| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
| Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do.... |
Thread Tools | Display Modes |
#1 |
MTF Member
MTF Member # 30245
built a log splitter for a buddy. twin 18hp briggs for the engine. 13.6 3200 psi for the pump. and a 4.5 in trunnion mount cylinder. 8 in H beam chevy caviler axle. fabricated tank to match size of beam.
__________________
Case project |
| Sponsored Links | |||
Advertisement | |||
#2 |
MTF Member
MTF Member # 30245
__________________
Case project |
#3 |
MTF Member
MTF Member # 30245
__________________
Case project |
#4 |
MTF Member
MTF Member # 30245
__________________
Case project |
#5 |
5000 Strong & Climbing
![]() ![]() Join Date: Jun 2009
MTF Member # 28463
That's a nice 25 ton splitter. It should stand up well and turn a lot of big wood into little wood.
Is you buddy on the firewood business, or is just for his own use?
__________________
Bob ![]() Click for The Hydraulics Forum! Sometimes you get on a roll, sometimes the roll gets on you. In Service MF GC2310, Husqvarna YTH20B42T Down for Repairs MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H Spending too much time on MTF to work on my toys.
#7 |
MTF Member
MTF Member # 30245
just his own use. 18 hp was way over kill but on the bright side u can split at an idle.
__________________
Case project |
#8 |
3K Poster!!!!
![]() Join Date: Apr 2009
MTF Member # 25367
Not necessarily. I had a Huss "Honest Abe" 24 ton splitter (1980) that was 16 HP. It wore out two cast iron Briggs engines and was into its third engine (a V-twin Vanguard) when I sold it.
#9 | |
MTF Member # 28463
Quote:
Splitting wood is a lot less work for an engine than snowblowing. It's quite literally only occassionally a few seconds per minute at maximum load with a well designed hydraulic system.
__________________
#10 | |
GANG GREEN GIZMOW KILLER!
MTF Member # 41447
Quote:
I have a Cheapie 20 ton splitter with only a 5hp briggs pos engine that has seen much use between our hunting cabin, my last house (2 cord/year) My current house (4 cord/year) My brother and neighbor who each do about a cord a year. It is about 12yrs old and admittedly it is getting a bit wheezy, but it still runs. I also never really go much past 2/3 throttle.
__________________
http://jd318techforum.proboards.com/index.cgi http://houseofhomelite.proboards.com/index.cgi? POWERKING "79" 2416 ECONOMY "64" JD KUBOTA 4200 "68" JD 140 H-3 And a restored JD318 |
#11 |
![]() ![]() Join Date: Apr 2005
MTF Member # 284
Nice job on the splitter
![]() Mine is set up sorta like your with the ram sliding on the beam. After 35 years (Guess) I just had to rebuild the slide from wear, the grit and dirt made it loose as a goose over the years and it started to twist off the bed when splitting twisted stuff.. and that caused the cylinder seal to start leaking. Now its better then new, and adjustable for when it wears down again. |
#12 | |
3K Poster!!!!
MTF Member # 25367
Quote:
| Sponsored Links | |
Advertisement |
#13 | |
MTF Member # 28463
Quote:
Not a poor system, just lots of work.
__________________
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
