Ford 3000 Hydraulic Issue - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-19-2012, 04:17 PM   post #1 of 5
airjay5
MTF Junior Poster
MTF Member # 69999
Default Ford 3000 Hydraulic Issue
I need help with an issue that I think I might have introduced to my hydraulics on a Ford 3000. I had the lift cover assembly off to replace the filters because the system was real slow. I changed filters, replaced o-rings, and put the system back together. After bleeding the hydraulics, the lift was smooth and was working fine. The one thing I've noticed is that now I can manually raise and lower the control arms with the tractor turned off. I took the cover assembly back off but I don't see what would stop the piston rod from moving up and down. Does anyone have any suggestions?
airjay5 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-19-2012, 05:03 PM   post #2 of 5
scm
Senior MTF Member
MTF Member # 38403
Default Re: Ford 3000 Hydraulic Issue
If the engine is not running theres no pressure your arms will raise by hand. As long as there not lowering when the engine is running you're ok.
__________________
2007 John Deere 5203 2009 John Deere X500 48'' deck 2010 John Deere X300 42'' deck And too many attachments to list
scm is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 06:25 PM   post #3 of 5
airjay5
MTF Junior Poster
MTF Member # 69999
Thanks. I wasn't for sure. It just didn't seem right but when I look at the piston and piston rod, there's nothing that holds the arms down even if the engine is running. This is my first tractor and I was trying to figure out how my disk or breaking plow would stay in the ground if you can raise by hand. I guess it's the weight of the implement that keeps it in the ground.
Old 02-19-2012, 07:01 PM   post #4 of 5
scm
Senior MTF Member
MTF Member # 38403
yes the weight of the implement plus the proper adjustment of the turnbuckle is what makes it work.
__________________
Sponsored Links
Advertisement
Old 02-20-2012, 12:59 PM   post #5 of 5
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
When plowing or disking you should have the 3 point in draft control mode rather than position control mode. This will allow the weight of the implement to keep a constant amount of pressure on the work being done instead of keeping the implement at a specific height, so if you encounter rocks or harder soil or any other kind of increased resistance then the system will actually raise the implement up until the amount of resistnce matches what it is set for, and then after the area of increased resistance has been passed it will lower it back down.
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
