My Wheel Horse 212-5 restoration attempt - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 10-18-2011, 11:49 PM   post #1 of 15
SkyFive
MTF Junior Poster
MTF Member # 65216
Images: 3
Default My WheelHorse 212-5 restoration attempt
Well...here goes, this is how it looked when I bought it three or four weeks ago for $70. It had been sitting a "couple of years", covered I believe. I bought it from a man in Ellenboro, NC that worked on mowers, mostly Deere John's I think from the look of his shop.
I have my work cut out for me on the hood. I think it was used as a battering ram.
It was a little rusty but, no rust thru. I evaluated the engine and transaxle operation before I made a decision to restore it. The engine ran really good after a carburetor cleaning, just a hint of blue smoke on start up. the transaxle operated fine but I later found a loose axle on disassembly, I was not deterred.
The axle is fixed with bearings. I sealed the case with Threebond, the same stuff I sealed my motorcycle case with. It works great and no leaks. I filled it with 80W-90 gear lube and turned it upside down, nary a drip. What about the shifter shaft you asked? I added an O-ring on top beneath the shfter arm. I filled the transaxle a little less than half way up, the gears with distribute it.
The bolts that secure the front axle support had loosened and a bolt had fell out of the support bracket for the transaxle. This allowed the front axle support and transaxle to rock around when the mower was in motion. The frame was stress cracked at the bolt holes in front and the frame had broke where the transxle mounts, a small piece of metal fell out when I unbolted the transaxle. I welded it up, ground it smooth but decided to add additonal support where the transaxle mounts. I made these supports from 1.25" angle and bolted them to the frame (see pictures). It's not going to be a concours restoration or show winner, I intend to use it like a mower so these minor modifications were necessary.
Before;
After;
Above; metal strip added on top of the frame with one additional bolt added in the middle.
The wheels are sanded, primed and painted, new tires installed.
I took the liberty of replacing the front wheels bushings with bearings. The front axles were worn so I had to weld the worn areas and file them back to size so that the bearings had a nice seat on the axle and not wallowing around.
That's as far as I've gotten.
SkyFive is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 10-19-2011, 12:11 AM   post #2 of 15
sparklie
Senior MTF Member
MTF Member # 41680
Thumbs up Re: My Wheel Horse 212-5 restoration attempt
Verry good work on tractor. if you do the rest like u did it so far--- it will be a show tractor.
sparklie is offline   Reply With Quote Quick reply to this message
Old 10-19-2011, 06:47 PM   post #3 of 15
glenn27
10,000 +posts!
glenn27's Avatar
MTF Member # 703
Images: 2
Default Re: My Wheel Horse 212-5 restoration attempt
I have to say--from the pictures, you have the equipment and knowledge--and looks like a first class job.
glenn
__________________
Sometimes you just have to laugh..To keep from going insane!!
Jimmy Buffett
glenn27 is offline   Reply With Quote Quick reply to this message
Old 10-22-2011, 09:02 PM   post #4 of 15
73 wheelhorse
Proud Member of the 1K Club
73 wheelhorse's Avatar
MTF Member # 18349
Images: 1
I have one of those if you need some parts
__________________
Doug
1973 18 automatic (2)
1977 D160
1979 D160
1994 416-8
1974 Cub 108
1971 Cub 127
1998 GT5000 pulling tractor
1976 SS/16 Twin
1986 Gt 18 Twin
73 wheelhorse is online now   Reply With Quote Quick reply to this message
Old 10-22-2011, 09:29 PM   post #5 of 15
SkyFive
MTF Junior Poster
MTF Member # 65216
Images: 3
Quote:
I sent you a PM 73 wheelhorse.
Old 10-22-2011, 09:34 PM   post #6 of 15
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
I have a $70 212-H. Fun little tractor! Your work is amazing. Keep the pictures coming!
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is online now   Reply With Quote Quick reply to this message
Old 10-22-2011, 09:50 PM   post #7 of 15
Mike X485
New Guy....Trainee
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Nice work.
__________________
JOHN DEERE X748
Mike X485 is online now   Reply With Quote Quick reply to this message
Old 10-23-2011, 01:49 PM   post #8 of 15
Mrwiggles2
3K Poster!!!!
Mrwiggles2's Avatar
MTF Member # 495
Images: 9
Looking good, that is going to be a fun little tractor when its done.
__________________
Craig
Buffalo, NY
You Tube Channel Link Below. Videos on my tractors, how-to and just good stuff!
http://www.youtube.com/user/mrwiggles2?feature=mhee
1989 Wheel Horse 416-8 16hp Onan
1989 Wheel Horse 520-H 20hp Onan
Mrwiggles2 is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 10:31 AM   post #9 of 15
tonsoffun
MTF Junior Poster
MTF Member # 67591
Looks Great SkyFive! I have one just like that with the rear bagger. Been having a hard time finding a snowblower for these. Do you know if they make them for these machines?
Its going to look amazing when done, can't wait to see the final pics!
tonsoffun is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 12:24 PM   post #10 of 15
Merrie-Merrie
Working to a 1K post
Merrie-Merrie's Avatar
MTF Member # 45408
Garage
Sweeeeet!!!!!
Looks good.
Merrie
Merrie
__________________
Proud student of MTF University!!!
See My YouTube Videos Here
2003 Cub Cadet 2186 with custom built Carry-All, Front Bumper
1974 B80 Wheel Horse (Work in progress), where you may see junk... I see potential
2005 Craftsman Push mower (THE PURPLE ONE!!!)
Merrie-Merrie is offline   Reply With Quote Quick reply to this message
Old 11-16-2011, 12:47 PM   post #11 of 15
kb0nly
MTF Member # 66593
Awesome! Can't wait to see the rest.
kb0nly is offline   Reply With Quote Quick reply to this message
Old 12-05-2011, 08:09 PM   post #12 of 15
bettafan
MTF Junior Poster
MTF Member # 59965
They sure do make them or it, here is the serial, 0636SL01 model on mine is 50517, and a date mark is 8237 ,, good luck i just got mine and it was already installed.
bettafan is offline   Reply With Quote Quick reply to this message
Old 12-06-2011, 01:37 AM   post #13 of 15
austinado16
Proud Wheel Horse Owner
austinado16's Avatar
MTF Member # 58755
I have this same tractor, but mine has the round 30" deck. It's cool to see another one, and you're doing a first class job. Mine had over 1,000hrs on the meter when I purchased it from the motel that bought it new. It was in pretty rough shape, but looks nice now after a repaint and new decals. Just found an NOS 30" deck about 6mo ago. What a score that was.
Neat to see the trans apart. I've had others apart, but not one of these. Amazing to see actual ball bearings, and bronze bushings. All I've ever seen are shafts running in aluminum bores. What a quality built transmission.
I like your front wheel bearing mod too. That'll last forever! I replaced the bushings on mine and said, "Good enough.....I'm not flying it to the moon."
Looking forward to your next update.
austinado16 is online now   Reply With Quote Quick reply to this message
Old 12-06-2011, 04:48 AM   post #14 of 15
k91
MTF Member # 19618
WOW you do quality work Like sparklie said if you keep this up it will be a show tractor.
k91 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 02-01-2012, 05:05 PM   post #15 of 15
mrolds88
Senior MTF Member
mrolds88's Avatar
MTF Member # 61421
I have a 212-5 too. It's got 400+ on the meter. Have the bagger for it (never used it) and it has a twin blde deck (dont know what width.) And a snow blower. It's my number 2 tractor now since I got a bigger Craftsman. Maybe soon, I might go through it and fix it up a bit.
__________________
Discerner of junque
mrolds88 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
