k321 hard to start in cold weather - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 10-19-2011, 08:36 PM   post #1 of 13
jas11964
Still plays with tractors
jas11964's Avatar
MTF Member # 8340
Default k321 hard to start in cold weather
I have a tractor that has a k321 14hp kohler. The first few years I owned it (6 to 8 years ago I got it), I just hit the key and it ran. Now, when the weather turns cold, it just cranks and cranks and, unless I put a small heater on it for a while, it won't start. In warm weather it starts up like it always did. Could this be an ethanol thing? It cranks strong so the battery is not in question.
__________________
I said I work on them; I never said I fix them!
Jeff
http://picasaweb.google.com/jas11964
1983 Power King 2414
1981 Power King 1614 w/FEL
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
1972 Wheelhorse Raider 14
1977 Wheelhorse B100 8 Speed
1961 Wagner Little Giant
1942 Speedex Model B
2003 Wheelhorse Classic 315-8
jas11964 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-19-2011, 08:38 PM   post #2 of 13
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
Default Re: k321 hard to start in cold weather
Did you check to see if the choke is closing all the way inside the carb ???
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 09:34 PM   post #3 of 13
jas11964
jas11964's Avatar
MTF Member # 8340
Quote:
You know, I haven't. The cable is pretty hard to pull so maybe it's hanging up in there. So simple I blew right by it. Thanks Kevin, I'll look tomorrow and see what's what.
__________________
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
Old 10-19-2011, 09:41 PM   post #4 of 13
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
I had the same problem (12 HP Kohler) and replaced a spark plug to coil wire and that solved my issue.
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 10-19-2011, 09:49 PM   post #5 of 13
jas11964
jas11964's Avatar
MTF Member # 8340
Quote:
Sounds like that will be step 2 then. Thanks.
__________________
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
Old 10-19-2011, 09:55 PM   post #6 of 13
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
The old wire was "leaking" electric really bad I inadvertently touched it while the engine was running and got lit like a Christmas tree! That is what told me it was time for a new one!
__________________
Old 10-19-2011, 10:35 PM   post #7 of 13
Walt 2002
Senior MTF Poster
MTF Member # 1229
Do the Cheap things first, check choke.
Walt Conner
Walt 2002 is online now   Reply With Quote Quick reply to this message
Old 10-19-2011, 10:38 PM   post #8 of 13
larrybl
5000 Strong & Climbing
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
New choak cable can be located at Tractor Supply for $12.99, Aske me how I know
larrybl is online now   Reply With Quote Quick reply to this message
Old 10-20-2011, 10:18 AM   post #9 of 13
jas11964
jas11964's Avatar
MTF Member # 8340
It's chilly here this morning (low 40's) which was the perfect time to try this choke thing. I went out to the shop, took the air cleaner cover off and worked the choke a little. It looked as though it was closing all the way but it wasn't quite getting there and the cable was pulling very hard. I took my finger and closed it the rest of the way then did a cold start. It cranked once and it was running at an idle. I guess it doesn't have to be open much to make a difference. I hope to get a new choke cable at lunch time today and I think I will go ahead and replace the plug to coil wire while I'm at it. Can't hurt and, if anything, I'll have a spare. I'll report back when all this is done and I'll either have good news or more questions. Probably won't get to it until the weekend. Thanks guys.
__________________
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
Old 10-20-2011, 08:55 PM   post #10 of 13
jas11964
jas11964's Avatar
MTF Member # 8340
Looks like we have a winner. I put the new choke cable on tonight along with a new wire from the plug to the coil. As it turns out, I didn't have to do the wire but, what the heck, winter is coming so it's better now than when I need it. Fired right up. I moved it out to the barn and will give it another go int he morning just to be sure but I think we're good to go. Thanks everyone! These simple little things can really get you sometimes.
__________________
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
Old 11-18-2011, 11:41 AM   post #11 of 13
jas11964
jas11964's Avatar
MTF Member # 8340
Well I thought it was fixed. I tried to start this thing yesterday and it cranked and cranked and then back fired. After that, it started and ran fine. I'm starting to think I need a carb rebuild. How much play around the throttle shaft is considered too much?
__________________
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
Old 11-18-2011, 09:24 PM   post #12 of 13
larrybl
larrybl's Avatar
MTF Member # 37470
Images: 32
Garage
Quote:
There should be no play, I had several, B/S and my K321, Makes starting hard, and you can't get to idle right. I was able to locate a brass bushing at T/S and dremel it to replace the old one.it fit in the recesed part on the carb. I heard some don't have this recess. Then a new throttle shaft should fix it.
ID:	183642   Click image for larger version
Sponsored Links
Advertisement
Old 11-19-2011, 12:43 AM   post #13 of 13
jas11964
jas11964's Avatar
MTF Member # 8340
I do believe this to be my problem. Thanks larrybl!
__________________
Jeff
1973 Economy 14hp
1977 Satoh Beaver
1954 Pond
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
