Need help with a HUSKEE Supreme LT - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-16-2006, 10:43 PM   post #1 of 36
Wild Bill 83
Proud Member of the 1K Club
MTF Member # 455
Images: 3
Default Need help with a HUSKEE Supreme LT
Yesterday I aquired a HUSKEE Supreme LT. The unit is less than 5 years old, runs and looks great!
However, there is a cable that is loose at one end....it is mounted on the right side of the deck....NOTE: in the pic I have simply 'hooked' the loose end of the cable onto a cotter key. The RR corner of the bracket that attaches the mower deck to the tractor, had a weld break....the PO tried to fix it, but it didn't hold....so I need to fix that again.
Could anyone please help me with how this cable is to be properly installed? Thanks in advance The tractor came with absolutely no manuals!
Here are some more pictures of it................
__________________
Cub Cadet: Plowin' the competition under since 1961
Wild Bill 83 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-16-2006, 11:53 PM   post #2 of 36
systech1
Senior MTF Member
MTF Member # 1395
Default Re: Need help with a HUSKEE Supreme LT
Not sure where it goes or if it even belongs.
For an owners manual try going here http://manuals.mtdproducts.com/mtd/public/list.jsp
The model number should be under the seat.
You can check here for a Illustrated parts list.
http://mtd.arinet.com/scripts/Empart...n%20&LoginPWD=
systech1 is offline   Reply With Quote Quick reply to this message
Old 04-17-2006, 09:27 AM   post #3 of 36
AlbanyBob
AlbanyBob's Avatar
MTF Member # 104
That cable is a lift cable for the deck. It should go up around a small plastic idler pulley right above it and then hook to the lift arm. Believe me when i tell yo uit is a pain in the A** to get it there too. But with some patientence and a littel luck you can do it.
Bob
__________________
http://ravine.no-ip.com/Directory/Bob/Bob's%20Stuff.html
AlbanyBob is offline   Reply With Quote Quick reply to this message
Old 04-17-2006, 09:30 AM   post #4 of 36
AlbanyBob
AlbanyBob's Avatar
MTF Member # 104
well now that i look at that picture again it may or may not be the lift cable for the right side of the deck. If the deck picks up even it is not. I am now thinking it may be the engage cable for the deck. Which would go to the end of the handle you move to engage the deck. Look under the frame for the arm that move off the handle on the dash. there should be a small pin there. It is only held on with a small washer and hair pin clip.
Bob
__________________
Old 04-17-2006, 07:34 PM   post #5 of 36
Wild Bill 83
MTF Member # 455
Images: 3
Thumbs up Re: Need help with a HUSKEE Supreme LT
Thanks guys!!
I'll research the model number, and check out the way the deck is engaged....and let you know what I find....
This tractor is a lot different than an IH Cub Cadet!!
__________________
Old 04-17-2006, 11:15 PM   post #6 of 36
Wild Bill 83
MTF Member # 455
Images: 3
I found the model and serial number under the seat, just like you said systech1...but by the time I got to checking it out, it was dark...AlbanyBob, tomorrow evening, I'll check out that cable again.
Guys!
The Model # is 13AJ608H131 which makes it a 2002 model year....the deck is a 46", so..............here is the parts break down:
The cable I'm dealing with, is part #50, which is PN 746-1107 Bracket Cable, 12"
__________________
Old 04-30-2006, 09:12 PM   post #7 of 36
Wild Bill 83
MTF Member # 455
Images: 3
The HUSKEE is in the garage, and ready for some 'fixin'
The deck will be repaired, remove blades, clean the underside of the deck, apply graphite 'slick paint', sharpen and reinstall the blades...then clean the top of the deck with Meguire's medium cut cleaner, then wax the deck. Also, the 21hp B&S will get a new fuel filter, air filter, spark plugs, and an oil change. The tractor itself will recieve a good cleaning with the Meguire's also, and will be waxed too.
I'll post some pics of the work in progress.
__________________
Old 05-10-2006, 08:21 PM   post #8 of 36
Wild Bill 83
MTF Member # 455
Images: 3
Here are some pics of the fune we had with the HUSKEE:
Here she is, in the garage, and deckless......
We tried to 'go through' the mower to make sure that all was well......it steers much better now that it has 1/4" toe in instead of 1/2" toe out!!
We had to remove the bodywork to properly get to the engine
The engine recieved a oil change with 10w-30 synthetic Valvoline oil, new oil filter, air filter, spark plugs, fuel line, fuel filter, and the air filter pre-cleaner washed out, and re-oiled.
Saturday after I got home from work, we lit into it again...we replaced the upper and lower drive belts, on the tractor, and started in on the deck...
As you can see, it had been a while since the deck had been cleaned out!!
and just as long since the blades had been sharpened...
yes folks, that is the cutting edge..........
__________________
Old 05-10-2006, 08:34 PM   post #9 of 36
Wild Bill 83
MTF Member # 455
Images: 3
My son got the deck cleaned out, then I ground off the old/broken weld on the deck hanger, and reattached it, she is on there to stay now
After it had cooled, and the reattched bracket area was painted and dry, Brandon went to cleaning the deck with the Meguires Meduim Cut Cleaner, then waxed the deck.
Once the deck was waxed, I installed the sharpened blades, and the deck was reattached to the tractor, and we hooked up the new PTO belt.
Then we touched up the wax on the tractor, and got the Armor-All in action.
Sunday afternoon I leveled the deck, and pushed it outside for these pictures....
The final results:
It barely turns over before it starts, and has PLENTY of power for the 46" cut deck
Not too bad for a 'free' mower
__________________
Old 05-10-2006, 08:43 PM   post #10 of 36
Wild Bill 83
MTF Member # 455
Images: 3
Now for the ONLY issue that I'm having.......................................
This mower has a manual PTO.....and it won't stay engaged!
The handle seems to easily slip backwards...like there is no friction, resistance, etc. at all!!!! To mow, I had to -hold- the PTO lever forward!
I have downloaded the Owners Manual, and the Parts Manual for the tractor....but I don't see in them what 'holds' the PTO in the engaged position....spring, friction, detent notch...??
Could someone help me out on this PTO deal.....** please**
Thanks!
__________________
Old 05-10-2006, 08:46 PM   post #11 of 36
jdkubotamurray
Guru on the Mountain
jdkubotamurray's Avatar
MTF Member # 147
Great Job!
jdkubotamurray is offline   Reply With Quote Quick reply to this message
Old 05-10-2006, 09:26 PM   post #12 of 36
Wild Bill 83
MTF Member # 455
Images: 3
Thanks!
Once I get this PTO handle deal fixed it will be pretty much in A-1 shape!
__________________
Old 05-13-2006, 03:33 PM   post #13 of 36
Tvern13
Senior MTF Member
Tvern13's Avatar
MTF Member # 385
Images: 1
Wild Bill,
I missed this when it was posted sorry or I could have helped you with the blade brake cable. My MTD has the same 46" deck. As you've probably already figured out the other end attaches to the PTO idler bracket so that when you engage the PTO it pulls the brake away from the pulley. The manual PTO on mine stays once engaged feels like its spring loaded but I've never really checked it out. You may want to take a good look at the PTO idler bracket underneath for a missing spring. Wish I could help more but I'm away at work and can't take a look at mine right now. Nice job though she's looking good
__________________
The little red tractor(s) that could!!!
OOPs - How did that cub get in here!!!
Cub Cadet GT2100 23 HP Kohler
54" Fabricated deck
Rear Bagger
Yanmar 1610D
Koyker 80 FEL
4' Box blade
Yanmar RSB1401 Tiller
Howse PHD
Howse middle buster
MTD Pro 25 HP Garden tractor
46" mower deck
Rear bagger
Johnny Bucket
Weight box
17 cu. ft. Brinley dump cart
Tow behind sprayer
Tvern13 is offline   Reply With Quote Quick reply to this message
Old 05-14-2006, 08:08 PM   post #14 of 36
Wild Bill 83
MTF Member # 455
Images: 3
Talking Re: Need help with a HUSKEE Supreme LT
No problem Tvern! I PM'd 'Neil', and he told me about the cable being part of a brake for the mower spindles. That's all hooked up, and operational now...and that's part of the reason the deck won't stay engaged...
I have downloaded the operators, and parts manual for the tractor from the MTD site, but neither is of the 'quality' I'm used to...
I studied the parts manual, but can't see any type of 'anything' that keeps the handle in the 'engage' position.
I stopped at a repair shop yesterday, and the tractor is headed there Monday eve. to get 'buttoned up'
As usual, Brandon did a good job cleaning up the HUSKEE. My dad has laid claim to it, so now I need to move the seat back...LOL....Dad is 6' tall, and he is pretty cramped!
__________________
Sponsored Links
Advertisement
Old 05-14-2006, 08:36 PM   post #15 of 36
Tvern13
Senior MTF Member
Tvern13's Avatar
MTF Member # 385
Images: 1
Wild Bill,
Let us know when they sort it out what it was just for future reference in case I ever have the same problem
__________________
54" Fabricated deck
Rear Bagger
Yanmar 1610D
Koyker 80 FEL
4' Box blade
Howse PHD
Howse middle buster
46" mower deck
Rear bagger
Johnny Bucket
Weight box
Tow behind sprayer
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
