Did a quick carb clean out with SeaFoam is pouring into the carb OK ? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 08-06-2011, 02:58 PM   post #1 of 12
C-175 Nut
Senior MTF Member
C-175 Nut's Avatar
MTF Member # 14498
Images: 20
Garage
Default Did a quick carb clean out with SeaFoam is pouring into the carb OK ?
Hello!
I decided it was time for a carburetor tune up on my 318, so I
got a zoom spout oiler bottle, rinsed it out with gas and filled
it halfway up with Seafoam carb cleaner. I squirted that a little
at a time directly down the mouth of the carburetor while
running the engine at 3/4 throttle.
It smoked up the backyard
for a while but then cleared up and ran fine. Is this ok to
add Seafoam this way, or should it be just added to the gas
tank? Also should I pull the plugs and clean them after doing this
or will the carb cleaner more or less do that?
C-175
__________________
If Life gives you limes, "MAKE MARGARITAS!"
(Jimmy Buffet) Land Shark Beer!
Wheel Horse C-175 is nice but,
The John Deere 318 is the Best!
Have been converted from Red to Green!
But going back to Red, Got a WH 520H to
ride! Hey it's still an Onan!
C-175 Nut is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-06-2011, 03:07 PM   post #2 of 12
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
Default Re: Did a quick carb clean out with SeaFoam is pouring into the carb OK ?
Oh my gosh-what have you done??? Yes it is recommended putting some Seafoam directly into the carb. as you did, just don't forget to put 1 oz. per gallon in the tank. You should be good to good as you have experienced, congratulation to joining the Seafoam Club.
Dick
__________________
GT275
GT235
JRJ is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 03:10 PM   post #3 of 12
littletractorguy
The Mod from... Nowhere!
littletractorguy's Avatar
MTF Member # 36339
Images: 6
Garage
What you did there is pretty much what they recommend on the Seafoam can.
littletractorguy is online now   Reply With Quote Quick reply to this message
Old 08-06-2011, 03:10 PM   post #4 of 12
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
Putting Seafoam directly through the carb is fine. You can check the plugs if you're worried but unless it runs badly I'd just replace them at the regular interval.
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 03:21 PM   post #5 of 12
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
That is on D-Dogg's 318 Maintenance Check list, the only difference is I believe he suggests you let the seafoam sit in the carb for about 30 minutes before "smoking up the backyard".
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 03:59 PM   post #6 of 12
John@Reliable
Banned!
MTF Member # 37003
Quote:
just like any good detergent let it sit and do it's job.
John@Reliable is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 04:21 PM   post #7 of 12
LLigetfa
standard issue neuralyzer
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Pouring Seafoam down the throat of the carb will do nothing to clean the carb as none of it actually ends up inside the carb. You need to pour it through the fuel filter or the gas tank if you want it to have any effect on the carb.
__________________
I don't suffer from insanity. I enjoy every minute of it!
LLigetfa is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 05:18 PM   post #8 of 12
SkipD
Senior MTF Member
MTF Member # 20430
Quote:
That's quite true. What needs to be cleaned in the carburetor isn't really touched by spraying stuff down the venturi. What needs the cleaning is the small orifices and other surfaces inside the carburetor that gasoline contacts, not just where the air goes through it.
__________________
Skip Douglas - X500 (2006)
SkipD is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 06:01 PM   post #9 of 12
jimbox748
proud qwner
jimbox748's Avatar
MTF Member # 59498
you won't get to the internals on the carb BUT you will clean carbon build-up from the cylinders,valves etc.
__________________
2011 x748
60" 7-iron deck
54" snowblower
54" blade
past machines:
cuc cadet gt1554(junk)
1973 case 220 (sold)
jimbox748 is offline   Reply With Quote Quick reply to this message
Old 08-06-2011, 06:21 PM   post #10 of 12
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Quote:
All the knowledge tells me this is true, BUT using Seafoam directly into the Carb has worked wonders for me and many other guys here, that being said, I don't know how or why it works but pouring directly into the carb works, for me anyways. I also use a couple ounces in the Tank.
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 08-06-2011, 06:34 PM   post #11 of 12
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
The Seafoam down the throat step (until pretty much choking out the engine, and letting it sit) works on the carbon in the combustion chamber.
The act of pouring it down the throat may knock some grime loose from some of the passages in some instances, but it's running a tankful of gas treated with Seafoam that helps the carb.
Of course as I have discovered, Seafoam in the gas will not take pieces of rubber and grit out of the float bowl.
Taking the top of the carb off, cleaning out the bowl and blowing out the passages with Seafoam Deep Creep is what you want to do if you want the carb really clean right away.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 08-06-2011, 07:42 PM   post #12 of 12
LLigetfa
LLigetfa's Avatar
MTF Member # 15283
Images: 2
Quote:
The confusing part in the subject line is the term "carb". Pouring it down the throat of the carb cleans carbon from the cylinder and piston. Pouring it in the fuel filter or gas tank cleans gum from the carburetor.
Both are good.
__________________
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
