14hp kohler hard to turn over - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 01-07-2012, 09:17 PM   post #1 of 11
Packrat
Senior MTF Member
Packrat's Avatar
MTF Member # 15571
Default 14hp kohler hard to turn over
A friend of mine is having trouble with his riding mower. He got it about 6 months ago, was running and starting fine. Last week he goe's to start it after letting it sit for a month. Didn't want to turn over so he pulls the plug, it turned over but was stiff. After cranking it a while with no spark plug it loosened up a bit. He put the plug back in and got it running. Now it starts and runs fine when warm but when its cold, it has a hard time turning over. Any thoughts about what may be the problem? The battery is good. Starter appears to be ok. I think the model of the engine is a K321. Any ideas as to what the problem might be?
__________________
1984 Craftsman GT6000 with snowblower - Got it free
1966 Snowbird S-228 - Got it free
1971 Homelite S-8 - paid $30
Packrat is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-07-2012, 10:01 PM   post #2 of 11
larrybl
5000 Strong & Climbing
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Default Re: 14hp kohler hard to turn over
Change the oil and spark plug, New Battery, Adjust the points.
larrybl is online now   Reply With Quote Quick reply to this message
Old 01-07-2012, 11:31 PM   post #3 of 11
Packrat
Senior MTF Member
Packrat's Avatar
MTF Member # 15571
Quote:
I don't know about the plug and points, but I know the oil is fresh and the battery is good(starts all his other riders no problem) Should be turning over easy seeing how most of the older kohlers had a ACR
__________________
Old 01-07-2012, 11:37 PM   post #4 of 11
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
My K321 has an ACR, but beats me on how to trouble shoot it, as mine is working I will follow this thred for future reference.
Old 01-08-2012, 03:56 AM   post #5 of 11
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Is there PTO dragging at all? If its a Hydro..cold hydro fluid is thick and if the pump is not perfectly in neutral it can drag the starter down.
__________________
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 K3500 Dually Sierra
Crew Cab, Long bed, Vortec 454
1995 K3500 Silverado
TBI 454
1995 K2500 Silverado
6.5 Detroit Turbo Diesel
1994 GMC Sierra Z71
350 TBI
RED-85-Z51 is offline   Reply With Quote Quick reply to this message
Old 01-08-2012, 04:01 PM   post #6 of 11
Packrat
Senior MTF Member
Packrat's Avatar
MTF Member # 15571
Quote:
Nothing is hooked to the pto so I don't think its dragging, but it is hydro so maybe thats causing the problem.
__________________
Old 01-08-2012, 08:05 PM   post #7 of 11
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
How hard would it be to disconnect the hydro?
__________________
Onan P216G
1962 WH702
TBI 454
1994 GMC Sierra Z71
350 TBI
Old 01-08-2012, 09:00 PM   post #8 of 11
caseguy
MTF Member
caseguy's Avatar
MTF Member # 7229
If youve done all the tune up stuff , check the valve clearance. The arc run off the cam and if the clearance is to large it wont open the valve enough. If you think yopu have a issue you can pull the head and watch or measure the opening .. check the book. if you have points make sure they are good shape ..
caseguy is offline   Reply With Quote Quick reply to this message
Old 01-08-2012, 09:04 PM   post #9 of 11
poncho62
National Mower Guy
poncho62's Avatar
MTF Member # 19374
Images: 7
Brushes or bearing in the starter may be worn......
__________________
That National Mower guy
National Reel Mower
Ford LGT100
Ford LGT125
M-F 10
John Deere STX38
Ontario Rodders
poncho62 is offline   Reply With Quote Quick reply to this message
Old 01-08-2012, 09:18 PM   post #10 of 11
WNYTractorTinkerer
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Question Re: 14hp kohler hard to turn over
Main battery cable conections clean & tight??
__________________
Experience is something we get.... right after we needed it!!
Can You see the Real me?
WNYTractorTinkerer is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-08-2012, 09:30 PM   post #11 of 11
RedOctobyr
Senior MTF Member
MTF Member # 33934
You could also try jumping it directly to the starter, I presume. That might help you rule out some wiring issues.
If it turns over slowly even with the plug removed, that would make me suspect either a problem with the starter, or some sort of parasitic drag, like RED-85-Z51 mentioned. For that matter, with the plug removed, how does it rotate if you try to turn the engine by hand?
RedOctobyr is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
