New to me Snapper LT 12 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-09-2012, 08:45 AM   post #1 of 11
KDS111
MTF Junior Poster
MTF Member # 68968
Default New to me Snapper LT 12
Hello all,
I've got a recently purchased LT12 that ran great last week but now has no spark. I've removed the steering head assembly and driveshaft from the motor which is a twin cylinder briggs 12.5 HP. Before I remove the engine cover and tear into this, is there specific things to look for and do.
My small engine experience goes back to points and condenser not electronic ignition as this has. Does the module/Coil need to be replaced? If so is there a testing procedure.
__________________
Thank You
Ken S.
88? Snapper LT 12 Snowplow.
KDS111 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-10-2012, 11:40 AM   post #2 of 11
KDS111
MTF Junior Poster
MTF Member # 68968
Default Re: New to me Snapper LT 12
__________________
Thank You
Ken S.
Old 01-10-2012, 11:55 AM   post #3 of 11
bepperb
MTF Junior Poster
MTF Member # 68391
No spark?
The magnetron ignition is pretty simple. Make sure there is about a business card of space between the flywheel magnet and the magneto. Off that will be the spark plug wire and also a grounding wire to kill the engine.
Really, I'd think it more likely that the kill wire is grounded by a broken (or working) safety switch than broken ignition. But you could test that easily just by disconnecting that kill wire.
bepperb is offline   Reply With Quote Quick reply to this message
Old 01-10-2012, 01:54 PM   post #4 of 11
Dude11
2000 Posts and climbing!!!
Dude11's Avatar
MTF Member # 8852
Images: 4
Got a volt/ohm meter? I couldn't do without one.Kinda basic gotta have item when fooling with engines.
__________________
Dude11
Dude11 is offline   Reply With Quote Quick reply to this message
Old 01-10-2012, 07:46 PM   post #5 of 11
KDS111
MTF Junior Poster
MTF Member # 68968
There is no coil?
This is a horizontal twin cylinder engine.
Where does the kill wire run from.
There is one small wire bolted to the head.
On the other side is another with a plastic connector that separates.
Is there anything under the flywheel to replace or adjust?
__________________
Thank You
Ken S.
Old 01-11-2012, 11:17 AM   post #6 of 11
bepperb
MTF Junior Poster
MTF Member # 68391
No.
Ok.
It runs from the magneto through the wiring harness. If anything grounds it there is no spark. Things that ground it are the ignition switch and most safety switches.
I dont know what the small wire bolted to the head is.
I don't know what the plastic connector is. It could be the alternator circuit, it could be the kill circuit.
No, assuming it's relatively new (1980's IIRC) the magnetron ignition is a modular piece outside the flywheel. Timing is adjusted by the magnet's position on the flywheel, which is held in place by the flywheel key. But the timing being off would still allow it to spark. Take the engine cover off and take some pics.
Old 02-11-2012, 04:19 PM   post #7 of 11
khoek122083
MTF Member
MTF Member # 52769
i got one of those myself, and it runs like a champ. changed ignition switch and checked gear lube on drive system. if i were you, i would replace the entire igniton system. i found it to be very beneficial on the lt 11 i had and the lt 12 i currently have. you might also wanna check the rear end and put some gear lube in it if needed. should just be a black plastic cap on top of the trans op the top left side of the case. the rear tires can some times be a pain in the a** to locate. other than that, its an excellent machine.
khoek122083 is offline   Reply With Quote Quick reply to this message
Old 02-11-2012, 07:36 PM   post #8 of 11
KDS111
MTF Junior Poster
MTF Member # 68968
Quote:
When you say replace the entire ignition system, can you specify all the parts you would replace.
__________________
Thank You
Ken S.
Old 02-11-2012, 10:23 PM   post #9 of 11
khoek122083
MTF Member
MTF Member # 52769
switch, solenoid, magneto, and it wouldnt hurt to throw a fresh spark plug in it. i just had to put a new switch in mine and i was good to go. you might also want to try sanding off the flywheel with a piece of sandpaper and re-setting the magneto. there should be a matchbook thickness between the magneto and the flywheel.
Old 02-13-2012, 08:29 AM   post #10 of 11
KDS111
MTF Junior Poster
MTF Member # 68968
Are the parts still available from a dealer?
Is there a good online source for the parts?
__________________
Thank You
Ken S.
Sponsored Links
Advertisement
Old 02-13-2012, 11:41 AM   post #11 of 11
khoek122083
MTF Member
MTF Member # 52769
if you call most any small engine repair shop, they should be able to help ya.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
