safe slope angle for hills - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-31-2011, 06:33 PM   post #1 of 60
calvet
MTF Junior Poster
MTF Member # 64937
Default safe slope angle for hills
Hi,
We'll be creating some low hills during a pond excavation and would like to be able to mow them. We can choose the slope angle within limits. However, because the volume of dirt is fixed, a lower slope angle means the hills will consume more cropland.
So, what angle would you suggest for:
1. traveling perpendicular to the contour lines (i.e. up and down), and
2. traveling parallel to the contour lines (i.e. sideways).
I realize that 1. can be steeper than 2. Ideally, we would like to be able to travel parallel just to keep our options open and for added safety (someone might forget that they are supposed to go only perpendicular). I also realize that soil conditions (ours is clay) are a factor, and localized items like pot holes, small gullies, wet spots, etc. can be dangerous. The tractors will be Kubotas (G or L series) with belly or trailing mowers. We need to decide now on maximum slope angle so the design can be finalized.
I searches the archives, and there was some indication that 20 plus degrees might be OK for traveling parallel, but it wasn't solid (how much plus?).
Thanks,
Mike
calvet is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-31-2011, 07:04 PM   post #2 of 60
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
Default Re: safe slope angle for hills
You should contact Kubota and ask them what the maximum safe angles are for each model tractor you intend to use. I seem to remember seeing that kind of information on John Deere's web site, but I can't find similar information on Kubota's. It may be in the owner's manual.
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is offline   Reply With Quote Quick reply to this message
Old 08-31-2011, 10:44 PM   post #3 of 60
TUDOR
9000+ Strong & Climbing
MTF Member # 28463
Loading the tires and adding wheel weights will improve the tractor's stability on side slopes.
I believe Massey recommends a max of 15* for side slopes, but I won't swear to it.
__________________
Bob
Click for The Hydraulics Forum!
Sometimes you get on a roll, sometimes the roll gets on you.
In Service
MF GC2310, Husqvarna YTH20B42T
Down for Repairs
MF1655 w/ FEL, MF1655, MF12H, MF8H, MF7H
Spending too much time on MTF to work on my toys.
TUDOR is online now   Reply With Quote Quick reply to this message
Old 09-01-2011, 12:33 AM   post #4 of 60
calvet
MTF Junior Poster
MTF Member # 64937
Kubota is not forthcoming about slopes on their website or in their manuals. They just say to be careful. Besides I may not be using a Kubota in the future.
Mike
Old 09-01-2011, 11:07 AM   post #5 of 60
North Country
Senior MTF Member
North Country's Avatar
MTF Member # 57976
If I were a tractor manufacturer in this lawsuit-riddled country, I would tell the user not to take the tractor out of a parking lot. The rollover angle depends on speed, turn rate, implements, load, holes, roots, operator skill, etc...
That being said: Most people seem to get anxious around 18 degrees and post "holy crap look at my hill" pictures around 20-22. 15 is a nice conservative number.
__________________
NC
My hills have hills.
North Country is offline   Reply With Quote Quick reply to this message
Old 09-01-2011, 11:55 AM   post #6 of 60
calvet
MTF Junior Poster
MTF Member # 64937
I've continued to research the question on the net. The steepest angle mentioned by a manufacturer or dealer is 15 degrees; some recommend no more than 10 degrees. These limits would be for slow, straight travel parallel to contour lines with firm, dry soil and no local hazards (pot holes, rocks, etc.) and any side implements on the uphill side. A few degrees could probably be added if travel was limited to perpendicular to the contour lines, but then you're depending on people to remember not to travel parallel to contour lines.
Most manufacturers take the CYA approach of simply saying avoid traveling on "steep slopes" without defining "steep."
I've found a record on the net of one roll-over that occurred on a 25 degree slope where there was no obvious local hazard or operator error beyond driving on the slope in the first place.
Of course, with sufficient operator incompetence, a tractor can be rolled on flat ground. I remember an incident about 9 years ago where one of my workers filled the front bucket with sand, kept it high, took off at top speed on level ground, and made a sharp turn. One of the front wheels lifted off the ground. After I calmed down, the worker received a couple of training sessions and was never unsafe again.
Mike
Old 09-01-2011, 12:24 PM   post #7 of 60
marlboro180
Loving Life :-)
marlboro180's Avatar
MTF Member # 37397
Garage
Mike,
Do you currently own the equipment that will be mowing the slopes?
You mentioned a couple pieces, or are you going to buy them to mow the area?
Are we sure we are ( the manufaturers ) talking the same thing-> degrees?
Some equipment makers express slope capability in % , not degrees.
Ventrac is one that comes to mind for some serious slope capabilty especially with the dual wheel option.
http://ventrac.com/
M
__________________
Case 222, 448 ,648 LBH ,, Craftsman 11-36, DLT 3000, Ransomes Motor 180 x 2 :-) Gilson RE-11, Plymouth Gilson something,?and some Hondas and other stuff- the e c l e c ti c gang LOL "Got Solar?"
Help save the DLandreth Seed Company
http://hereandnow.wbur.org/2012/05/0...d-horticulture
marlboro180 is offline   Reply With Quote Quick reply to this message
Old 09-01-2011, 01:09 PM   post #8 of 60
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
I use the pucker and clench factor to know when is enough and that will vary from person to person slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 09-01-2011, 01:51 PM   post #9 of 60
Loremaster72
Proud Member of the 1K Club
Loremaster72's Avatar
MTF Member # 25731
One other thing to consider, especially for extended use on side slopes, is that some engines can suffer from oil starvation when held at too severe an angle. It's been a while since I had to spec out an OEM diesel engine, but I recall that the "same" base engine could have radically different slope capability, I believe primarily based on the oil pan configuration. It may be hard to get this info for CUT engines ( I was dealing with 4 and 6 cylinder diesels 80-200 Hp) but keep this in mind when looking at your equipment.
You may want to look into adding duals to your mowing machine for side slope use, as this can have a great effect on the sideways stability of the machine. There are also some tractors, primarily configured as golf-course or mowing tractors, with lower clearance and wider machines. I know I've seen Fords like this, and THINK I've seen a Kubota like this, but I could be wrong.
__________________
Loremaster72
Mechanical Engineer, Book Collector, and Tractor Nut
Current Machines:
1979 Gravely 5265 Commercial
1990 Gravely 16G Professional
1973 Sears SS16 Twin
Loremaster72 is offline   Reply With Quote Quick reply to this message
Old 09-01-2011, 02:11 PM   post #10 of 60
Nouveau Redneck
3K Poster!!!!
MTF Member # 19566
Images: 1
You could just get yourself One of these and not worry about the slope.
__________________
Nouveau Redneck
Sean in PA
Old 09-01-2011, 05:32 PM   post #11 of 60
Curly69
Senior MTF Member
Curly69's Avatar
MTF Member # 45653
I live on a hill and could have sworn it was steeper then it was. So I bought an inclinometer on average I cut on a 15-20 degree angle which sometime in scary. I one section where I go just at 25 and it's scary the first few times of the year then I just go.
http://www.mytractorforum.com/showthread.php?t=200796
__________________
JD 2305
200X FEL
60" K-K R.D. Finish Mower
Pittsburgh/Taylor-Way Tiller
EMCO Auger 9" bit
5' Pittsburgh Scrape Blade
48" Cultivator / Hiller
Homelite Super XL 25 yrs+ and still humming
Homelite XL 25 yrs+ and humming away
Echo weedeater SRM251E
TroyBilt Log Splitter
Curly69 is offline   Reply With Quote Quick reply to this message
Old 09-01-2011, 07:19 PM   post #12 of 60
TUDOR
MTF Member # 28463
A pile of gravel off of a conveyor has a slope of approximately 39* or 81%. Dirt slumps at about the same angle. You're not likely going to have to mow steeper.
__________________
Bob
In Service
Down for Repairs
Old 09-02-2011, 09:46 AM   post #13 of 60
RTG53
Senior MTF Member
MTF Member # 38420
Quote:
Okay, I'm impressed! I wonder if they have cleats on their shoes too.
RTG53 is online now   Reply With Quote Quick reply to this message
Old 09-02-2011, 10:43 AM   post #14 of 60
JFordBronco
Senior MTF Member
JFordBronco's Avatar
MTF Member # 26902
That was some steep slopes there.....WOW
__________________
Looking for another tractor....but will still be on this page everyday!
MF 1532 with FL100 5' FEL SOLD
5' Big Bee bush-hog SOLD
6' Rhino finishing mower SOLD
6' County Line/King Kutter box blade
12" Everything Attachments Single Bottom Plow
5' Howse disc(DLHT16822B) SOLD
5' Everything Attachments Garden Bedder
Everything Attachments Trailer Mover
Everything Attachments Potato Plow
Thanks Wifey for buying it for me
JFordBronco is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 09-02-2011, 11:28 AM   post #15 of 60
cub2900
Josh
cub2900's Avatar
MTF Member # 33095
So much of your ability to mow on an angle will depend on the skill of the driver. That doesn't mean its any safer, just means that some people can accomplish a lot more with the same piece of equipment than an unskilled driver. This probably falls into the the area of bodily-kinesthetic intelligence.
cub2900 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
