Just another rebuild thread!! Bolens GK - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-25-2012, 05:41 PM   post #1 of 75
timberlakeowen
Senior MTF Member
MTF Member # 57867
Default Just another rebuild thread!! Bolens GK
So I will give you the background on this bolens GK. I bought it last summer and it has been sitting in my shed since then untill yesterday. My cousin and I pushed it into my shop and started working on it (carb rebuild, clean the fuel pump, a new tank. We couldent get it running untill today i fixed the spark module (twisted the wires up and shoved them in and put a screw in to hold them). Adjusted the carb to 1 1/2 turns out squirted gas in the cylynders and it fired up and off I went. When i post the videos you will see that it doesent steer well because the steering valve needs a heli coil kit (the valve twists) It has no muffler no attachments so the front end is quite light. The hood is in my shop. This is going to be a slow rebuild with lots of questions that i will need answers for so PLEASE feel free to help. I will post pictures later tonight when i get them uploaded. I also have a few videos but they may come a little later.
-Owen
timberlakeowen is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-25-2012, 07:21 PM   post #2 of 75
BOSMECH
Proud Member of the 1K Club
BOSMECH's Avatar
MTF Member # 38136
Default Re: Just another rebuild thread!! Bolens GK
Can't wait I want pictures now
BOSMECH is offline   Reply With Quote Quick reply to this message
Old 02-25-2012, 07:24 PM   post #3 of 75
BOSMECH
BOSMECH's Avatar
MTF Member # 38136
Hello any one home we want those pictures
Hello wake up are you a sleep
Old 02-25-2012, 08:49 PM   post #4 of 75
jason4567
jason4567's Avatar
MTF Member # 30557
Garage
This is going to be a very interesting restoration to watch, and I bet it's going to be a really nice restoration just like your 1054.
Jason
jason4567 is offline   Reply With Quote Quick reply to this message
Old 02-25-2012, 10:28 PM   post #5 of 75
timberlakeowen
Senior MTF Member
MTF Member # 57867
1. Here are the pictures 2. This will be better than the 1054 thread
Included is my new sandblasting gun for the project!!
Videos will be put up on flicker
http://www.flickr.com/photos/oldengi...in/photostream
-Owen
ID:	200394   Click image for larger version
ID:	200395   Click image for larger version
ID:	200396   Click image for larger version
Old 02-25-2012, 11:09 PM   post #6 of 75
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Wow Owen that is a big engine in that tractor. I never owned one so I may not be much help but it will be fun to watch your progress on this.
__________________
CLICK HERE
Restored:
853, 1556, 1556 Loader, custom 1856, 1669, 1886, HT23
Restored:
tillers, 3pt, sleeve hitch, E-Z Vac, mowers, single & 2 stage blowers, moldboard, front and rear pto chippers/shredders, wheelbarrow attachment, aerator
ed-nh is offline   Reply With Quote Quick reply to this message
Old 02-26-2012, 08:17 AM   post #7 of 75
Deerlope
3K Poster!!!!
Deerlope's Avatar
MTF Member # 20931
-Owen
What blast media will you use in that gun?
__________________
"1886 Upper Heat Shrouds Available"
Operational 2486,1886: 1455; 900;DGT1700, Kubota RTV900; Kubota M-5040; Kubota excavator KX 057; B-2650 Kubota, JD332 diesel
]Deerlope's Bolens on YouTube[
Till the soil til I am soil.
Deerlope is offline   Reply With Quote Quick reply to this message
Old 02-26-2012, 01:41 PM   post #8 of 75
mikebramel
Senior MTF Member
MTF Member # 38183
Once you sandblast with an adequate sized compressor you wont want to use anything else
mikebramel is offline   Reply With Quote Quick reply to this message
Old 02-26-2012, 02:54 PM   post #9 of 75
timberlakeowen
Senior MTF Member
MTF Member # 57867
I use black beauty sandblasting sand and even with a decent sized compressor you have to wait occasionally. Now that it runs i am going to start the SLOW rebuild as i have other projects that I do at the same time. My first question is how do you get fiberglass ready for paint? My sandblaster? And what do i use to fill in the chips and cracks because the hood looks pretty rough?
-Owen
Old 02-26-2012, 03:32 PM   post #10 of 75
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Same kind of blasting gun I use, if you have deep rust you'll be further ahead hitting it with a twisted wire brush wheel before using the sandblaster.
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 02-27-2012, 01:04 AM   post #11 of 75
mikebramel
Senior MTF Member
MTF Member # 38183
You can soda blast it or a da sander
Old 02-27-2012, 12:36 PM   post #12 of 75
BOSMECH
BOSMECH's Avatar
MTF Member # 38136
After watching the video I want my own GK
Old 02-27-2012, 06:27 PM   post #13 of 75
LPBOLENS
Nine Year Site Sponsor
MTF Member # 857
I have seen fiberglass repaired by sanding off the top coat until you get into the raw fiberglass, then soaking the old, dried -out fiberglass with fresh resin to resolidify the old stuff. I think that is what professional restorers do to old Corvette bodies, then they do the follow up repairs on a good substrate.
I would think that media blasting would cut into the old fiberglass too quickly.
__________________
Doug
Bolens:1254, G14, H14, Whirly Rake, generator; 1250 (2), 1455, 1886, HT20, HT20D, HT23 (4), typical attachments, Danuser post hole digger, Haban Sickle-Mo, Johnson FEL,forklift, Brantly backhoe; Cozy Cab; GK (2) 72" decks, dozer blades, snowblower; Ridemaster 35AB01, sickle mower, disc harrow, grader, hitch; Power Ho (3), sulky, snowcaster, air compressor
Bush Hogs: D4-7, D4-10 (parts), D4-12, plow blades & MMM (Want the 42" trail mower!)
Massey Ferguson: MF12 (1967), MMM
LPBOLENS is offline   Reply With Quote Quick reply to this message
Old 02-27-2012, 06:49 PM   post #14 of 75
timberlakeowen
Senior MTF Member
MTF Member # 57867
I am thinking i will sand with orbital sander then bondo the chips. I dont want to try what LP bolens said because i am terrible with fiberglassing (my canoe looked like the sides were bulging out ond still leaked). need some bondo now. The hood is currently sitting in my basement so i will start cleaning and striping it tonight.
-Owen
Sponsored Links
Advertisement
Old 02-27-2012, 08:29 PM   post #15 of 75
Mike.ASC
2000 Posts and climbing!!!
Mike.ASC's Avatar
MTF Member # 39049
Cool machine . Pardon my ignorance , what kind of engine does that have ?
Mike
Mike.ASC is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
