Welding ring gear - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 11-04-2011, 01:40 PM   post #1 of 20
WI_Jeff
Senior MTF Member
WI_Jeff's Avatar
MTF Member # 64624
Default Welding ring gear
About 3 months ago, I changed the clutch in my 8N. While I was in there, I decided to change the ring gear as the one on there was starting to wear and someone had already pulled the "turning" trick. Last week, the starter would just spin. Simple minds think simple things. I checked out the starter and it was fine. Replaced the bendix with the new style. It still just turned free. After a little more investigation, I noticed that the ring gear is turning on the flywheel. DARN! I did notice that when I put the new ring gear on that when it "fell" on, after heating it was very loose when it bottomed out.
I may try to weld it in the tractor. That is if I can get the ground directly onto the flywheel. I don't want to "weld" any of the bearings together by grounding to any where else. Anyone have any ideas, I'm always open.
WI_Jeff is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-04-2011, 01:51 PM   post #2 of 20
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Default Re: Welding ring gear
Gotta be a better way than welding it on? IMO
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 11-04-2011, 01:59 PM   post #3 of 20
WI_Jeff
Senior MTF Member
WI_Jeff's Avatar
MTF Member # 64624
I'm open for suggestions.
Old 11-04-2011, 02:29 PM   post #4 of 20
monteman_73
Senior MTF Member
monteman_73's Avatar
MTF Member # 53585
I understand your concern for the bearings, but what I don't understand is if you have enough room to put a ring gear on, why wouldn't you have room for the ground cable for the welder?
monteman_73 is offline   Reply With Quote Quick reply to this message
Old 11-04-2011, 02:39 PM   post #5 of 20
CADplans
5000 Strong & Climbing
CADplans's Avatar
MTF Member # 66233
JB weld or Loctite gap sealer??
CADplans is offline   Reply With Quote Quick reply to this message
Old 11-04-2011, 02:43 PM   post #6 of 20
Tencubed
3K Poster!!!!
MTF Member # 31735
Never seen a ring gear welded on but don't see why it wouldn't work. Save tearing the tractor in half to replace the flywheel and ring gear again. If you just put some tack welds on it thru the starter mount hole you should be OK. I sure wouldn't get carried away with the welding and would tack one side, turn it 180 degrees, tack again and then turn 90 degrees. You get the idea. Four tacks about an inch long should do it.
Since the crank is bolted solid to the flywheel you should be able to ground the welder to the front of the crank and avoid any potential problems of arcing the bearing surfaces.
Worse case you end up pulling the flywheel again and grinding off the tack welds.
Just my opinion, never done it, hope I never have too.
Mike
__________________
A gun and a parachute are much the same. When you need one nothing else will really suffice.
Tencubed is offline   Reply With Quote Quick reply to this message
Old 11-04-2011, 03:46 PM   post #7 of 20
WI_Jeff
Senior MTF Member
WI_Jeff's Avatar
MTF Member # 64624
"I understand your concern for the bearings, but what I don't understand is if you have enough room to put a ring gear on, why wouldn't you have room for the ground cable for the welder?"
I have the tractor together and plan on welding through the starter hole.
"Four tacks about an inch long should do it."
Plan on the 4 tacks at 90 degrees to each other. The ring gear has 134 teeth. So, first tack at 0, second at 67, third at 33 1/2 and the last at 100 1/2 ( or close to that anyway LOL)
Old 11-04-2011, 04:22 PM   post #8 of 20
windowgoblin
Senior MTF Member
windowgoblin's Avatar
MTF Member # 47556
What about brazing or bronzing it on a few spots,won't hurt the bearings and easy to remove it you have too.
__________________
I have a rock garden. Last week three of them died.
my projects
1950 ford 8n
1967 gravely 430 commercial rider
198? Murray 18 twin with 3 point hitch and several attachments.
kEMP woodchipper.20?? lawn flite (for cottage yard)
1949 ford 8n
windowgoblin is offline   Reply With Quote Quick reply to this message
Old 11-04-2011, 05:22 PM   post #9 of 20
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
There have MAY a ring gear tack welded, just be sure to ground to the flywheel some way and then tack it in 3 or 4 places. it won't take much to hold it. Try to get them equal distance.
JohnW is offline   Reply With Quote Quick reply to this message
Old 11-05-2011, 04:10 PM   post #10 of 20
WI_Jeff
Senior MTF Member
WI_Jeff's Avatar
MTF Member # 64624
Whew Re: Welding ring gear
DONE! Welded through the starter hole. Four tacks about an inch long. Spaced at 33 and a half teeth apart. Grounded at the crank shaft. Needed a helper to hold the rig gear tight. Just used a pry-bar. WORKED GREAT. I though on this was that if the flywheel is messed up already, so, when a new ring gear is need the flywheel would have to be replaced anyway. It was fairly easy to do.
Thanks for all the input!
Old 11-05-2011, 08:50 PM   post #11 of 20
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
even if you are the one to change it next time, the welds can be ground off and use the flywheel again.
Old 11-06-2011, 11:42 AM   post #12 of 20
oldsarge
Senior MTF Member
oldsarge's Avatar
MTF Member # 32130
Tell us who you bought the crappy ring gear from.
oldsarge is offline   Reply With Quote Quick reply to this message
Old 11-06-2011, 11:23 PM   post #13 of 20
WI_Jeff
Senior MTF Member
WI_Jeff's Avatar
MTF Member # 64624
I got it from Steiner Tractor. When I did contact them, they said it was a "bad Fly Wheel".
Old 11-07-2011, 11:33 AM   post #14 of 20
oldsarge
Senior MTF Member
oldsarge's Avatar
MTF Member # 32130
Of course ,the flywheel has been bad for 60 years and the ring gear is a top of the line Chinese product!!
Sponsored Links
Advertisement
Old 11-07-2011, 05:59 PM   post #15 of 20
thenubsterman
Senior MTF Member
MTF Member # 63713
hey off topic but that is like the power steering pump i put on a tahoe the other day pulled the pulley off with the puller put the new pump on and went to put the pulley on the pump well it slid right on called the parts people and they treated me like i was dumb saying the pulley was too big, i said no when u measure the one shaft its 10 thou smaller then the pump i took off of it. then they proceeded to tell me i had to use their pulley, i guess they forgot i work on cars everyday of my life and their part was cra*. Basically chinese cra* sucks.
thenubsterman is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
