When spark plugs go bad - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 09-24-2011, 07:49 PM   post #1 of 5
dancote
Senior MTF Member
dancote's Avatar
MTF Member # 20867
Default When spark plugs go bad
My Craftsman GT has been running poorly for a while. Ran fine on start-up but within a few minutes it seemed to be missing and had less power.
Thought it might be bad gas so I drained and re-filled. No luck.
Looked at the fuel filter and, even though it didn't look too bad, I replaced it. No luck.
Pulled the plugs and they looked good (to this untrained eye) but I checked and re-gapped them. No luck.
Finally, I replaced the plugs, even though I had put new ones in this spring. And ... voila ... running like new again.
Regards,
Dan
dancote is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-24-2011, 08:01 PM   post #2 of 5
engine2quarters
5000 Strong & Climbing
MTF Member # 24003
Default Re: When spark plugs go bad
Even different manufacturers of plugs give different results.
engine2quarters is offline   Reply With Quote Quick reply to this message
Old 09-24-2011, 08:36 PM   post #3 of 5
Ralphst16
Senior MTF Member
Ralphst16's Avatar
MTF Member # 61010
Yeah plugs can make alot of difference. I looked at mine today and it was FILTHY. I cleaned it up and regapped it and now the tractor runs alot better. I really need a new plug considering I've never changed it before, but it will work until I get a chance to get one.
__________________
1973 Sears ST16 (48" mower deck, front plow, snowblower, litter whisk, broadcast spreader, manual 3 pt hitch, penn line dump trailer)
1964 Bolens Husky 900 (38" mower deck, front plow, home made dump trailer)
1969 International Scout 800a
Ralphst16 is offline   Reply With Quote Quick reply to this message
Old 09-24-2011, 09:45 PM   post #4 of 5
Dude11
2000 Posts and climbing!!!
Dude11's Avatar
MTF Member # 8852
Images: 4
I'd say bad plugs are one of the most over looked,easy repairs one can make--now how would I know that??
__________________
Dude11
Dude11 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-25-2011, 01:38 AM   post #5 of 5
Tractor-Holic
10,000 +posts!
Tractor-Holic's Avatar
MTF Member # 8867
They ARE important--especially when you only have ONE...a single cylinder engine needs one that works,isn't fouled,and has no cracks in the porcelain to short the spark to ground instead of firing at the tip...you aint got 3,5,or 7 other cylinders to run on like a car when one dies--one dies,its DEAD!..
I've had plugs last decades,others I've had "die" suddenly,like a switch went off inside them,and though they'll spark outside of the engine fine,they would not let it start when put back in--tried a new one and VROOM,cured!!..I've had some plugs "shut down" after they get hot,then work again once they cooled down..(I smash those so I wonrt end up using them again !)..
I think some magnetos get flukey too though,and make the plug look "bad",but putting a new one in or reducing the gap on the old one can mask a weak magneto,as the new plug has lower resistance,and the smaller gap is easier to jump..
__________________
Tractor-Holic is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
