I built a Mid Mount grader blade for my 140 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-17-2012, 10:01 PM   post #1 of 25
sawbuckjohn
MTF Junior Poster
sawbuckjohn's Avatar
MTF Member # 22484
Default I built a Mid Mount grader blade for my 140
Hi Guys,
PA318GUY said I should post some pics, so..., The best I know how to do here is post the link to my off site. The first is before adding the scarifier. The second is after. It's been frozen, now too wet to really try it but it should do what I want. My linkages do not allow for downpressure, I thought about adding hooks for weight behind blade. I want to wait and see how it performs first..
http://www.use.com/Mid_mount_grader_...5108e9df16fadf
http://www.use.com/Mid_Mount_grader_...80c4bb2b8e6812
sawbuckjohn is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-17-2012, 10:11 PM   post #2 of 25
69project
Proud Member of the 1K Club
69project's Avatar
MTF Member # 40646
Default Re: I built a Mid Mount grader blade for my 140
Nice piece of work. I am not sure the stock ones had any down pressure either.
69project is offline   Reply With Quote Quick reply to this message
Old 01-17-2012, 10:32 PM   post #3 of 25
dmorrill22
Sears Fan
dmorrill22's Avatar
MTF Member # 38986
Images: 26
Garage
Hope you don't mind me posting them:
Awesome job on the blade!
__________________
Doug
1966 Colt 2712 (Restoration in progress)
1969 Sears SS12 (Soon to be a dedicated grader!)
- Homemade snow plow (in progress)
- GM 3-wire alternator
- Duromax 16hp Repower
- Custom headlights
1972 Sears SS15 (Work in progress)
dmorrill22 is online now   Reply With Quote Quick reply to this message
Old 01-17-2012, 11:16 PM   post #4 of 25
sawbuckjohn
MTF Junior Poster
MTF Member # 22484
Thanks guys. I don't mind a bit..., but how did you do it?
Old 01-17-2012, 11:21 PM   post #5 of 25
FnT96
Senior MTF Member
FnT96's Avatar
MTF Member # 54164
Great Job ! Looks heavy duty !
FnT96 is offline   Reply With Quote Quick reply to this message
Old 01-17-2012, 11:25 PM   post #6 of 25
396 big block
2000 Posts and climbing!!!
396 big block's Avatar
MTF Member # 68626
Garage
For some reason the pic, with blade on the tractor looks upside down??
396 big block is online now   Reply With Quote Quick reply to this message
Old 01-17-2012, 11:27 PM   post #7 of 25
396 big block
MTF Member # 68626
Garage
Quote:
But very nice."Nice job" I bet you saved some money..
Old 01-17-2012, 11:28 PM   post #8 of 25
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
John glad you posted the links and dmorill22 thanks for helping out! John, here's one way to do it: http://www.mytractorforum.com/showthread.php?t=77144
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 01-17-2012, 11:31 PM   post #9 of 25
Mike X485
New Guy....Trainee
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Great job on the blade.
__________________
JOHN DEERE X748
Mike X485 is online now   Reply With Quote Quick reply to this message
Old 01-17-2012, 11:37 PM   post #10 of 25
dmorrill22
Sears Fan
dmorrill22's Avatar
MTF Member # 38986
Images: 26
Garage
Quote:
Since you already provided a link to the images, I opened up the link. I right clicked on the picture and selected "copy image location" and then came back to the forum page. In the reply box, you will see a yellow box with a mountain and a sun. Click on it, and paste the link in, and the image will appear in your post. Basically, if you have the link to the picture, you just have to surround the link with [img][/img].
example (remove quotes):
"[img]"http://yoursite.com/image.jpg"[/img]"
Hope this helps!
__________________
Doug
- Custom headlights
Old 01-18-2012, 01:23 AM   post #11 of 25
John@Reliable
Banned!
MTF Member # 37003
Very nice work on that blade set-up
on my to do list, long list
John@Reliable is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 08:39 AM   post #12 of 25
rabbitking61
MTF Member # 54524
Great Job! I bet you really enjoyed building it.
rabbitking61 is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 08:56 AM   post #13 of 25
sawbuckjohn
MTF Junior Poster
MTF Member # 22484
Okay, I think I got it. I didn't notice the "Mountain with Sun" image. Or it didn't ring any bells. I'll try again.
Oh, I don't know why it looks upside down, maybe when focused in too close we loose perspective??
Old 01-18-2012, 10:31 AM   post #14 of 25
Alan_Heist
Tractor nut, general nut
Alan_Heist's Avatar
MTF Member # 34174
Looks good. Did you build it from scratch or adapt it from another use?
Another idea you might use for down-force... come off the side of your support bracket with a could of bolts, or even weld some plates on... when you need down-force, stand on them. This would be a way to custom vary the amount of down-force up to your weight. Just an idea to consider since space above and behind your blade might be limited to add weight.
EDIT: Wouldn't it look better in JD Green?
__________________
'70 Wheel Horse Charger 12 (Was Dad's, he got it when I was about 6mo's old)
'72 John Deere 112 Electric Lift found a new home.
'70 Case 220
'70 Case 444
'72 Case 222
(Both 220's for an upcoming 4WD articulated project)
'02 Crafstman LT1000 repowered with a 22 HP Opposed Briggs cause the 17 single blew the rod
GrassHopper 220 .. Zero-Turn for the mowing duties
Alan_Heist is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-18-2012, 10:54 AM   post #15 of 25
sawbuckjohn
MTF Junior Poster
MTF Member # 22484
Thanks Alan, To Answer.., I had an old Simplicity blade that I was never going to use, cut it down, removed the angle mount/bracket, remounted it , found some steel, used the hangers from a 318 deck(which wouldn't work on the 140), fit everything together. The cutting edge is soft steel at this point(until my local Bobcat type can find a used piece of one), which is another reason for the scarifier, Hung it off etc. Did all with a 4.5" grinder with cutting wheels, and my Hobart 140 MIG.
Clearance is an issue, but small weights will clear on the back in vertical, but I only gain 20-30lbs. I may weld some foot pedals or some such on, but not wild about the idea. I have seen guys do footrests on the blade itself, but when angled, that is pretty close to a turning tire w/chains. The mount is pretty rigid, so varying the weight one side to the other isn't gonna help much as far as tilt goes , and I really planned on level cutting. The tilt option would be nice for some applications, but there are other methods/tricks to make that happen. I really just wanted to regrade my lane.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
