undercoating a mower deck? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-21-2011, 09:18 PM   post #1 of 28
ATLANTICCENTRAL
2000 Posts and climbing!!!
MTF Member # 60860
Default undercoating a mower deck?
I have read several ads for mower decks for sale indicating they have been undercoated? Anybody do this? What are your thoughts?
Sheldon
ATLANTICCENTRAL is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-21-2011, 09:27 PM   post #2 of 28
Richard-tx
5000 Strong & Climbing
Richard-tx's Avatar
MTF Member # 51208
Images: 7
Default Re: undercoating a mower deck?
I use epoxy paint or equivalent. If dried concrete can't stick to it, that is good enough for me.
__________________
Code:
                              Current Inventory
   24G (Onan 24hp)    24GLX - was 16G  (Onan 24hp)   8249 - was 8129 (Onan 24hp)
        818T (Onan 18hp B48)       8163T - was 8123 (Onan CCKA)
                              8183T (Onan B48)
   5665 w/brakes        5665        5660        Pro-8         Pro-16 w/brakes
For Gravely Manuals and more visit http://GTCOA.com
Richard-tx is online now   Reply With Quote Quick reply to this message
Old 08-21-2011, 09:38 PM   post #3 of 28
ATLANTICCENTRAL
MTF Member # 60860
So far I have just cleaned mine real good every fall when I take it off. It's still red underneath? No rust to speak of. The deck has reached the point were it looks really dull and dirty in spots and has a few small surface rust spots (very small), so I was thinking of some paint work when it comes off this fall.
Epoxy paint, that makes good sense to me.
Sheldon
Old 08-21-2011, 11:24 PM   post #4 of 28
eveled
eveled's Avatar
MTF Member # 28747
Images: 8
I think the decks rot out when they are allowed to sit outside and the moisture builds up underneath. Decks that are used alot seem to last the longest. When I work on a deck, I usually clean it up as best as I can then use apliance epoxy spray cans. The decks that I have in storage I keep up off the ground and spray with wd40.
__________________
Here's to our veterans past present and future
Machine of The Month link
eveled is offline   Reply With Quote Quick reply to this message
Old 08-21-2011, 11:31 PM   post #5 of 28
silver hair deere
Old as Sin
silver hair deere's Avatar
MTF Member # 4257
Images: 4
I use the rubberized car undercoating on my 89 sears (mine since 91) still looks like new . wish I'd held up that good !!
__________________
Silver Hair Deere
1989 Sears GT
1989 GMC 1500 , NEEDS BALL JOINTS (FIXED)
1996 MTD 695 , REBUILDER (MOSTLEY DONE)
1995 CHEVY LUMINA NEEDS OUTSIDE ROD ENDS
DONE
1998 FORD RANGER RADATIOR NEEDS CHANGED
DONE
When one breaks down , i just drive another .
silver hair deere is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 12:38 AM   post #6 of 28
ATLANTICCENTRAL
MTF Member # 60860
Quote:
My tractor, and its accessories, have never spent the night out doors. My garage is not heated (at least not unless I am working out there in cold weather), but it is insulated and dry. And my deck is in good condition, just ready for some cosmetics.
I used spay can appliance epoxy on my recent wheel and wheel weight repaint - I'm very happy with it so far.
Sheldon
Old 08-22-2011, 03:18 AM   post #7 of 28
Richard-tx
Richard-tx's Avatar
MTF Member # 51208
Images: 7
WD40 makes for a miserable rust preventative. Almost anything else is better. LPS3 is pretty good.
__________________
Code:
                              Current Inventory
                              8183T (Onan B48)
Old 08-22-2011, 11:52 AM   post #8 of 28
eveled
eveled's Avatar
MTF Member # 28747
Images: 8
Sheldon
I would need a warehouse to keep every thing indoors. I was just saying that the decks I've seen that had real rot issues spent a long time outdoors and most where on tractors that had sunk into the ground. On a working tractor I don't think it is an issue. So the answer to you orgingal question is that I don't think undercoating your deck is worth while. I'm also aware of wd40s limitations, but I get an endless supply of it for free, so I make the best use I can of it. The other problem with undercoating the spindles is that you may hold in heat and lead to premature bearing failure. Ed
__________________
Old 08-22-2011, 11:57 AM   post #9 of 28
crisco
Back in VA!
crisco's Avatar
MTF Member # 46665
Garage
yes plus if you leave the grass buildup under there too long, it will rust underneath those blobs that grow over time. also i would assume the more wet grass you cut, the more you have to keep an eye on things under the deck.
__________________
-1972 816 Rider w/50" deck and M20 Kohler
-1990? Promaster 20 H with 60" deck M20 Kohler
-6x4 diesel gator with leaky tires
-1978 troy-bilt Horse tiller/V-furrow plow 7HP Kohler
-2007 Kubota BX2230s w/60" deck and FEL,
42" woods bush hog, 60" DR Power Gravel Grader
crisco is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 12:06 PM   post #10 of 28
eveled
eveled's Avatar
MTF Member # 28747
Images: 8
Quote:
That is probably true, I do blast mine with the leaf blower on top and underneath to remove clippings and dust before I bring it into the barn. They used to make an adapter for your garden hose to attach to your deck but it seems like the worse thing you could do to it before putting it away, Ed
__________________
Old 08-22-2011, 12:55 PM   post #11 of 28
qlty
MTF Member
qlty's Avatar
MTF Member # 61564
If you have been cutting wet grass spraying with a garden hose has to be better than not doing it,other wise blowing it with compressed air is my choice and sealing exposed metal with any paint has to be better than none JMO
qlty is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 01:44 PM   post #12 of 28
esnb74
Desk by Day/Shop by Night
esnb74's Avatar
MTF Member # 43409
Images: 8
To me the key is pulling the deck off several times per year and cleaned out underneath. As long as you don't leave grass packed under there that retains moisture - rust shouldn't be an issue.
__________________
JD 318 H3
JD 140 H1 Mods coming slowly: http://www.mytractorforum.com/showthread.php?t=290386
CC 124 (Future Mini Farmall build)
CC 1250 (Future IHC 966 Tribute build)
Farmall H (One of the many Farmall's I grew up with)
Ford Mustang (64.5)
Past Equipment: JD 316, JD 318, JD 757 Ztrak, IHC 1100A Pickup, CC 3235
Remember: Freedom Isn't Free!
esnb74 is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 03:03 PM   post #13 of 28
vr4Legacy
Gravely Enthusiast
vr4Legacy's Avatar
MTF Member # 59744
Garage
A lot of the newer push mowers I looked at had that. A simple hose female hose fitting on top of the deck, you were supposed to hook the hose up and run the mower for a minute or two to clean it. Not sure it is intended for each mowing. I think it's a good concept, just not sure how well the execution would be.
__________________
-Jason
1973 Gravely CI Walk-behind
1997 Lawnboy 10227 Silver Series
vr4Legacy is offline   Reply With Quote Quick reply to this message
Old 08-22-2011, 04:38 PM   post #14 of 28
WNYTractorTinkerer
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Icon2 Re: undercoating a mower deck?
Quote:
The grass under there does a lot more than retain moisture.. It begins a chemical process that produces Nitrogen and other 'deck-unfriendly' chemicals which eat things up faster as well or more than just the moisture. Lots of good ideas shared here for your consideration.. The best thing is mowing when the lawn is dryest as it won't promote the decay or mulching process as much and deck clean-outs when you do help a ton.. I rebuilt a few decks lately and applied rust converter to them in my attempts to retain what metal the decks have left.. Jury's still out on that method though.. Time will tell.. (*I might try the appliance paint if I ever get a newer deck!) Good luck and hope you find something that works!
__________________
Experience is something we get.... right after we needed it!!
Can You see the Real me?
WNYTractorTinkerer is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-25-2011, 04:52 AM   post #15 of 28
Mickeymotormount
Proud Member of the 1K Club
Mickeymotormount's Avatar
MTF Member # 20928
Images: 12
I've used pourable 2 part roof sealer. Turns to rubber when cured. I did my Ford LGT deck about 10 years ago and it's still holding up well. Grass doesn't stick to it very well, and even when it does, the amount is so small that it's not worth scraping off and possibly ruining the rubber coating.
__________________
John
Ford and Gravely Nut
Mickeymotormount is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
