Transaxle fluid change - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-21-2011, 02:41 AM   post #1 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
Default Transaxle fluid change
I just recently learned that my transaxle has a drain/fill plug, so I decided that after 12 years it was time for a fluid change. I snapped a few pics, in case anyone wanted to see how it went.
To change the gear oil, you have to drop the transaxle out.
The drain/fill hole is located on top of the tranny next to the gear selector. Here is a pic of the hole with the plug out: (the tranny is wet because I tried cleaning some of the grime off)
The drain plug was a little stubborn to get out. Here is a pic of it:
Basically, you just have to turn it upside down to drain the oil. The old oil was pretty dark, as you can see here on my finger:
The manual calls for 16 ounces of 80w90, so that's what I put back:
I noticed that it was pretty nasty around the brake too. Here is the before pic:
It was getting late tonight, so I will have to finish the job in the next couple of days. I'll snap a few more pics as I go, if you guys are interested.
leftyclick is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-21-2011, 02:56 AM   post #2 of 15
rustyrideon68
CalifornianGravelynator
rustyrideon68's Avatar
MTF Member # 17701
Images: 15
Garage
Default Re: Transaxle fluid change
good job
__________________
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
My name is Mike and I own these tractors, a...
68 Gravely 430 (40" Comm mower)
80 Gravely 8163-T (L.S.D trans)
(Mighty Mac Shredder)
67 Gravely 424 (40" kidney mower)
66 Gravely C8, with Governor and soon elec start. Rotary Plow, Rotary cultivator, and 30" deck x2
48 Gravely model L ,G.R.Hs with rotary plow
?? Gravely 5660 30" finish mower
72 Gravely 814, cig lighter parts machine(NFS)
72 Simplicity Landlord 3410 H with MM grading blade.
7? Allis Chalmers 314 D with Electric lift 3pt, tiller and 42" MM mower
74 Wheel horse D-160, 3pt, rear scraper blade. in sad shape.
79 (MTD) Dayton 11hp but looks great, "Survivor" ,and a 72 (Gilson)Wards 16 hydro w 48" MM mower
78 John Deere 214, 38" mower + brass tag snow plow ( I dont really need the snow plow). project. will get Onan 18hp. when its repaired
79 Sears LT 10/36 MMM.... also have a 70s HAHN LTD 500 RER, Electric conversion, when I have $
78 Sears GT/19.9 Six Spd with a Loader, dually, WW, MMM, Waren elec 3pt, dump tote box, disc harrow, Front mount shredder, rear scraper blade, Onan N52M-GA. low hours machine
81 Sears GTV Custom. Will get Wisconsin 18.5 hp THD. may have a Turbo. Or a 27hp Kohler needs a bore and .10 oversize pistons ....Nothing runs like a deere running from my GRAVELYS.................................. THE
87 Pontiac Fiero GT V6 3spd...69 Dodge A-108 Sportsman ,318 ,3spd man. McCulloch 10 (MAC 10) 2 vintage backpack blowers, 1953 Briggs and Stratton 6S , a B&S 1950 5S too with Firestone plug. GO BUCKS! OHIO State U
rustyrideon68 is offline   Reply With Quote Quick reply to this message
Old 06-21-2011, 06:41 AM   post #3 of 15
BushBoneYard
5000 Strong & Climbing
BushBoneYard's Avatar
MTF Member # 31379
Images: 12
Garage
Quote:
For sure!.
BushBoneYard is offline   Reply With Quote Quick reply to this message
Old 06-21-2011, 11:39 AM   post #4 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
I'm a bit concerned about the brake assembly being so oily, but I can't really take the time to pull the entire transaxle apart right now. I did go ahead and clean it up really well, so now I'm going to just try to keep an eye on it and make sure it's not leaking a bunch. Here's a pic of what the brake assembly looks like now:
Old 06-21-2011, 11:41 AM   post #5 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
Oh, and by the way, this transaxle is a Peerless MST-206-502C.
Old 06-21-2011, 01:06 PM   post #6 of 15
FrankMA
Proud Member of the 1K Club
FrankMA's Avatar
Location: Merrimack Valley in Northeastern Massachusetts
MTF Member # 10550
You should notice quite a difference in the performance once you start to use it again. I did mine recently and it's much smoother and quietier than it was before I changed the fluid and filter.
__________________
2002 Toro Wheel Horse 522xi
Honda HS928TA Snowblower
Honda HS621AS Snowthrower
Honda HS520A Snowthrower
Honda HS624WA Snowblower (Sold 8/23/2010)
Honda EM6500SX Generator
Stihl BR550 Backpack Blower
McCulloch MS1635 Chainsaw
Weedeater SST25 Line Trimmer
"It is what it is!"
FrankMA is offline   Reply With Quote Quick reply to this message
Old 06-21-2011, 06:54 PM   post #7 of 15
hankll
Old Iron......Forever
MTF Member # 35652
Ok, I didn't want to do this but what is that out of? I hate asking dumb questions.....I always thought that most of the Peerless transaxles were using that Bentonite grease in them. The AutoDrive trans is, I thought, a combo of Bentonite grease for the gears and fluid for the Hydro part of it.......but I never claimed to be an expert on the trans part...fact is, I've only played with one, and it was the hydro on an Ultra, needing a change of fluid. I used Pennzoil gear lube on it, a 75/90 full synthetic, that had the viscosity of regular motor oil, which I was told was what it used OEM.
hankll is online now   Reply With Quote Quick reply to this message
Old 06-22-2011, 02:14 AM   post #8 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
Hankll: This transaxle is out of my '99 Murray 20hp 46". It's the one pictured in my sig. I too thought that all of them were just packed with grease, until I found a Peerless maintenance manual.
FrankMA: I hope so! If it doesn't make a huge difference, I'll still be happy just knowing it's running smoother.
Old 06-22-2011, 06:38 PM   post #9 of 15
BushBoneYard
MTF Member # 31379
Images: 12
Garage
leftyclick
Do you know the model # of your tractor? 46500x92A?
Old 06-23-2011, 11:25 AM   post #10 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
Quote:
Originally Posted by BushBoneYard View Post
leftyclick
That is it! I was just a kid when I bought it, but the reason I bought this model was because it had grease fittings in places some of the other mowers didn't. I just didn't know the transaxle was serviceable too.
Looking back, another reason I chose this model was because I didn't like the plastic noses on the GT's. I really like this LT, don't get me wrong, but I kick myself now for not getting the GT!
Old 06-23-2011, 12:16 PM   post #11 of 15
BushBoneYard
MTF Member # 31379
Images: 12
Garage
Cool, we have the same tractor.
Old 06-27-2011, 12:45 PM   post #12 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
Well, I finally made time to get it all back together, but I didn't get any more pics. I thought I might share some tips for those who may want to try this though.
First off, there are 5 bolts holding it in. Two on each side where the axle shafts are, and one up by the shifter that mounts it to the frame (and is a real pain to get to.)
You also have to remove the spring for the brakes. If you pull the pin out to remove the spring, (where it attaches to the pedal assembly,) put the pin back to hold it all together. Otherwise it's a pain to line everything back up.
You might want to remove the drive belt idler pulley to get some slack on the belt.
When lowering the transaxle, be sure it is in neutral or reverse to make sure the shift lever clears the frame. Also make sure it clears the frame and idler pulley bracket when reinstalling it.
When you put the transaxle back into place, make sure the belt is back on the pulley and clears the guide rods on each side of the pulley.
That's all I can think of for now. These are all things that I had trouble with, so maybe my experience will help others!
Old 06-27-2011, 12:58 PM   post #13 of 15
FrankMA
FrankMA's Avatar
MTF Member # 10550
Have you noticed any difference in the performance? Does it sound quieter and feel smoother? Just curious.
__________________
"It is what it is!"
Old 06-30-2011, 12:27 PM   post #14 of 15
leftyclick
Senior MTF Member
leftyclick's Avatar
MTF Member # 44995
I just got to really use it yesterday evening when I mowed my yard. I actually can't tell any difference except that it may shift a little easier. It does make me feel better that it does have new oil in it though.
Sponsored Links
Advertisement
Old 10-08-2011, 07:11 PM   post #15 of 15
andyinmichigan
MTF Member
MTF Member # 45246
just dug this up looking for info on bentonite grease that the manuals call for.....mines a peerless model 930 if it makes any difference...
edit: so i'm too lazy to look the op's part number that which looks very similar to mine, is a little different.
so to replace the grease, do you have to open it up and all that? the search continues...
andyinmichigan is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
