flywheel shear pin keeps breaking - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-25-2011, 02:21 PM   post #1 of 27
747driver
747driver
MTF Member # 64665
Default flywheel shear pin keeps breaking
I have a 16hp ohv briggs series 28q. I replaced the altenator with a new one as the old one quit charging. I learned I put the wrong style on so I took the new one off and put the old one back on. After taking the new one off I found the flywheel shear pin had broken. So I put the old altenator on and a new shear pin. I adjusted the valves and the engine ran rough for abit then would not start at all. I pulled the flywheel off to check the pin and found it to be sheared again. Now the first new one I put on was not a briggs pin but just key stock from the hardware store, would that make a difference? Can't figure out why the shear pins have broken ? I can understand when the pin shears it throws the timing off which will make it hard to start or not start at all.
Thanks Chuck
747driver is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-25-2011, 02:46 PM   post #2 of 27
tomw0
2000 Posts and climbing!!!
MTF Member # 34922
Default Re: flywheel shear pin keeps breaking
How much torque did you put on the flywheel nut? The shaft is tapered, and depends on friction to keep the flywheel in 'place'. If the nut is not tight enough, the fly will shear the key as the key is sacrificed if you ever hit a stump... and if the flywheel is not tight enough.
The surfaces should be clean and non-rusty for a good friction contact at the specified torque.
tom
tomw0 is offline   Reply With Quote Quick reply to this message
Old 08-25-2011, 07:22 PM   post #3 of 27
747driver
747driver
MTF Member # 64665
Thanks Tom...I didn't use a torque wrench, just tightened it by feel to what I thought was tight ! Your right I should have use a torque wrench, it makes sense in your response to my problem. Yes, being a aircraft mechanic we use torque wrenches all the time on critical parts.
Old 08-25-2011, 09:46 PM   post #4 of 27
Kbeitz
Collector of many tractors
Kbeitz's Avatar
MTF Member # 86
Images: 4
And dont use a hard key..
A hard key will mess up you crank and flywheel...
The taper does all the holding...
__________________
Kbeitz is offline   Reply With Quote Quick reply to this message
Old 08-26-2011, 06:46 AM   post #5 of 27
Mike Milburn
Senior MTF Member
MTF Member # 30999
Since the grip is dependant on the taper and the key is just for alignment I'll get some valve lapping compund and use it to true up the flywheel and the shaft. Just be sure to get it all off before you put it back together.....Mike
__________________
1984 1966 Bolens 19H Kohler
198? 1666 Bolens 17H Kohler
2007 204 Jinma 20 HP 4WD Tractor
Koyker 140 Loader
BH6600 Backhoe
Howse 5ft. Backblade
Mike Milburn is online now   Reply With Quote Quick reply to this message
Old 08-29-2011, 05:40 PM   post #6 of 27
747driver
747driver
MTF Member # 64665
Ok guys....I put a new key in and torqued the flywheel down to 65 ft. lbs. I adjusted the valves from TDC and the engine started right up but ran rough. It stopped and I couldn't get it started again. So I pulled the flywheel and the key was sheared again. The crank shaft taper is alittle scared from the keys shearing. The flywheel bolt has 4 washers under it, should I remove one to seat the bolt farther on the crank shaft ?
Old 08-29-2011, 05:47 PM   post #7 of 27
Mike Milburn
Senior MTF Member
MTF Member # 30999
Anything other than a clean fit is going to cause the key to shear. Did you get some compound as I suggested and dress up the flywheel and shaft?.....Mike
__________________
Koyker 140 Loader
BH6600 Backhoe
Old 08-29-2011, 06:14 PM   post #8 of 27
rscurtis
5000 Strong & Climbing
MTF Member # 25367
I've never seen a Briggs with 4 flywheel washers. That could be the crux of your problem.
rscurtis is offline   Reply With Quote Quick reply to this message
Old 08-29-2011, 07:33 PM   post #9 of 27
dc 3mech
Proud Member of the 1K Club
MTF Member # 35535
Look closely and make sure the flywheel isn't cracked,usually in the keyway,over torquing can split it,and tightening more can cause it to spread.
dc 3mech is offline   Reply With Quote Quick reply to this message
Old 08-29-2011, 07:39 PM   post #10 of 27
mla2ofus
Old Stonebreaker
MTF Member # 138
If the flywheel bore and crank taper aren't clean and dry w/ absolutely no lubricant, the problem won't go away.
Mike
mla2ofus is offline   Reply With Quote Quick reply to this message
Old 08-29-2011, 07:51 PM   post #11 of 27
LilysDad
Just Have a Little Faith!
MTF Member # 7161
Does this have a dished washer like the old Briggs verts. used to?
LilysDad is offline   Reply With Quote Quick reply to this message
Old 08-29-2011, 08:11 PM   post #12 of 27
747driver
747driver
MTF Member # 64665
Mike..I had put it all back together before I read your post. Now I will use the compound and dress the shaft and bore. As I said earlier I don't work on small engines much, but with manuals and this forums help I am learning alot !
Thanks again Chuck
Old 08-30-2011, 02:29 PM   post #13 of 27
BOSMECH
BOSMECH's Avatar
MTF Member # 38136
Chuck come on your an A&P mechanic (So am I) so we should never have problems.
BOSMECH is offline   Reply With Quote Quick reply to this message
Old 08-30-2011, 11:23 PM   post #14 of 27
dc 3mech
MTF Member # 35535
Yeah,me too,A&P IA,DME for a while,lots of piston time, 4&6 cylinder flats,, 9,14&18cylinder rounds,and still I've had these little one lunger's kick my butt.
Sponsored Links
Advertisement
Old 08-31-2011, 03:20 PM   post #15 of 27
tomw0
MTF Member # 34922
Dad worked on them (Wright Cyclones) for the B29(?) back when at the Chicago (Cicero) Dodge plant, then went on to build R4360's and Pratt J57s, again at the old Chicago Dodge plant, then taken over by Ford AED. Long ago.
Same place Preston Tucker built his 50 Tuckers... Dad said he was put out of business by the Big '4' of the day... Didn't want the competition, and they had a lobby in DC, which Tucker did not. Old f*rt memories, I spoze.
Back OT, if the crankshaft taper is all scored from slippage, what is a possible solution? I have two in mind, but one involves disassembly, and the other involves epoxies...
tom
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
