wiring 318 electric fuel pump - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-27-2011, 10:33 PM   post #1 of 8
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
Default wiring 318 electric fuel pump
anyone have some advice on how to wire an electric fuel pump?
i was thinking with a relay going off the oil pressure switch. that way, whenever the pressure switch closes (when there is oil pressure) the pump turns on and whenever it opens (engine loses oil pressure) it turns off.
was also thinking a relay off the hour meter, but that might not be a good idea as it could easily flood the engine if the key was left "on" for some reason.
__________________
2001 JD 345
JD 42" Hydraulic Tiller
JD 48" Front Blade
Brinly 48" Plug Aerator
Brinly 125 lb Broadcast Spreader
Craftsman 42" High Speed Sweeper
1988 JD 332
44 Loader
jakenbake is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-27-2011, 10:54 PM   post #2 of 8
Kansas John Deere
Proud Member of the 1K Club
Kansas John Deere's Avatar
MTF Member # 32517
Images: 1
Default Re: wiring 318 electric fuel pump
I am not sure if you jump from the oil sending unit will work. Usually the electric fuel pump need to have power to prime when you turn the key on.
Kansas John Deere is online now   Reply With Quote Quick reply to this message
Old 07-27-2011, 11:18 PM   post #3 of 8
John Snykus
3K Poster!!!!
John Snykus's Avatar
MTF Member # 9147
When I did my 318 I used the hour meter to power the relay. It worked fine and I only removed it after having to replace the stater and found that mice had chewed a hole in the vaccuum line to the fuel pump. It was on for over 1 year. Does draw some DC power.
__________________
Everyone should have some toys. Mine happen to be green.
John Snykus is offline   Reply With Quote Quick reply to this message
Old 07-27-2011, 11:37 PM   post #4 of 8
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
Mine is wired to the positive side of the coil.
__________________
D-Dogg is offline   Reply With Quote Quick reply to this message
Old 07-28-2011, 07:43 AM   post #5 of 8
jakenbake
Senior MTF Member
jakenbake's Avatar
MTF Member # 34769
thanks guys. agree on the priming, so maybe the hour meter is the way to go. d-dogg, is your's powered direct from the coil or is a relay used?
anyone have a wiring diagram of how these are wired in a 400?
__________________
2001 JD 345
JD 48" Front Blade
1988 JD 332
44 Loader
Old 07-28-2011, 07:46 AM   post #6 of 8
D-Dogg
The Magnificent
D-Dogg's Avatar
MTF Member # 20164
Images: 2
Garage
I use no relay, Jakenbake. My pump is tiny and not much of a draw. The PO did the conversion quite a while ago, and no troubles.
__________________
Old 07-28-2011, 07:46 AM   post #7 of 8
WNYTractorTinkerer
5000 Strong & Climbing
WNYTractorTinkerer's Avatar
MTF Member # 26264
Images: 13
Garage
Icon2 Re: wiring 318 electric fuel pump
Tap into anywire that comes on when the key is turned to RUN.. I wouldn't do the Oil switch though as already suggested.. The key is on= the pump will run.. Sound right?
__________________
Experience is something we get.... right after we needed it!!
Can You see the Real me?
WNYTractorTinkerer is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-28-2011, 08:44 AM   post #8 of 8
biker3777
Three of my friends
biker3777's Avatar
MTF Member # 33453
I tried the electric pump but did not care for it,I now use a vacuum pump from John Deere Gator 2 wheel drive,works fantastic.
__________________
Real Lawn Tractors are Green,Just can't have too many toys,and Free is not Cheap.
1965 Round Fender
332 Diesel
F525 A Fantastic Mowing machine
216 fitted with model 31 tiller
91 Honda Goldwing that I REALLY like.
Wife of 52 yrs that tolorates me
biker3777 is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
