default Re: 432 Commercial
The parts that you are looking for do show up on E-bay that might be the place to look or at the Mow-in
__________________
It is Gravely season
John
canadian.gravelynut is offline   Reply With Quote Quick reply to this message
Old 03-12-2012, 11:55 PM   post #3 of 23
Billmac001
MTF Member
MTF Member # 70593
Thanks for the reply
Old 03-13-2012, 12:29 AM   post #4 of 23
FLOYD'S
Senior MTF Member
FLOYD'S's Avatar
MTF Member # 54440
Garage
i can have those for you soon. i am parting a 432 this week.
FLOYD'S is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 12:38 AM   post #5 of 23
Billmac001
MTF Member
MTF Member # 70593
That would be great!!
Old 03-13-2012, 09:25 AM   post #6 of 23
deerecharles
Senior MTF Member
deerecharles's Avatar
MTF Member # 35519
Quote:
Does it have an electric lift?
__________________
deerecharles is offline   Reply With Quote Quick reply to this message
Old 03-13-2012, 09:29 AM   post #7 of 23
FLOYD'S
Senior MTF Member
FLOYD'S's Avatar
MTF Member # 54440
Garage
no, it is manual lift.
Old 03-13-2012, 05:07 PM   post #8 of 23
Billmac001
MTF Member
MTF Member # 70593
No on the electric lift but that would be nice.
Old 04-07-2012, 04:22 PM   post #9 of 23
Billmac001
MTF Member
MTF Member # 70593
I have another question about this tractor. When I got it the PO advised me that it would work in low range and reverse but not in high range or when the mower was engaged it would slow down. I pulled the engine off today and this is what I found. I believe this is the rear ring gear? any ideas what would cause this wear?
ID:	207050   Click image for larger version
ID:	207051   Click image for larger version
Old 04-07-2012, 04:42 PM   post #10 of 23
arcam8123
Gravelyyard.com
arcam8123's Avatar
MTF Member # 1157
Very worn bushings in the planetary gears. Here's what I found in my Pro Master 50 that did the same thing except it would not work in low range.
The bushing is .036 clearance. It should not be more than .002 if my memory serves me.
ID:	207053   Click image for larger version
ID:	207054   Click image for larger version
ID:	207055   Click image for larger version
arcam8123 is online now   Reply With Quote Quick reply to this message
Old 04-07-2012, 07:32 PM   post #11 of 23
Billmac001
MTF Member
MTF Member # 70593
Well that would explain things, Are there bushing kits available to rebuild the planetary or do I need to send the planetary to Richards?
Old 04-07-2012, 08:40 PM   post #12 of 23
arcam8123
Gravelyyard.com
arcam8123's Avatar
MTF Member # 1157
You can buy bushings for replacement, but you need to measuse the pins and bolts to make sure they are still round and not oval. Those bolts are left hand thread by the way.
Old 04-07-2012, 11:58 PM   post #13 of 23
arcam8123
Gravelyyard.com
arcam8123's Avatar
MTF Member # 1157
Here's some pictures of a worn bolt and bushing next to a NOS bolt and bushing. You can see the difference. What you can't see is that the bolt is .010 out of round.
ID:	207173   Click image for larger version
ID:	207174   Click image for larger version
Old 04-08-2012, 12:26 AM   post #14 of 23
Billmac001
MTF Member
MTF Member # 70593
Thanks for the replies Ron....
Sponsored Links
Advertisement
Old 04-08-2012, 12:52 AM   post #15 of 23
Richard-tx
5000 Strong & Climbing
Richard-tx's Avatar
MTF Member # 51208
Images: 7
If it were mine I would replace the orbit gears as well as the ring gear. I would also examine the sun gear (engine gear) for wear. There is also the pilot bushing to examine as well.
__________________
Code:
                              Current Inventory
   24G (Onan 24hp)    24GLX - was 16G  (Onan 24hp)   8249 - was 8129 (Onan 24hp)
        818T (Onan 18hp B48)       8163T - was 8123 (Onan CCKA)
                              8183T (Onan B48)
   5665 w/brakes        5665        5660        Pro-8         Pro-16 w/brakes
For Gravely Manuals and more visit http://GTCOA.com
Richard-tx is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
