Tiller belt routing 214 w/31 tiller...AGGREVATING! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-22-2011, 04:19 PM   post #1 of 12
StWeiler
Buy High, Sell Low
StWeiler's Avatar
MTF Member # 13372
Default Tiller belt routing 214 w/31 tiller...AGGREVATING!
So I can't find a single diagram online that shows the tiller (31) belt routing, and this being my first time trying to set up on the newly acquired 214 I'm finding myself getting downright irked at this. Typically I'm pretty savvy at figuring this sort of thing out...but this stupid new belt has me completely perplexed.
Do ya think the JD dealer would be willing to print me off a diagram if they have one? I did just spend $69 on the belt, so that certainly helps my persuasion.
__________________
1988 Wheel Horse 518H
48" Dozer Blade
48" SD Deck x2
StWeiler is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-22-2011, 04:37 PM   post #2 of 12
JimHenry
Senior MTF Member
JimHenry's Avatar
MTF Member # 14490
Default Re: Tiller belt routing 214 w/31 tiller...AGGREVATING!
Did you twist the belt between the mule drive and the tiller 1/2 turn?
PM sent
JimHenry is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 04:50 PM   post #3 of 12
better before
Too young to act this old
better before's Avatar
MTF Member # 48627
I just put pics up and explained this for someone recently. Like the last 2-4 days. Could have sworn it was you but it wasn't. Yeah, the mule drive hooks up on the frame just behind, below the engine. Uses mounts for the mower deck. Short belt from pto to mule drive and the long one goes all the way back to the tiller with the half turn like Jim said. Google 31 tiller and go to images. These were compatible with 110, 112, 210-216. It hooked to all of them the same. Is your rear lift installed?
better before is online now   Reply With Quote Quick reply to this message
Old 08-22-2011, 05:06 PM   post #4 of 12
StWeiler
Buy High, Sell Low
StWeiler's Avatar
MTF Member # 13372
Yep rear lift is installed, tiller is mounted just couldn't figure out the slack in the belt. I guess the 1/2 turn makes sense. I suppose it doesn't matter which direction you twist it...cw or ccw?
TIA
__________________
48" Dozer Blade
48" SD Deck x2
Old 08-22-2011, 05:38 PM   post #5 of 12
JimHenry
Senior MTF Member
JimHenry's Avatar
MTF Member # 14490
clockwise, looking back
Old 08-22-2011, 06:50 PM   post #6 of 12
Sergeant
Tech Exchange Moderator
Sergeant's Avatar
MTF Member # 24
StWeiler I sent You a PM with some Help It for the 110 & 112 Fender decks But the Mounting & Belt routing is the same
__________________
John Deere Models:X748,140H3,112,Sabre 1542
Cub Cadet Models:0riginal,70,106,2206 & Experimental Non Production Rear engine rider
Ingersoll Model:3016PS
Simplicity Models:Wonder Boy
White Model: GT2055
"The only thing necessary for the triumph of evil is for good men to do nothing." Edmund Burke
Sergeant is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 09:05 PM   post #7 of 12
StWeiler
Buy High, Sell Low
StWeiler's Avatar
MTF Member # 13372
Sweet Sergeant...that will definitely help a ton!
__________________
48" Dozer Blade
48" SD Deck x2
Old 08-24-2011, 04:44 PM   post #8 of 12
StWeiler
Buy High, Sell Low
StWeiler's Avatar
MTF Member # 13372
I'm at a loss. Either I have something routed incorrectly or I"m skipping a step on getting this belt to route through to the mule. Suggestions? Sorry sun is directly overhead very difficult to get a decent photo.
__________________
48" Dozer Blade
48" SD Deck x2
Old 08-24-2011, 04:51 PM   post #9 of 12
ericstromberg
Senior MTF Member
MTF Member # 34891
Not sure if you've seen this one, but here is a good diagram of the routing.
ericstromberg is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 05:25 PM   post #10 of 12
better before
MTF Member # 48627
Make sure you have your tension pulleys on.
Old 08-25-2011, 09:24 AM   post #11 of 12
StWeiler
Buy High, Sell Low
StWeiler's Avatar
MTF Member # 13372
Where are those located?
__________________
48" Dozer Blade
48" SD Deck x2
Sponsored Links
Advertisement
Old 08-25-2011, 11:05 AM   post #12 of 12
better before
MTF Member # 48627
Look at eric's pic. right side, just in front of the mule drive. Have you run a mower deck on your tractor?
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
