318 lock out valave - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-22-2011, 11:41 AM   post #1 of 31
blown67
Senior MTF Member
blown67's Avatar
MTF Member # 36477
Default 318 lock out valave
Is there any other suppliers for the valve than deere? I just priced it on their website and its over 90 bucks with tax....... I saw one on ebay for about half that, but was wondering if anyone had a part number that would work from a place like Mcmaster Carr or Surplus Center.
blown67 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-22-2011, 11:44 AM   post #2 of 31
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Default Re: 318 lock out valave
I got one from an EBay vendor for around $30 IIRC. Nothing special about it.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 12:34 PM   post #3 of 31
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I've also seen the aftermarket ones on eBay for around $30.00.
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 10-22-2011, 04:48 PM   post #4 of 31
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Quote:
Anyone have a link for these $30 ones? I keep seeing the one for about $43. Also, I need one for a 317. I'm assuming it would be the same?
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is online now   Reply With Quote Quick reply to this message
Old 10-22-2011, 06:27 PM   post #5 of 31
blown67
Senior MTF Member
blown67's Avatar
MTF Member # 36477
I was looking on the Mcaster Carr website and found these, rated for 2000 psi I think might do the trick. http://www.mcmaster.com/#flow-contro...valves/=eltn58 I think I can use one to do the flow control I need to slow down my angle cylinder and another to lockout the rockshaft, both together are cheaper than 1 on eBay and Mcaster Carr's stuff is usually very good quality.
Old 10-22-2011, 07:28 PM   post #6 of 31
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
ggsteve, went through eBay and could not find the cheaper one! The 42.99 is the cheapest one I see now!
__________________
Old 10-22-2011, 08:10 PM   post #7 of 31
ggsteve
ggsteve's Avatar
MTF Member # 9436
Garage
Yeah, that seems pretty reasonable, especially since it comes with the extra fitting that's probably $5 anyway. I'll probably rise to the bait on that one soon.
__________________
ggsteve
71 JD 140H1
72 JD 110 parts
86 JD 318 3pt
Old 10-22-2011, 08:16 PM   post #8 of 31
GotDeeres
Just John Deere
GotDeeres's Avatar
MTF Member # 35846
Images: 8
All you need is a 1/8" Parker Flow Control valve and a 1/8" Male to Female
45 degree adapter. I used to buy the valve from surplus center for less than $15.
Name:	Rear lockout Flow.JPG
GotDeeres
__________________
Just John Deere
318 Garden Tractor
345 Garden Tractor with Piranah Deck
425 Garden Tractor with 54C Deck
455 Diesel with 60" Deck, 3 Point and 540 PTO
455 Diesel with Buford Bucket Compact Loader
2210 CUT with Buford Bucket Compact Loader
John Deere TS Gator
GotDeeres is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 09:13 PM   post #9 of 31
blown67
Senior MTF Member
blown67's Avatar
MTF Member # 36477
I checked Surpluscenter and couldnt find one, http://www.surpluscenter.com/sort.as...c&keyword=HAFC I looked threw all the flow control valves they carry, any chance you have a part number for that valve?
Old 10-22-2011, 09:38 PM   post #10 of 31
GotDeeres
Just John Deere
GotDeeres's Avatar
MTF Member # 35846
Images: 8
Blown 67,
I have a couple in my shop. I will check the part number tomorrow. It is a Parker PF-200 I believe. Funny, but I can remember a part number, but keep forgetting my wife's name.
__________________
Just John Deere
318 Garden Tractor
John Deere TS Gator
Old 10-25-2011, 09:45 PM   post #11 of 31
blown67
Senior MTF Member
blown67's Avatar
MTF Member # 36477
Well I went ahead and ordered 2 from Mcaster Carr, they were 20.39 each, and are the same ones being sold on eBay for 42.99 except these are steel and the eBay ones are brass, and this comes from the manufacturer of the valve: "Brass valves are ideal for water and have a brass needle. Steel valves are ideal for hydraulic oil and have a stainless steel needle". I bought 2, one for my rockshaft and another to slow down my angle cylinder on the blade, but I should have looked closer, the misfit cylinder on my blade has 1/4" NPT and not 1/8' NPT like the original cylinders have so either I need a couple reducing fittings or I have a spare...
Old 10-26-2011, 03:27 PM   post #12 of 31
windcatcher
Senior MTF Member
MTF Member # 20354
Attachment 179395
GotDeeres
GotDeeres: how did you go about installing your remote shutoff valve? I have a JD 322 I'm wanting to install the valve on, and I'm having a problem with getting enough room to work with.
Mine is on so tight and there is so little room under there to get a long wrench on to work with.
I've decided to try a gas line wrench this weekend and see if that might help with the leverage. In between that time, I'm soaking the fitting with Seafoam Deep Creep, and I hope to put some freeze rust penetrant on the fitting this evening.
Any help would be greatly appreciated.
BTW, aux-hyd.com also has the remote shutoff valves for now. They even have the 1/4 turn valves - of which I purchased for my JD 322.
WC
__________________
__________________________________
In the shed:
1950 Farmall Cub
2000 Simplicity Landlord DLX w/ locking differential
1988 JD 322
"If you would fire a person for not showing up for work on a regular basis, then why don't you fire an invisible god for never showing up to work?"
windcatcher is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 04:50 PM   post #13 of 31
Dan33Klein
2000 Posts and climbing!!!
Dan33Klein's Avatar
MTF Member # 55503
[QUOTE=blown67;1918270]Well I went ahead and ordered 2 from Mcaster Carr, they were 20.39 each, and are the same ones being sold on eBay for 42.99 except these are steel and the eBay ones are brass, and this comes from the manufacturer of the valve: "Brass valves are ideal for water and have a brass needle. Steel valves are ideal for hydraulic oil and have a stainless steel needle". I bought 2, one for my rockshaft and another to slow down my angle cylinder on the blade, but I should have looked closer, the misfit cylinder on my blade has 1/4" NPT and not 1/8' NPT like the original cylinders have so either I need a couple reducing fittings or I have a spare...
WHY DO YOU WANT TO SLOW DOWN YOUR ANGLE CYLINDER?
__________________
2014 Kubota 2370-1
LA243 FEL
54" MMM
2000 John deere 455 Diesel. SOLD
Mini FEL
Ruegg Cat 1 Limited 3 Point hitch
60 Inch Commercial Deck
1987 John Deere 214 RESTORED. SOLD
37A Blower RESTORED
1979 John Deere 317 Briggs Re Power RESTORED. SOLD
54" 4 Way Hydraulic Plow RESTORED
http://www.mytractorforum.com/showthread.php?t=178233
http://www.mytractorforum.com/showthread.php?t=214280
Dan33Klein is offline   Reply With Quote Quick reply to this message
Old 10-26-2011, 05:24 PM   post #14 of 31
blown67
Senior MTF Member
blown67's Avatar
MTF Member # 36477
The angle cylinder that is on my blade is not an original setup, a previous owner put a smaller volume cylinder in place of the correct one, it will go from full angle to opposite full angle in less than 1 second flat, literally.
The flow control valves I bought are dual directional so I can dial down the flow to the cylinder to a speed that I am happy with.
And I may have jumped the gun saying the quality of Mcaster Carrs stuff, after I took the pic of the valve for this thread I saw the markings on the left hand side and looked at the threaded hole in the end and sure enough its oblong, but they are sending me a new one and are even giving me the bigger size I need for my misfit cylinder.
Sponsored Links
Advertisement
Old 10-26-2011, 05:37 PM   post #15 of 31
Dan33Klein
Dan33Klein's Avatar
MTF Member # 55503
I see now, id want the cylinder to go fast but not that fast, i am in the process of finding a lock cylinder for my 317 rockshaft so my blade angles faster. it goes slow for a second that speeds up. the 317 cylinder is hard to get to unlike the 318. so i believe it will be harder to rig up. im gonna swing by a hydro shop after work in a bit and see what they have, is the fittings off our rockshaft cylinders 1/4 or 3/8?
__________________
2014 Kubota 2370-1
LA243 FEL
54" MMM
Mini FEL
37A Blower RESTORED
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
