starter for gravely rider - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 01-06-2012, 11:22 AM   post #1 of 19
danmack61
MTF Member
MTF Member # 19848
Default starter for gravely rider
I am hoping that someone can help me with starter problem. My gravely rider has a onan twin cylinder ,but the only# I can find is stamped on the manifold ( 170-1542) indicates it came off of a onan's generator.Have tried different starters bought off of E-bay but cannot match it. Have tried different spaces in different positions,but nothing seems to work. Any help in identifying it would be a lot of help,
danmack61 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 01-06-2012, 12:14 PM   post #2 of 19
Richard-tx
5000 Strong & Climbing
Richard-tx's Avatar
MTF Member # 51208
Images: 7
Default Re: starter for gravely rider
Dan,
Some pictures would help.
My guess based on the number is that it is a CCKA
Take a look here and see if anything matches.
http://www.psep.biz/store/onan_starter_motors.htm
Also take a look at this and see if it helps.
http://rich.homeunix.com:443/gravely...l_Spec_A-J.pdf
__________________
Code:
                              Current Inventory
   24G (Onan 24hp)    24GLX - was 16G  (Onan 24hp)   8249 - was 8129 (Onan 24hp)
        818T (Onan 18hp B48)       8163T - was 8123 (Onan CCKA)
                              8183T (Onan B48)
   5665 w/brakes        5665        5660        Pro-8         Pro-16 w/brakes
For Gravely Manuals and more visit http://GTCOA.com
Richard-tx is offline   Reply With Quote Quick reply to this message
Old 01-06-2012, 12:16 PM   post #3 of 19
jepics
Gravely 408 Authority
jepics's Avatar
MTF Member # 26625
Images: 12
Garage
Can you post any photos?
__________________
John D
If you want to do what you want to do, you have to do what you have to do.
1945,1946 Cletrac AG-6 Crawler Tractors
1952 Ford 8N Sherman backhoe;Wagner FEL
1962 Gravely Model LI
1966 Gravely Commercial 10
1968 Jacobsen Chief 1000
1969,1972 Gravely Commercial 10A
Gravely 408's:
. 1973 w/ 34" Mower; rear weight box, snow plow
. 1973 w/ 34" Mower
. 1974 w/ 34" Mower; extended hitch
. 1977 w/ 34" Mower
1994 Gravely 18-G
jepics is online now   Reply With Quote Quick reply to this message
Old 01-06-2012, 12:54 PM   post #4 of 19
rlordjr
Old Iron Enthusiast
rlordjr's Avatar
MTF Member # 68685
Check out this item on eBay. I think AJ at oldforgepower had that motor on one or more machines he is parting out and might have the starter you need.
http://www.ebay.com/itm/Gravely-816-...-/220908569287
rlordjr is offline   Reply With Quote Quick reply to this message
Old 01-06-2012, 03:30 PM   post #5 of 19
danmack61
MTF Member
MTF Member # 19848
based on your link I think I might i.d. the right starter.I put on some pictures.I am still wondering if it is a starter problem or flywheel, but if I can get the correct starter that will tell me a lot-- thanks for the help
ID:	191841   Click image for larger version
ID:	191842   Click image for larger version
ID:	191843   Click image for larger version
Old 01-06-2012, 03:32 PM   post #6 of 19
danmack61
MTF Member
MTF Member # 19848
p.s The altrnator is a retrofit
Old 01-06-2012, 07:54 PM   post #7 of 19
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
That looks like a CCKA
Based on the pictures that starter is a 191-1052
Both dbelectric and pats has the starter.
http://www.dbelectrical.com/p-2867-n...8-smt0153.aspx
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Old 01-06-2012, 09:50 PM   post #8 of 19
boomers_influence
Proud Member of the 1K Club
MTF Member # 36155
dan, richard and club.
the CCK family of engines can be a nightmare,
when it comes to starting and charging systems
most of the starters were a two bolt style,
and used an adapter plate.
some later were a three bolt starter with no adapter.
i currently have a two bolt, with the adapter in stock.
dan,
if you walk up to the rear of your tractor., the engine tag should be on the left rear of your engine cowl.
this will tell us a lot.
thank you. boomer (the used onan engine parts guy)
boomers_influence is online now   Reply With Quote Quick reply to this message
Old 01-07-2012, 05:01 AM   post #9 of 19
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
The ring gear on the flywheel should be easy to inspect. If I recall correctly there will be two spots where there is the most wear.
If I recall correctly, the CCKA starters are somewhat of a loose fit and have to be moved around an the mounting bolts to get the pinion gear to engage the ring gear correctly. I believe this is mentioned in the service manual.
CCKA charging systems are no problem for me. If the regulator is bad. I just install a generic Kohler remotely. If the stator is bad, I either replace it or rewind the bad pole(s).
Richard - Have Glyptal - Will Travel
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Old 01-07-2012, 10:01 AM   post #10 of 19
danmack61
MTF Member
MTF Member # 19848
thanks for the reply's . Boomer I am not sure about the adapter plate for starter. maybe I am missing something.Mine is a 2 bolt but no adapter
Old 01-07-2012, 10:48 AM   post #11 of 19
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
What are the symptoms that you are experiencing?
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Old 01-07-2012, 12:15 PM   post #12 of 19
danmack61
MTF Member
MTF Member # 19848
original stated grinding noise when engaging and finally nothing.I bought a replacement starter from e-bay and though it also was grinding .it did turn and eventually start, but after a few starts it also burnt out. It seems not to mesh with the flywheel, and I have tried different spaces and different positions but it won't engage correctly. I have ordered a new one ( 191-1052 } and hope that this is the correct one. If not I may have look at the flywheel a little closer,though it looks to be ok. Thanks -- Dan
Old 01-07-2012, 01:21 PM   post #13 of 19
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
If I recall correctly the starter can be shifted around a little due to the oversize mounting bolt holes. Finding the correct position requires a little fiddling. It doesn't take much to get the starter into a bind. If there a mounting plate that bolts to the engine, I would examine that closely for evidence that it had been removed/moved at some point in time in the past.
Those starters are sort of like the old two bolt GM starters. A replacement GM starter usually came with shims and instructions.
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Old 01-07-2012, 05:03 PM   post #14 of 19
danmack61
MTF Member
MTF Member # 19848
i'm not giving up. I will let you know how the new starter works out when I get it and install it. Thanks for the tips
Sponsored Links
Advertisement
Old 03-07-2012, 03:35 PM   post #15 of 19
Jimmy in NC
Old Iron Connoisseur
Jimmy in NC's Avatar
MTF Member # 36741
Richard-
Working on a CCKA right now and looking for a remote regulator to use. Any pictures of the styles you have used and suggestions? Do the stators produce enough current to make 20A or is a 15A regulator enough to utilize all that is available. I'm sure 15A is enough for what a Gravely pulls with lights and to charge but if you are buying new, and the stator will make 20A...
__________________
WANTED:
Time to finish all my tractor projects!
My name is Jimmy and I have G.A.S.
Click for an explanation if you need it....
Gravely 816s, 8182-T (Going back to 8183-T soon!), 526, Lots of "L"
Round Fender John Deere 110
Jimmy in NC is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
