Finally built my mid mount grader blade - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 02-04-2012, 03:48 AM   post #1 of 5
TractorBob
Senior MTF Member
TractorBob's Avatar
MTF Member # 40681
Default Finally built my mid mount grader blade
I read swdias thread and asked some questions and finally made my blade happen! It's not finished yet but this was the fitting and it fits perfect! I couldn't resist and had to go try it down in the town yard sand pile just down the road from me and it works AWESOME!! for the tips and help swdias and poncho62.
I took an old 48" craftsman dozer blade cut it down to height, turned the push bar around to be the drawbar and pivot. I welded a piece of channel to the front of the drawbar with side tabs to bolt it to the frame for the lift pivot point(seen in pics above). I used a piece of chain I had laying around to hang the blade with. I got the chain length right the first shot. I may also fab up some bars on each end of the blade to put weights on for some down pressure and to help dig hard packed dirt and soil.
My attachment for the blade is still in the process of laying out but heres a pic to get an idea. I am going to weld all the U shaped pieces on as teeth to scarify the ground. The points of the teeth will be about 3/4" below the blade to give some digging depth in tough, rocky NH dirt. I am going to weld 4 tabs to the top of the scarifier to through bolt it to the main grader blade. I want it to be easily removed when its not needed for finish work.
Now I need to take it back off and finish grinding down the messy welds trim the lifting chain to the right size and make a handle for the lock that holds the blade from pivoting. Then most importantly make it blue!!
Next I'm thinking a 3 pt hitch. But we'll see if I'm able to do that. If I do do that, then I may have to talk to skyrydr2.
__________________
65 Sears Suburban 8 HP w/ 10 HP repower (The Old Tractor)
72 Ford LGT125 (The Hydro)
74 Ford LGT100 (The Ford)
Johnson FEL
48" Dozer
48" Mid grader
50" Mower
42" snowthrower
86 F350 1 tn PU 4x4
03 Dodge Durango 4x4
"There is a sickness worse than alcohol and dope, it is the tractor debt, and there is no cure in sight."
TractorBob is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-04-2012, 07:34 AM   post #2 of 5
skyrydr2
Proud Member of the 1K Club
skyrydr2's Avatar
MTF Member # 32073
Default Re: Finally built my mid mount grader blade
Awsome job Bob! 3 point hitch is easy as long as you have a hydro trans to attach to the axle
__________________
Keith
'82 Ford LGT 165(Kubota diesel conversion)
'72 Ford LGT 125 (loaded, 3 point hitch, and rear pto, and hydraulic lift )
'58 Ford 1841 Industrial(for the big jobs)
skyrydr2 is offline   Reply With Quote Quick reply to this message
Old 02-04-2012, 08:37 AM   post #3 of 5
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
Looks good...I need to stiffen up the blade on mine a little
__________________
That National Mower guy
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
poncho62 is offline   Reply With Quote Quick reply to this message
Old 02-04-2012, 11:53 AM   post #4 of 5
TractorBob
Senior MTF Member
TractorBob's Avatar
MTF Member # 40681
Poncho, It was easier to make than I thought. I had to use my neighbors torch and was going cut the db down the center to build it the way you and swdias did with the separate triangular drawbar but he convinced me to leave the drawbar solid for strength reasons so I did. It is very solid and has no flex to it what so ever.
Sky, Your hitch build pops up every time I do a search for ideas. I have been looking at different ideas on the 3 pts and haven't really found one on a lgt 100 other than a sleeve hitch. I have a 4 spd trans and it is quite different from your hydro tractors. Here's a pic of my rear. What part of MA are you in? I'm originally from 20mins south of boston.
__________________
Johnson FEL
48" Dozer
48" Mid grader
50" Mower
42" snowthrower
86 F350 1 tn PU 4x4
Sponsored Links
Advertisement
Old 02-04-2012, 09:02 PM   post #5 of 5
skyrydr2
skyrydr2's Avatar
MTF Member # 32073
North central Ma. Right off rt2 litterally .
As far as all the brackets, they are universal and should work on your rig as well. Not sure about the lower arms though ? I have to finish my LGT125 soon, as spring is coming and I would like it finished and painted . All that is left is the pto shaft setup.
__________________
Keith
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
