| Register | Home | FAQ | Active Topics | Garage | MTF Gallery | Search | Today's Posts | Mark Forums Read | Store | Chat Room |
Thread Tools | Display Modes |
#1 |
MTF Junior Poster
MTF Member # 63213
In my area where farmers grow wheat, soy beans, rice, corn, milo and such, i have yet to see a tiller behind one of their tractors, and I'm wondering about the advantages / disadvantages of a disc for an individual using a compact tractor gardening 1 to 2 acres.
Please advise regarding a disc vs tiller
| Sponsored Links | |||
Advertisement | |||
#2 |
USMC
The majority of farmers use no till equipment today compared to years ago. For a 1-2 acre garden I would use whatever I had around. If you've got the plow and disc use it. If your going to need to buy one or the other I would get the largest tiller available for the size tractor you've got. slkpk
__________________
1964 JD RF110 Restored 2004 Ingersoll 318LGT @ the church doing the Lord's work ![]() 2007 JD 2305 It's too late to worry about it now!
#4 | |
MTF Member
MTF Member # 55222
Quote:
A compact tractor can only pull a small light disc. This often is the weakness of where this combination fails. Disc is too light and/or tractor is too light. A PTO powered tiller works great on a small tractor. You can really do a good job with a tiller. You can go as slow as needed to break up the soil. The only benefit to a small compact tractor disc over a tiller is lower cost. A tiller will do a better job overall.
__________________
Darrell JD2320, 200CX, 53" Bucket, 54" QH SnowBlower, iMatch, Ballast Box, LR1072, RC2048, GM3060, 647 Tiller, SS1023B |
#5 |
MTF Junior Poster
MTF Member # 63213
Wow - great explanations!
Many Thanks
#6 |
W5CPT
Another dis-advantage of a disc - you must first break up the soil with a plow before you disc it. Breaking up the ground (two or three passes) and then discing (two or three passes) actually takes longer than running a Tiller.
The main advantage of a plow and disc is $$$ . I got a Subsoiler for $169 and a disc given to me. Tillers are about $1500 or so.
__________________
Clint in West Kentucky 2010 JD2305 - 62C MMM -200CX (49") - Big Disc Harrow 4' BB (ancient) - MiddleBuster/Potato Plow - Carry All |
#7 |
Senior MTF Member
MTF Member # 55521
Ive got the nice reverse till land pride and I still run a subsoiler to break up the deep packed dirt really seems to help with drainage Ive got some weeds and crops to till in here tomorrow if the ground isnt too wet and the plan is to use the middle buster to hopefuly try and burry the weeds so they die then Ill till
| Sponsored Links | |
Advertisement |
#8 |
Machinery enthusiast
Agree, great explainations
![]() I can only add my experiences w/a plow & disc setup (somebody has to swim against the current ).My garden used to be about an acre in size and I'd turn it w/a bottom plow just before the 1st frost then work it up nice and fine w/a disc in early spring. I could really work that dirt up real fine w/this combination and do it pretty quick w/an old TE20 as the power plant. My disc was a modified single row former horse drawn model w/a 3ph adapter welded on. I'd have maybe a 1/2 day to plow and another 1/2 day to disc. A dual gang disc would have cut down on the disc'ing time quite a bit. I've down sized the garden to basicall a 30 x 50 plot which is really too small for a plow & disc so I just follow a walk behind tiller around it come early spring. A nice 3ph mounted tiller would be great but I'd have to hit the lottery or similar 1st ![]() IMHO, it's more economical to use a plow/disc on large acreage plots and a 3ph tiller on smaller. A tiller is also great for between row weed control too. Dave Dave
__________________
2004 Kubota BX23 w/60" MMM, Thumb, AM/FM/CD. http://www.mytractorforum.com/showth...highlight=BX23, 1966 Wheel Horse 856, Gear. 1966 Wheel Horse 876, HST. w/50" sicklebar mower, 36" rotary mower, snow blade, alternator/welder. http://mytractorforum.com/showthread...hlight=856,876 The USMC, providing the enemies of the USA the opportunity to die for their country since 1775. |
| Sponsored Links | |
Advertisement | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
