2404 with 2000 loader - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 12-31-2011, 04:04 PM   post #1 of 12
Texas_T
MTF Junior Poster
MTF Member # 68478
Default 2404 with 2000 loader
Hello everyone! Well I just brought home my grandfather's 2404. He has owned it since the early 70's. He bought it from the construction crew that actually built the High School in Hempstead, TX in 1972. It's the high school that I graduated from in 1992. He purchased it to be used on his property in Franklin, TX. Where it served a hard well used life. It hasn't been used in about the last 8 or 9 years though, since he bought another tractor.
Now I'm the proud owner for a price tag of $600. I would like to find a good service/parts manual and restore it to a good working state.
Texas_T is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 12-31-2011, 06:42 PM   post #2 of 12
buba
MTF MEMBER
buba's Avatar
MTF Member # 35637
Images: 2
Garage
Default Re: 2404 with 2000 loader
I&T shop manuals are always what i have used they give good info on how to fix and overhaul basically everything on the tractor and they don't cost a arm and a leg to buy ether hear is the one you are looking for
http://www.clymer.com/Book.aspx?bid=...+Manual+IH-201
__________________
you can never have too many antiques but finding the time and money to restore them that is a problem
buba is offline   Reply With Quote Quick reply to this message
Old 01-03-2012, 03:21 PM   post #3 of 12
Texas_T
MTF Junior Poster
MTF Member # 68478
Thanks for the link Bubba.
OK I have removed fuel tank and cleaned it out, removed and cleaned fuel separator, changed plugs and wires, replaced battery cables and bought new battery. I also filled loader reservoir, and transmission with hydraulic fluid. I got it to crank and I have problem with the number one cylinder on the exhaust valve. When i have plug installed and plug on it is trying to fire back through the carburetor, with plug wire disconnected it still pops back. So just for test purposes i removed plug and fired it up. Motor is running smoother even though only on three cylinders. The front PTO pump is leaking, and the rear axle seal is leaking on the left side. When trying to move tractor it barely wants to move and the power steering and three point hook up doesn't want to work.
So it seems I may have a longer uphill battle than I had planned on with this project.
Any suggestions are welcome.
__________________
IH 2404 with 2000 loader --->http://www.mytractorforum.com/showthread.php?t=221157
61 IH 404 -- Salvage find
90 Hesston 45-66 -- burn victim
Old 01-08-2012, 01:22 PM   post #4 of 12
Texas_T
MTF Junior Poster
MTF Member # 68478
Well here is a picture of it in my shop.
After removing the valve cover I realized that it's a miracle this thing even cranks. Also I thought it was running on three cylinders, when actually it is only running on one. The #2 cylinder was the only one that the pushrods were still in place. Also the amount of rust I found has me wondering if my oil pump is still functioning.
I'm gonna vacuum the rust out and clean the rocker assembly, straighten push rods and reset them. Then see if how it runs. I'm thinking if I remove oil filter and crank for just a few seconds to see if oil pump is working, before removing oil pan for further inspection.
Does anyone know the actual oil path for these engines?
I'm assuming that after oil pump picks up oil it goes through filter, crank, then cam and lifters, then up to valvetrain, then gravity feed back to oil pan.
__________________
Old 01-08-2012, 10:05 PM   post #5 of 12
Onan18
2000 Posts and climbing!!!
Onan18's Avatar
MTF Member # 40653
Not sure about the oil path but WOW, that thing actually ran?! If I were you after I removed the rocker shaft assembly I would drain the oil and then fill the crankcase with diesel and let it sit for a few days. also, I would put the rocker shaft assembly and push-rods in a pan and soak them in diesel as well. Te oil pumps on those old IH's almost never fail, but it almost looks like that thing was underwater at one point.
Joe
Onan18 is online now   Reply With Quote Quick reply to this message
Old 01-10-2012, 04:57 PM   post #6 of 12
met828
Senior MTF Member
met828's Avatar
MTF Member # 35689
Garage
maybe it is a katrina tractor that just goes to show you they don't make em like they use to
__________________
just cause you look dumb don't mean your not
met828 is offline   Reply With Quote Quick reply to this message
Old 02-19-2012, 05:27 PM   post #7 of 12
Texas_T
MTF Junior Poster
MTF Member # 68478
Well after further clean up what I thought was rust, I believe was or is paraffin from probably running the cheapest oil or whatever was available. After several days of soaking the valve train and lightly tapping on springs and lifters, and straightening push rods, I have this thing running on all 4 cylinders believe it or not.
Still having a problem with the shuttle shift switching from forward to reverse. Also having problem with main hydraulics not working.
__________________
Old 02-27-2012, 01:52 PM   post #8 of 12
Texas_T
MTF Junior Poster
MTF Member # 68478
Does anyone know if there are two hydraulic pumps? There is one up front that is gear driven by the motor right below the distributor. I am just wandering if there is another in the rear housing.
__________________
Old 02-27-2012, 10:50 PM   post #9 of 12
DJ54
Senior MTF Member
MTF Member # 69712
IH shows the type like you described, either a 4.5 gpm, or, 9 gpm. Then one that is driven off the front of crankshaft, via pto shaft. All were either Thompson, or Cessna.
DJ54 is online now   Reply With Quote Quick reply to this message
Old 02-28-2012, 08:47 AM   post #10 of 12
Texas_T
MTF Junior Poster
MTF Member # 68478
Thanks DJ54.
Yes it does have the front pump run off of the crank pulley via pto shaft which is an independent unit for the front loader.
I'm trying to troubleshoot the main hydraulics for the thrid point and power steering.
I need to go ahead and order a shop manual that buba give me a link to earlier, but just being the oh i can probably figure it out idiot.
__________________
Old 02-29-2012, 03:21 PM   post #11 of 12
IronLion
MTF Junior Poster
MTF Member # 70250
Be careful with all the crud on the top end. The shop vac would be a better tool than a blow gun. After you clean the top, depending on what the crud is, you may want to drop the oil pan and flush out any crud that lodged on the crank, etc.
IronLion is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-29-2012, 04:01 PM   post #12 of 12
Mike.ASC
Mike.ASC's Avatar
MTF Member # 39049
Looks to me like your missing some rocker arms ...?
Mike
Mike.ASC is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
