My snow plow issues - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-16-2011, 11:16 PM   post #1 of 36
rbark3020
MTF Member
rbark3020's Avatar
MTF Member # 54400
Images: 9
Garage
Default My snow plow issues
I just bought a plow for my 16G this year and I repainted it, not the right color. I will remedy this at a future date. To all you Gravely enthusiasts with the rider snow plow, can I drill two new holes in the middle plow braces to get more ground clearance. I have a steep driveway where it meets the street and need a couple of more inches (No laughing) of lift.
__________________
RBark3020
rbark3020 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-17-2011, 09:32 AM   post #2 of 36
ATLANTICCENTRAL
2000 Posts and climbing!!!
MTF Member # 60860
Default Re: My snow plow issues
Do you have a manual lift or hydraulic? Is it currently lifting up until it hits the front axle?
Rasing the plow on the frame as you suggect is an intersting idea, not sure how that might work out. I will take a look at mine and give you my thoughts.
Sheldon
ATLANTICCENTRAL is online now   Reply With Quote Quick reply to this message
Old 11-17-2011, 09:46 AM   post #3 of 36
Fla Don
Gravely bug bit.
MTF Member # 33720
You don't want to raise the rear or middle of the plow frame. You actually would need to lower the rear to get the blade higher. The closer the frame is to tractor chassis, the less lift you will get. Or are you talking about just moving the blade itself up?
__________________
Current L/C count = 38.
Fla Don is online now   Reply With Quote Quick reply to this message
Old 11-17-2011, 02:44 PM   post #4 of 36
RedRider8179KT
Senior MTF Member
RedRider8179KT's Avatar
MTF Member # 55519
Lack of blade ground clearance with the plow in the up position is one of the biggest (and most obvious) design flaws of the Gravely rider, IMO. With all the experience we have on this site maybe someone has come up with, or has seen a practical solution? I'd love to see it if it's out there!
RedRider8179KT is offline   Reply With Quote Quick reply to this message
Old 11-17-2011, 04:54 PM   post #5 of 36
yamato72
3K Poster!!!!
yamato72's Avatar
MTF Member # 14161
Images: 10
Garage
...back up the hill instead.
With the factory setup you will only be able to raise the blade until the frame contacts the underside of the front axle.
__________________
Gravely 18-G * 50" MMM * 48" Snow Blade / Gravely 816 Project * 30" Tiller * 48" Blower / Custom Trailer
yamato72 is online now   Reply With Quote Quick reply to this message
Old 11-17-2011, 05:11 PM   post #6 of 36
ATLANTICCENTRAL
MTF Member # 60860
Quote:
It's only a design flaw if you have a hill with a steep angle of attack, but that can be a problem for a lot of automobiles as well.
Relocating the plow on the existing frame might gain an inch, not much more, and has a number of issues to overcome.
Designing a set of offset axle brackets could maybe gain an inch.
No matter how steep a grade is, it is always better to transition into it rather than having an abrupt angle - I might consider some driveway improvements if it was mine.
Sheldon
Old 11-17-2011, 11:31 PM   post #7 of 36
rbark3020
MTF Member
rbark3020's Avatar
MTF Member # 54400
Images: 9
Garage
Fla Don, that is exactly what I'm talking about. If you look at the large pin that runs through the two holes in the blade supports. If my theory is correct I can drill two identical holes approx. 2-3 inches lower (not looking at plow now) and this will give me that much clearance off the ground. It appears that the stop will still hit the reinforced plate on the back of the blade. I will try to take pics tomorrow to show you guys what I mean. I really don't want to start drilling if you guys can think of a reason this won't work that I have not thought of.
__________________
RBark3020
Old 11-18-2011, 12:00 AM   post #8 of 36
Richard-tx
5000 Strong & Climbing
Richard-tx's Avatar
MTF Member # 51208
Images: 7
The only things I can think that might give you a problem is that it may render the snow blade safety springs useless and making sure the plow will go low enough when you are done.
__________________
Code:
                              Current Inventory
   24G (Onan 24hp)    24GLX - was 16G  (Onan 24hp)   8249 - was 8129 (Onan 24hp)
        818T (Onan 18hp B48)       8163T - was 8123 (Onan CCKA)
                              8183T (Onan B48)
   5665 w/brakes        5665        5660        Pro-8         Pro-16 w/brakes
For Gravely Manuals and more visit http://GTCOA.com
Richard-tx is online now   Reply With Quote Quick reply to this message
Old 11-18-2011, 12:27 AM   post #9 of 36
rbark3020
MTF Member
rbark3020's Avatar
MTF Member # 54400
Images: 9
Garage
I did think about the springs and I may have to add longer bolts but I believe that due to the angle of the frame, it won't change the lift attachment by too much.
__________________
RBark3020
Old 11-18-2011, 05:14 PM   post #10 of 36
RedRider8179KT
Senior MTF Member
MTF Member # 55519
You could put larger diameter wheels and tires on the front.
Old 11-18-2011, 05:45 PM   post #11 of 36
CADplans
CADplans's Avatar
MTF Member # 66233
We need photos!!!
I was at the local tractor dealer Wednesday, they had a Kubota blade, very similar to the Gravely one I have that I do not know what it fits.
ANYWAY, the Kubota frame is bent about 18" from the blade!!
This causes the frame to be close to the ground at that bend point when the blade is down, but gives much more lift height.
CADplans is online now   Reply With Quote Quick reply to this message
Old 11-18-2011, 08:35 PM   post #12 of 36
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
20" tires are available....no need to change the wheels. Carlisle Turfmasters come in a 20x8-8.
A 2 ply Turfmaster 18x6.50-8 has an OD of 17.2"
A 2 ply 20x8-8 has an OD of 19.1"
That will net nearly one additional inch of clearance.
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Old 11-18-2011, 08:40 PM   post #13 of 36
CADplans
CADplans's Avatar
MTF Member # 66233
Quote:
2" radius increase at the tires, 3" increase at the blade!! Sounds good!!
Old 11-18-2011, 08:42 PM   post #14 of 36
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
Here are the tire specs.
http://www.carlisletire.com/products...ver/index.html
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Sponsored Links
Advertisement
Old 11-18-2011, 09:23 PM   post #15 of 36
Jimmy in NC
Old Iron Connoisseur
Jimmy in NC's Avatar
MTF Member # 36741
If I remember correctly you are not mowing with this tractor correct? I do not think that 20" tires will clear the front of a mower, even on a long frame. I know that 18" will not clear on a short frame.
Anyone with a long frame want to chime in???
__________________
WANTED:
Time to finish all my tractor projects!
My name is Jimmy and I have G.A.S.
Click for an explanation if you need it....
Gravely 816s, 8182-T (Going back to 8183-T soon!), 526, Lots of "L"
Round Fender John Deere 110
Jimmy in NC is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
