My Workhorse 214 has been busy... pushing the belly blade! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-29-2011, 08:10 PM   post #1 of 13
derekbroerse
Senior MTF Member
MTF Member # 60712
Default My Workhorse 214 has been busy... pushing the belly blade!
Yes, it has a grille emblem!
Some pics, all nice and dirty, spent a few hours today pushing the JD Model 43C Center (belly) Blade. I was levelling off 3 triaxle loads of 3/4 gravel, 40x60' pad. Does a decent job.
Blade rotates 23 degrees right or left, or straight ahead. Also the blade can be rolled forwards of back to make it dig more or less.
I bought this recently off fleabay, it was pricey and not cheap to ship either, but it even came with the original manual and works great on dirt and gravel.
I will say this, I'm really glad I added the hydro's to my tractor!!
Name:	214 blade 1.jpg
ID:	172253   Click image for larger version
Name:	214 blade 2.jpg
ID:	172254   Click image for larger version
Name:	214 blade 3.jpg
derekbroerse is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-29-2011, 08:19 PM   post #2 of 13
derekbroerse
Senior MTF Member
MTF Member # 60712
Default Re: My Workhorse 214 has been busy... pushing the belly blade!
more pics including some from the manual....
Name:	214 blade 4.jpg
ID:	172256   Click image for larger version
Name:	214 blade 5.jpg
ID:	172257   Click image for larger version
Name:	214 blade 6.jpg
Old 08-29-2011, 08:22 PM   post #3 of 13
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Nice blade for sure, you also really have that tractor set up for working!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 08-29-2011, 08:47 PM   post #4 of 13
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
That a Very rare Implement on the 200 series and Looks Great on that 214 with Hydraulic lift
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 08-29-2011, 09:58 PM   post #5 of 13
derekbroerse
Senior MTF Member
MTF Member # 60712
It must be an early version, the manual doesn't even show or mention a 200/300 series. Just the 110/112/120/140.
Old 08-30-2011, 04:52 AM   post #6 of 13
slkpk
USMC
slkpk's Avatar
MTF Member # 37
Images: 21
Nice looking tractor and you don't see many of those on a JD. slkpk
__________________
1964 JD RF110 Restored
2004 Ingersoll 318LGT @ the church doing the Lord's work
2007 JD 2305
It's too late to worry about it now!
slkpk is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 08:52 AM   post #7 of 13
ColonyPark
3K & Yet So Little to Say
ColonyPark's Avatar
MTF Member # 5603
Nice workhorse, the treads look great. Thanks for the pics!
__________________
2011 John Deere 1026R w/60" 7Iron Drive Over NON AutoConnect MMM and FEL and 47" Front Mount Snow Blower with "Wings" and 48" KingKutter II Tiller and 48" KingKutter Brush Hog and CountyLine CarryAll
1990 John Deere 185 w/46" Deck and PowerFlow Bagger
ColonyPark is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 08:56 AM   post #8 of 13
quickrch
Senior MTF Member
quickrch's Avatar
MTF Member # 33410
wow, now there is something new I want.
__________________
Cub Cadet 3206
54" Deck
Chains, Wheel Weights
JB SR with hydro lift and electric dump
Agri Trailer 12 Cubic Ft.
John Deere 212 1980, tiller with one extension, 47" deck, and the plow.
quickrch is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 08:58 AM   post #9 of 13
better before
Too young to act this old
better before's Avatar
MTF Member # 48627
That actually looks easy enough to build. I like it. I have more time than money.
better before is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 12:51 PM   post #10 of 13
derekbroerse
Senior MTF Member
MTF Member # 60712
Quote:
I know someone's gonna ask sooner or later, so Titan Tru Powers on the rear, and Deestones on the front. All four are filled with fluid (I forget how many gallons, it sure was alot). The fronts actually rub the lugs against the frame at full turn when the axle pivots, in fact, a few times while pushing the rough gravel around it would lift the wheel up enough to lock the wheel until I straightened the steering or got off the hump.... :S They are the original size.
Can anyone ID my rear wheels? When I bought them, they referred to them as "heavy duty Patio 140 rims", but I'm not sure I buy that, I'm not even sure they are JD. Offset it a bit different and the center is a solid welded disk rather than the usual pressed in square. I can probably get a better pic....
Old 08-30-2011, 07:05 PM   post #11 of 13
tmaynard
Senior MTF Member
tmaynard's Avatar
MTF Member # 34476
Those are the so called "heavy duty" rims. They are not any stronger than the other rims and actually are though to be weaker by some. They were used by Deere in part of 1969 when the supplier of the regualr rims went on strike so the company that produced the flat faced rims was used. I have a set on my patio 140 H3 too.
__________________
-Tom
1968 John Deere 140 H3 54 4 Way Blade, 3 Point Hitch, Brass Tag 33 Tiller
1981 John Deere 400 54 4 Way Blade, 60" Deck
And a bunch more John Deere Garden Tractors
tmaynard is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 08:46 PM   post #12 of 13
derekbroerse
Senior MTF Member
MTF Member # 60712
Quote:
Hmmmmm.... learn something new every day.
They are actually freshly painted, but you'd never know it under the dirt!!
Sponsored Links
Advertisement
Old 08-30-2011, 08:47 PM   post #13 of 13
derekbroerse
Senior MTF Member
MTF Member # 60712
For Sergeant....
ID:	172424   Click image for larger version
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
