JD 160 Kawasaki FB460V Idle problems - Need some help - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 07-03-2011, 11:50 PM   post #1 of 7
GeorgeL
MTF Junior Poster
MTF Member # 48359
Default JD 160 Kawasaki FB460V Idle problems - Need some help
Hi,
My JD 160 has been been great for a very long time. Just recently it started idling strange. If I put the throttle all the way up it wont run steady. It goes up, down, up, down. It cuts and drives but its not running smoothly.Could the carb need to be cleaned? Fuel lines? Just trying to identify what the cause of the problem is so I can look into it and fix it. Its almost like someone is pushing the throttle up and down as its running.
Thanks for any help. Sorry if it cant explain it so well.
George
GeorgeL is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-04-2011, 12:58 AM   post #2 of 7
Jgj5150
Proud Member of the 1K Club
Jgj5150's Avatar
MTF Member # 41313
Default Re: JD 160 Kawasaki FB460V Idle problems - Need some help
Sounds like a fouled carb. Warm it up and slowly pour some "seafoam" in the intake. Just a little. After that, if you still have issues take and clean the carb.
__________________
JD 455 Diesel
JD 332 Diesel.
JD 330 Diesel
JD 1964 110 RF (my baby, s/n 11300 restored)
JD 1965 110 x2 no engines.
JD 1966 110 RF non running
JD 1967 110 RF non running
JD 1968 110 SF non running
JD 111 non running.
JD 60 x2 non running
JD RX95 bought new by my dad in 1984
JD SX75 not running
JD 68 wore out
JD 1957 720LP
Jgj5150 is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 01:17 AM   post #3 of 7
littletractorguy
The Mod from... Nowhere!
littletractorguy's Avatar
MTF Member # 36339
Images: 6
Garage
Good advice from Jgj... Thing to bear in mind, also, tho, is that if your carb is fouled, it must have gotten that way from what's being fed into it.... So, some standard things to do are: changing fuel filter (if you don't remember the last time you did it, its time to do it); clean/change air filter; change out your fuel lines (if you are the original owner and you've never done this, it's probably time... the rubber in the lines does degrade over time); remove and clean your tank (this one is a good one to do at the same time as you change the fuel lines, as you'll have the deck off at that point).... Here's a thread from recently where I went through everything I did LAST summer to clean out my fuel system.... One other piece of advice would be to set your idle speed mix... The process for doing that is available in the technical manual for the FB460v, which I'd suggest downloading and keeping a copy handy...
Hope this helps!
littletractorguy is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 09:35 AM   post #4 of 7
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
One other thing that is free and that is check the vent hole in the gas tank gas cap.
Dick
__________________
GT275
GT235
JRJ is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 09:40 AM   post #5 of 7
Herd of Deeres
Certified Master Tinkerer
Herd of Deeres's Avatar
MTF Member # 32443
All the posts above as the right places to start. One more thing to inspect while you're there is the vacuum line to the fuel pump. If that's leaking it could be one of the problems but my first bet is a fouled carb, fuel filter or fuel pickup. Have you run it out of gas recently?
__________________
Current Herd:
John Deere 175, 180 & 185
1983 JD 214 Hydraulic Lift
1963 John Deere 110
Deerely DeParted:
1969 JD 110 H DeereZilla
On to Greener pastures:
1969.5 JD 110H FrankenDeere
Herd of Deeres is offline   Reply With Quote Quick reply to this message
Old 07-04-2011, 11:45 AM   post #6 of 7
rscurtis
5000 Strong & Climbing
MTF Member # 25367
Remove the air filter assembly, and look for the idle jet- not the idle adjustment screw with the T-handle, the jet. It will be a brass screw with a hole in it. Remove it and clean the small hole in the bottom of the jet. That should get you going. When you re-install the air filter base, make sure the breather hose is connected properly.
rscurtis is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 07-07-2011, 05:05 PM   post #7 of 7
GeorgeL
MTF Junior Poster
MTF Member # 48359
thank you very much everyone. Going to try these suggestions tonight, had a unexpected plumbing problem the past 2 days. Never a dull moment. I'm glad I fix everything myself. FUN FUN FUN and never a dull moment. Always learning something new.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
