Hydro Trans for pulling? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
The Pulling Club Puller Builds and Discussions
Reply
Thread Tools Display Modes
Old 11-04-2011, 12:08 AM   post #1 of 28
DieselMower
Senior MTF Member
DieselMower's Avatar
MTF Member # 67176
Images: 2
Default Hydro Trans for pulling?
I found a JD 111 for $50 locally that has a lot of potential but has a hydrostatic trans. Has anyone used a hydro for pulling or would you be better off using a gearcase? Also can you upgrade a hydrostatic or mess with it any? Thanks
DieselMower is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-04-2011, 10:34 PM   post #2 of 28
ldunlap
MTF Member
ldunlap's Avatar
MTF Member # 7701
Default Re: Hydro Trans for pulling?
Nobody pulls with hydrostats in my area. I have seen on the internet where some guys in New York were pulling with cub hydros. They had said that you had to know how to work the hydro lever as you are going down the track. Good luck to you, pulling is a lot of fun.
ldunlap is offline   Reply With Quote Quick reply to this message
Old 11-06-2011, 08:36 PM   post #3 of 28
big jake
MTF Member
big jake's Avatar
MTF Member # 51536
I Pull a older Ford 145 hydro but the rear has a hi and low that works good.but it takes more motor to make them work. Jake
big jake is offline   Reply With Quote Quick reply to this message
Old 11-07-2011, 08:00 PM   post #4 of 28
DieselMower
Senior MTF Member
MTF Member # 67176
Images: 2
Nice puller big jake! Do you have built pics? Did it come factory with shaft drive or belt?
Old 11-07-2011, 08:07 PM   post #5 of 28
larrybl
5000 Strong & Climbing
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Quote:
Larrybl here, I can show the drive The LGT 145 has with pictures. It is a shaft drive to the Eaton Hydro Pump.
Name:	Deck Lift Ram.JPG
ID:	181950   Click image for larger version
ID:	181951   Click image for larger version
larrybl is online now   Reply With Quote Quick reply to this message
Old 11-07-2011, 08:18 PM   post #6 of 28
big jake
MTF Member
big jake's Avatar
MTF Member # 51536
Thanks for the help Larry. I didnt take any build pic. Jake
Old 11-07-2011, 09:13 PM   post #7 of 28
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
I like the rims on Poppa Smurf.
Old 11-13-2011, 08:21 PM   post #8 of 28
junkman1946
Senior MTF Member
junkman1946's Avatar
MTF Member # 37529
Rule of thumb for Cub Cadets: It takes 25% of the engines power just to turn the hydro. therefore you put yourself way down on power. I have seen limited success with C.C.s with bigger motors with hydros, but you have to be real good with the control handle.
junkman1946 is offline   Reply With Quote Quick reply to this message
Old 12-15-2011, 09:40 AM   post #9 of 28
wseternmd
Senior MTF Member
MTF Member # 68333
A quick question I am thinking of getting in the smaller side of pullin my family farm had a smoker series puller untill it got to expensive. anyhow I have an ingersoll 3018 with the onan engine and hydraulic drive I know it is strong enough but what about the hydro is there rules for that type of tranny and can you modify the pumps to be more efficient for the application.
wseternmd is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 12:51 AM   post #10 of 28
wseternmd
Senior MTF Member
MTF Member # 68333
still lookin for any comments on my ingersoll idea, if any one care to chime in
Old 01-18-2012, 02:55 AM   post #11 of 28
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
Hydraulic drives are even less efficient at transmitting power than hydrostatic drives. A good hydro is about 80% efficient, but a hydraulic drive with a gear pump and motor has to be in top shape to make 65% efficiency.
You can only increase the relief setting or turn the pump faster to get more power out. You have to have even more power from the engine to do that, though.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 07:18 AM   post #12 of 28
redmule
Proud Member of the 1K Club
redmule's Avatar
MTF Member # 51067
Lets see if I am understaning this. We have two tractors one is a JD 425 and the other is a case 4020. Because the JD has a hydrostatic drive it can pull or push more than a case with hydraulic drive if both tractors are the same in every other way.
redmule is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 08:38 AM   post #13 of 28
Weaverama
Senior MTF Member
Weaverama's Avatar
MTF Member # 8010
Quote:
Bob stated that a good hydrostatic pump is 80% efficient and a hydraulic drive with a gear pump is 65% efficient. If both tractors are the same in every other way as you stated (tire diameter, gearing, horsepower, rpms etc), one could expect to have more available power to the drive wheels with the hydrostatic driven tractor, hence, it will do more work.
You did mean "the same in every other way" didn't you?
__________________
______________________
1966 - 856 Wheel Horse
1976 - 1000 IH Cub Cadet (Sold)
1984 - 682 CCC Red Cub Cadet
1988 - 2072 Super Garden Tractor
1997 - 345 John Deere
1972 - 108 Cub Cadet (Sold)
1978 - 1650 Cub Cadet (Sold)
Weaverama is offline   Reply With Quote Quick reply to this message
Old 01-18-2012, 09:04 AM   post #14 of 28
redmule
redmule's Avatar
MTF Member # 51067
Yes Thank you
Sponsored Links
Advertisement
Old 01-18-2012, 08:21 PM   post #15 of 28
searstractorfan
Tractor hoarder/collector
searstractorfan's Avatar
MTF Member # 35836
Images: 5
Find a gear drive cub...u can buy the hydro tractors to rob parts from...Hydros might work good once or twice...but EVENTUALLY they burn up or wear out....If ur gonna spend the money..might as well build something to somewhat last..
__________________
1967 Sears Suburban 10, 1967 Custom 7, 1969 8Xl, (3) 1973 ST/16, (2)1973 SS/16, 1973 ST/10, 1974 SS/16, 1974 ST/16, 1976 ST12, 1977 SS/18, 1977 10/6, 1977 12/6, 1977 14/6, 1978 GT19.9. 1973-75(unknown year) Roper RT16T, 1978 or 79 Roper 18T. Craftsman Mowers: 196? Craftsman 6hp mower, 2 196? craftsman mowers. Various 82 series pullers 1973 IH Cub Low Boy, Cub Cadet 782, IH Cub Cadet 582 Special, IH Cub Cadet 582. 1972 Economy Jim Dandy, 1972 Economy. And an unknown Panzer, theirs more im sure.
searstractorfan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
