Trouble with John Deere 214-noisy transmission? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-09-2011, 08:10 PM   post #1 of 8
kart 14
MTF Junior Poster
MTF Member # 62899
Default Trouble with John Deere 214-noisy transmission?
I have a JD 214 lawn tractor. Has a 4 speed transmission with the variable speed control lever. On an incline, when you are pulling in 3rd or 4th gear, it mades a loud roaring sound. The sound quits when going downhill or not in a hard pull. Trying to figure if it is a bad pulley bearing or something wrong with variable speed control or in the transaxle?? Have checked the transaxle and it full of gear oil. Has anyone run into this kind of problem before or have any ideas what to check to find the problem??
Thanks.
Kart 14
kart 14 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-09-2011, 08:12 PM   post #2 of 8
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Default Re: Trouble with John Deere 214-noisy transmission?
I would check out the Vari-speed belts and all its components.
If you need easy Picture help
Be sure to Register for Your State!
__________________
SonnyT is online now   Reply With Quote Quick reply to this message
Old 07-09-2011, 08:41 PM   post #3 of 8
ggsteve
5000 Strong & Climbing
ggsteve's Avatar
MTF Member # 9436
Garage
Are you talking about a sound like a cross between a rusty hinge on a closing dumpster door and a tuba? My 214 always does that if I'm in 3rd or 4th and I advance the variator lever to full speed. I changed my gear oil but it still makes the noise.
__________________
ggsteve
08 Craftsman Professional 24hp B&S ELS 42" deck 3 bin bagger Berco 44" blower & 48" blade OTC cab
68 JD 112H 47 deck 43 blade
69 JD 110H 37A blower 50 cart
71 JD 140H3 integral hitch 54" 4-way blade 46" deck cozy cab
71 JD 140H1
72 JD 110 parts
78 JD 316K 49 blower
81 JD 317 Onan JB Sr. 46" deck 80 Cart
84 JD 214 39 deck 43 blade
86 JD 318 3pt
Toro 212-5 36" blower
74 Concord (MTD) 990
12 cu. ft. poly cart, JD front dethatcher, plug aerator, drop spreader, box blade, 10" bottom plow, sweeper
ggsteve is online now   Reply With Quote Quick reply to this message
Old 07-09-2011, 09:36 PM   post #4 of 8
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
Rear end noise is a standard feature on 214. There are some gear oils that are supposed to help - read through my 214 thread is you want to see what others posted on my problem. Link in my signature.
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Old 07-09-2011, 10:24 PM   post #5 of 8
kart 14
MTF Junior Poster
MTF Member # 62899
Thanks. I guess the variable speed controls, belts, etc. will be the easies place to start.
Old 07-09-2011, 10:37 PM   post #6 of 8
deereboy55
close enuff works for me
deereboy55's Avatar
MTF Member # 19601
Garage
My 210 whines also ,have heard several others ,that sounded the same.It;s the way they were built.. It has been discussed here before , most all the 200 series transmissions ,have a whine.
deereboy55 is online now   Reply With Quote Quick reply to this message
Old 07-09-2011, 10:39 PM   post #7 of 8
kart 14
MTF Junior Poster
MTF Member # 62899
My sound is like a 1950's old-style straight tooth geared transmission. Thanks.
Kart 14
Sponsored Links
Advertisement
Old 07-09-2011, 10:41 PM   post #8 of 8
kart 14
MTF Junior Poster
MTF Member # 62899
Thanks for the come-back. Will check on variable speed control belts, etc. to start with.
Kart 14
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
