New to Kubota BX 2360 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Introductions For New Members. Tell us about yourself
Reply
Thread Tools Display Modes
Old 08-07-2011, 02:38 PM   post #1 of 9
Tchinkubota
MTF Junior Poster
MTF Member # 64002
Default New to Kubota BX 2360
I just bought a new Kubota BX 2360 with loader and a 54" MMM. I started using it to mow my lawn and also my 4.5 acre field that has been cut with a bush hog until last year. I am mowing with the deck a 4". Maximum thickness of any saplings is 3/4 of an inch. The MMM does not cut very well tall and thick grass and saplings Also noted that the temperature of the tractor can go close to the red line. I stopped mowing when that happened and let the machine cool for several hours before starting it again. Would I be better wit a bush hog. What is the maximum size that this tractor can pull. I found a 40'' King Kutter on Graigslit. Seems pretty small. Also what is the HST fan? Do I need to protect it as recommended on some website? Thanks for any advice to a novice.
Tchinkubota is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-07-2011, 08:04 PM   post #2 of 9
Brad
MTF--A Step Above!
Brad's Avatar
MTF Member # 4571
Images: 28
Default Re: New to Kubota BX 2360
Welcome to the forum, Tchinkubota. Hope you enjoy your visits. I think you will get some good advice and suggestions in the Kubota and accessories forums. Good Luck!
__________________
MTF--Getting better, one new member after another!
It's a great place to spend some time every day!
Brad
Brad is online now   Reply With Quote Quick reply to this message
Old 08-07-2011, 11:16 PM   post #3 of 9
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
Tchinkabota, welcome to the forum! You would probably find that a brush hog would work better as MMM are not designed to cut 3/4 inch saplings. A brush hog should do it nicely though!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Old 08-07-2011, 11:39 PM   post #4 of 9
UrbanTractor
Likes Vintage JDs
UrbanTractor's Avatar
MTF Member # 38663
Garage
Hi, welcome.
The mmm isn't really designed for cutting brush or saplings. I imagine you would dull and knick the blades pretty quickly.
A brush hog / rotary cutter is what you need. 40-48" is usually the recommended size for scuts like yours.
The overheating neds to be figured out. Sounds like the machine is still under warranty, so you might want to get the dealer involvec. Could be any number of causes, but the coolant level should definitely be checked.
The hst fan is for the hydrostatic transmission. It is attached to the driveshaft that comes from the engine back to the transmission. If you get down and take a look under the machine, you will see a little plastic fan just in front of the tranny. As the drive shaft spins, the fan blows air on the tranny and helps to keep it cool.
That hst fan is vulnerable to damage from stray twigs etc. Newer BX units have a shield that partially protects it. Older units may not have had the shield and some folks have added aftermarket protection.
__________________
1966 JD 110 Round Fender Integral Sleeve Hitch, Model 42 Blade, 1964 (?) Model 80 Cart, 1965 Model 80 Cart
1972 JD 140 H3, 1972 Cozy Cab Model 14 JDX (2nd Ed.), Front-, Mid-, and Rear-PTOs, Model 54/48" 4-Way Blade, Model 48 MMM, 542 Front PTO, 3-Point-Hitch, Heavy-Hitch, 1968 Model 80 Cart, 2 x 1987 Model 80 Cart, Johnson Model 12 FEL (in progress), MTF Dec. 2013 Machine of the Month
UrbanTractor is online now   Reply With Quote Quick reply to this message
Old 08-08-2011, 10:49 AM   post #5 of 9
APinNY
I didn't do it!
APinNY's Avatar
MTF Member # 22011
Images: 5
and congratulations on your purchase. The overheating could simply be a result of air blockage. Your engine is reverse mounted. Make sure the screen in front of your legs is clean, and more importantly, check the screen behind the radiator. Then, blow compressed air down on the radiator fins. As UT stated, the HST fan is easy to break, so definitely check it. If you've been cutting saplings with your MMM you should sharpen and balance the blades.
__________________
Al
Kubota BX1860, 48" fine cut mulching MMM, FEL, snow thrower, cab, Heavy Hitch
TroyBilt LTX 15.5, snow thrower, cab (sold)
TroyBilt LTX 13, (given away)
Craftsman DYT 4000 Special Edition, 21 HP Briggs Twin (sold)
DR Lawn Vacuum. Review here
1978 Craftsman 7 1/2 HP snow blower (backup machine-never use it)
"You will find out what that extra part is for as soon as you throw it away"
APinNY is offline   Reply With Quote Quick reply to this message
Old 08-15-2011, 12:03 PM   post #6 of 9
Tchinkubota
MTF Junior Poster
MTF Member # 64002
Thank you all for the very informative replies to my post. Since then, I found and bought 40" Kingkutter Bush Hog. It is in decent shape. Paid $350.00 for it. Was this a decent price? I sharpened the blades that had hit several stones! But now the blades need to be be balanced because the bush hog vibrates when turning. Can I still using it with the vibration then balance the blades when I am finished or it is a NoNo to use it with unbalanced blades? But the tractor does not heat up anymore when I am using it with the bush hog.
Old 08-15-2011, 01:53 PM   post #7 of 9
Mike X485
New Guy....Trainee
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Welcome to the forum.
__________________
JOHN DEERE X748
Mike X485 is online now   Reply With Quote Quick reply to this message
Old 08-15-2011, 02:42 PM   post #8 of 9
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
Welcome to MTF! Its a great site with lots knowledge and information, and plenty of nice people to help you along the way
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-15-2011, 03:31 PM   post #9 of 9
APinNY
I didn't do it!
APinNY's Avatar
MTF Member # 22011
Images: 5
The vibration is not good for the mower. Vibration tends to loosen bushings, bearings and bolts. I would remove the blades and balance them using a nail in a wall stud or take them to a pro.
__________________
Al
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may post new threads
You may post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
