Honda GX340/390 Oil Drain - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-28-2011, 08:42 PM   #1
Torque454
Senior MTF Member
MTF Member # 50996
Default Honda GX340/390 Oil Drain
Hello I have a Honda GX390 and a GX340 both, mounted on a trailer floor and very difficult to remove. I need to change the oil on them but there is no way to remove the drain plug and drain the oil without it draining all over the trailer floor. On my Kohler and ALL my Briggs engines, I can use regular NPT pipe nipples to extend the oil drain out to where I can use it correctly, but on the hondas I believe the oil drains are 10MM. I am not aware of any place atleast around here that sells a 10mm pipe nipple and cap/plug. I have seen some of those quick drain things that extend the oil drain out for these things, but I dont think they are long enough.
What should I do? Or does anyone know where I can buy 10mm pipe?
Torque454 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-28-2011, 10:22 PM   #2
RED-85-Z51
Certified Technician
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Default Re: Honda GX340/390 Oil Drain
Easiest way is to use a simple hand oil pump. Take off the filler, put the straw in the sump, pump a few times to build vacuum and let it lift the oil, cleanly into the hopper...no mess, no fuss
__________________
Owner/Operator of Hagrens Lawnmower Service and Repair
Pensacola, FL
Visit our site!
http://hagrensmower.webs.com/
add us on facebook!
https://www.facebook.com/HagrensLawnmowerService
1993 Wheel Horse 416-H
Onan P216G
1962 WH702
1997 GMC Sierra C3500 Dually
454 Big Block "Vortec 7400"
4L80E
4.10 gears
1995 GMC Sierra K1500 Z71
350 TBI 4L60E
Lifted 3", 33" tires
True Duals/Thrush 3 chambers
3.42 gears
RED-85-Z51 is offline   Reply With Quote
Old 10-28-2011, 10:27 PM   #3
kb0nly
MTF Member # 66593
Go to Northern Tool, get the 10mm Drainzit...
http://www.northerntool.com/shop/too...1063_200311063
I put one on my Honda clone on my blower... Makes it nice and mess free.
If its not long enough its a standard automotive grade GoodYear rubber hose, you could easily cut and splice with some barbed fittings and more hose and make it whatever length you want.
kb0nly is offline   Reply With Quote
Old 10-29-2011, 12:37 PM   #4
rscurtis
3K Poster!!!!
MTF Member # 25367
I used a lot of them on my rental equipment right from brand new. If the oil is easy to change, you'll be more inclined to do it.
rscurtis is offline   Reply With Quote
Old 10-29-2011, 03:03 PM   #5
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
If the motors are mounted flush to the trailer floor, I dont think you can use a Quick drain type device. Could always put some washers under it though.
__________________
Pensacola, FL
Visit our site!
add us on facebook!
Onan P216G
1962 WH702
4L80E
4.10 gears
350 TBI 4L60E
3.42 gears
Old 10-29-2011, 05:48 PM   #6
rscurtis
3K Poster!!!!
MTF Member # 25367
They were installable on flush-mounted engines without removing the engine. That's one of the things that made them so attractive.
Old 10-29-2011, 07:19 PM   #7
RED-85-Z51
RED-85-Z51's Avatar
MTF Member # 2950
Images: 7
Personally I liked em, but I saw alot of blown engines from people not returning them to the closed position securely. And I never saw one on a flush mounted application I could get to to install. It was such a pain when Id short block an engine on a Z mower and forget to swap the drain and have to unbolt the engine, put a jack under the crank to lift it up a hair so I could spin on the ez drain.
__________________
Pensacola, FL
Visit our site!
add us on facebook!
Onan P216G
1962 WH702
4L80E
4.10 gears
350 TBI 4L60E
3.42 gears
Sponsored Links
Advertisement
Old 10-30-2011, 01:28 AM   #8
kb0nly
MTF Member # 66593
The Drainzit is not a quick drain with a valve or such... It has a threaded fitting on the end and a cap with an o-ring. I wouldn't put one of those quick drain valve type devices on i don't trust them, but i know some swear by them.
The Drainzit doesn't take any more room than the stock drain plug, so it can go on an engine that is flush mounted onto a surface. Just spin it in like a drain plug, i didn't need to move the engine on my snowblower just pulled the plug, drained the oil, cleaned up the mess, then spun in the Drainzit hose and done. No problemo!
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
