My Tractor Build - Page 3 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Home Made Tractors, Implements and Accessories For you guys handy with a blow torch, welder or a wrench.. show us what you can do....
Reply
Thread Tools Display Modes
Old 11-23-2011, 05:30 AM   post #31 of 87
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
Default Re: My Tractor Build
My MF1655 weighs in a little over 2400 with me in the saddle. I've stood it on the front tires alone when pulling 10" dia., 4.5' long concrete posts out of the ground. That's over 4000 lb on the 1" spindles.
There aren't too many GT's with 3/4" spindles that you can ballast to that level. With my old MF12H, I could only get up to 1350 with the same FEL on it. It would stand on the front wheels with an 850 lb payload for 2200 lb on the spindles. I put over 100 hours a year for 7 years on that tractor, likewise for 22 years with the 1655. Almost all loader work.
Never hurt the spindles on either tractor, and never hurt the axle on the MF12H.
The weak point is the axle pivot. That's where all that weight interacts with the frame.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-23-2011, 01:23 PM   post #32 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
That sounds better, im pretty shure that gravely is a pretty heavy tractor, and my axle pivot is a 1" grade 8 bolt so there wont be any troubles there
__________________
tractors:
1980 Turf Trac 16/44 (MTD 824) - rear side-by-side plow, rear snow/dirt blade, v-bar 4 link tire chains.
1982 John Deere 66 RER
1988 Roper YT16 hydro
other:
2006 Craftsman Push 6.5hp front wheel drive
1983 Princess Auto Mini Bike (in progress)
1967 Mercury (ford) half ton 240 3spd
1965 snow cruiser 360 opposed twin, 2 stroke, 14hp
operator of:
2010 John Deere 2320 mid mower, bagger and rear tiller.
2005 Grasshopper 60" front mount , bagger
CrazyRoper is offline   Reply With Quote Quick reply to this message
Old 12-15-2011, 11:19 PM   post #33 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
ok, it is motor time!! i have 3 choices.
1. go to princess auto and pick up a brand new 6.5HP motor (89.99)
2. spring for a new 13HP motor (250.00)
3. ask around and hope that some one has one for cheap.
4. ask my uncle very nicely if i can buy (or have) the 18 HP Opposed twin briggs sitting on the shelf of the storage building at the farm. (insert tim taylor growl here).
the only problem with the briggs is it may not fit as well as it should and im not shure how the dash would work.
opinions??
__________________
tractors:
other:
operator of:
Old 12-16-2011, 06:36 AM   post #34 of 87
TUDOR
MTF Member # 28463
Number 1 is a little light, even for the mountains in Manitoba. Number 2 is a much better option.
Numbers 3 and 4 are the preferred choices, although availability on a timely basis is suspect and space considerations must not be taken lightly.
Give it some time for something to show up and then go with #2 if necessary.
The prices for those engines must be in the showroom. They sure aren't in the catalogue.
__________________
Bob
In Service
Down for Repairs
Old 12-16-2011, 10:12 PM   post #35 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
thanks, the prices are on the website, and they are both powerfist engines.
if the 18 hp fits good would it be the best choice??
__________________
tractors:
other:
operator of:
Old 12-17-2011, 09:07 AM   post #36 of 87
TUDOR
MTF Member # 28463
Not necessarily. Horses are hungry and you don't really need that many for loader work. The first engine that you mentioned will "do" the job, but it won't like any kind of slope with the weight of a tractor set up for loader work. It will climb ramps onto a trailer, but it's going to complain.
The big Briggs won't complain about anything, but those extra cubic inches will want to be fed. My 12 hp Massey had adequate power and wasn't all that thirsty. My 20 hp MF1655 thinks I own an oil well in comparison.
The bottom line is big horsepower is for powered implements and hill climbing. GT's in general simply don't have the weight to use more than 10 or 12 hp when working on flat ground with a FEL, and that includes my 2400 lb 1655.
That being said, if you intend to play in the wet ground with any frequency, definitely get the Briggs. I know what Saskatchewan gumbo is like and I assume Manitoba's is similar. I make every effort to keep my tractors out of the mud. I learned my lesson the first spring that I had my 1655, 30 years ago.
__________________
Bob
In Service
Down for Repairs
Old 12-17-2011, 10:00 AM   post #37 of 87
MrGiggles
TE Writer
MrGiggles's Avatar
MTF Member # 30161
Images: 10
Briggs opposed twin with dual stacks.
I'm 18 and still think this is cool.
__________________
Mowers:
2005 Troy Bilt ZTR 42-19hp Briggs I/C 42" Deck
Allis Chalmers B-10 with a snow blower, blade, tiller, and mowing deck
Chainsaws:
Husqvarna 50 Special, 20" and 16" bars
Stihl 066, 25" and 20" bars
Jonsered 2252 Autotune, 18" bar
Poulan 3400CV, Craftsman 2.1
Other:
Stihl FS90R with Brush Blade
1999 Kawasaki Bayou 220 ATV
Collection still growing.
MrGiggles is online now   Reply With Quote Quick reply to this message
Old 12-17-2011, 10:38 AM   post #38 of 87
Onan18
2000 Posts and climbing!!!
Onan18's Avatar
MTF Member # 40653
You might want to consider finding something with pressure lube, like a Kohler Magnum Twin, Kohler Command, or an Onan.
Joe
Onan18 is online now   Reply With Quote Quick reply to this message
Old 12-17-2011, 10:42 AM   post #39 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
Thumbs up Re: My Tractor Build
the thing with my tractor is FEL work will not be its primary duty, it is going to be in the garden alot too, plowing and such,
so im thinking that if i can get this 18 from my uncle cheap or free, it would be my best choice.
if he doesnt want to sell it then i will take a cruise over to Princess Auto and pick up the 13HP
__________________
tractors:
other:
operator of:
Old 12-17-2011, 04:47 PM   post #40 of 87
TUDOR
MTF Member # 28463
Sounds like a good plan to me. Too much horse power is better than not enough and budgets rule the world.
__________________
Bob
In Service
Down for Repairs
Old 12-17-2011, 05:01 PM   post #41 of 87
TUDOR
MTF Member # 28463
Yup! They look cool .................... right up to the point where you have to tarp up the tractor to protect it from the 60 mph breeze blowing across a flat prairie and carrying a foot of snow with it. If the tarp stays put, the stacks will poke holes in it.
Not everyone can park their tractor inside.
__________________
Bob
In Service
Down for Repairs
Old 01-23-2012, 08:34 PM   post #42 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
ok boys, im back at it and got a motor picked out, its the 16HP Briggs i rebuilt, it came out of the same tractor as the rear end. the only problem is it is a vertical shaft and my trans has a horizontal shaft so i am going to have to to use a stupid twisted belt clutch system, but i think it should be ok
__________________
tractors:
other:
operator of:
Old 11-04-2012, 12:17 AM   post #43 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
Long time since I have posted an update. I have totally revamped my plans for this stupid thing.i now have a vw 1.6 nc diesel motor and 5 speed trans, and a ford 7.5 rear axle. I will possibly be making it articulate and 4x4 but we will see about that one...
__________________
tractors:
other:
operator of:
Old 11-04-2012, 09:00 AM   post #44 of 87
biker
Proud Member of the 1K Club
biker's Avatar
MTF Member # 35905
Boy did you change your plans. Keep posting pictures!!!
__________________
John Deere 750
Kubota B6200
Craftman GT5000
Building A Hydraulic Drive Homemade Tractor
Happy Wife Happy Life Sad Wife OOH No
Nothing But The Truth
biker is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 11-08-2012, 12:54 AM   post #45 of 87
CrazyRoper
Senior MTF Member
CrazyRoper's Avatar
MTF Member # 33339
It's coming along...please mind the mess..lol I don't have a lot of garage room to work with.
On a side note I have decided on conventional solid axle 4x4 and I am hopefully going for the engine/trans on Saturday.
__________________
tractors:
other:
operator of:
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
