Bolens 1256 hydrostatic questions - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Register Home FAQ Garage MTF Gallery Search Today's Posts Mark Forums Read Store Chat Room [1]
Reply
Thread Tools Display Modes
Old 06-19-2011, 08:53 AM   post #1 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
Default Bolens 1256 hydrostatic questions
Brought home a 1256 -07 Bolens Husky yesterday and I adjusted the carb and the Wisconsin engine started right up. I had the option between a 6 speed and the hydrostatic but I chose the hydrostatic cause I would be mowing, snowblowing, and tilling with it. Was it a bad idea to go with the hydrostatic? Are they good and durable transmissions?
My other questions is, is that it doesn't have much power going slow. It will slowly move along then when it hits resistance it stops and makes noise like something is slipping. The belts and drive shaft are not slipping from what I can see. Is this normal? Are there seals that wear out and can be repaired? or do I have to fork over another pile of money for a replacement transmission?
__________________
Tucker
One '53 Economy King in a constant state of improvement(Avatar)
One 1256 Bolens Husky with a mower, and 3ft tiller and a 1253 with 2, 3ft snow blowers.
1995 F150 XL 4.9 liter 5 speed
Looknlearn is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-19-2011, 01:16 PM   post #2 of 25
JustinR
Proud Member of the 1K Club
JustinR's Avatar
MTF Member # 10838
Default Re: Bolens 1256 hydrostatic questions
You made a good choice. Have you checked the hydro fluid in the tank under the seat pan? There is a cap right in front of the seat. Make sure also that you have the throttle wide open. The hydro system has full charge at full throttle. Lastly, make sure and change the hydro filter.
__________________
Original Bolens 1250 - Restored Bolens HT-18 - Rebuilt 1886 to 1386 Diesel Loader w/ Powersteering Restored FMC Bean Cutler - Project 1477 - Troy Bilt GTX 20
http://huskylargeframes.blogspot.com/
http://www.youtube.com/user/jtube76?feature=guide
JustinR is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 09:01 PM   post #3 of 25
Cam-Shaft
Cam-Shaft's Avatar
MTF Member # 54891
Ditto
__________________
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
Bolens HT-23S power steering, Cruise control, Transmission cooler.
Bolens HT-20 w/ARK 500 FEL and 3pt hitch (apart for repairs)
Bolens 1050 pulling tractor (Wisconsin TJD)
Bolens 800, rebuilt engine.
Cam-Shaft is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 09:02 PM   post #4 of 25
jason4567
jason4567's Avatar
MTF Member # 30557
Garage
Those hydro's are bulletproof. The 1256 uses an eaton model 10. As long as the fluid level is maintained and you don't overheat it, it will last forever.
Be sure and clean the fins on the hydro unit (where the driveshaft goes). They get caked with dirt and oil and this can lead to overheating. Also make sure that you still have a driveshaft fan.
Jason
__________________
Bolens
Tube Frame: 600, 800 (2), 900 (2) 1000, 1050 (4), 1225, 1254 (2), 1256, G14, H14
Large Frame: 1250 (5), 2086
Others
Bolens RAM, Bolens FS-11, Copar Panzer, Sears SS12, Sears Custom 6, Gravely LI, L8, L, Comm.10a, Farmall Cub
jason4567 is offline   Reply With Quote Quick reply to this message
Old 06-19-2011, 10:32 PM   post #5 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
Thanks for the replies. Hydro fluid looked good. I didn't have the throttle all the way up cause it was late and that thing is LOUD. I can try to get pictures tomorrow but I am leaving for a few weeks starting tomorrow. My brother may be on my account here to ask a few questions cause he is gonna be working in it. I wish I am gonna be tinkering on it as well. The hydro still has the cooling fan and the fins don't look clogged up.
I managed to get the hydro filter off by jamming a screwdriver through it cause nothing else would work. I think I'll slowly turn the hydro to flush the old fluid out while the filter is off. The fluid didn't look bad but I'd thought I'd do it anyway. What filter do I use as a replacement? Will any filter work?
Is there are place to get replacement brake pads?
Can't wait to get this thing running. I sure like the thought of hydraulics. I am having second thoughts about leaving the tractor other behind.
Hopefully I'll get you guys some pictures before I leave.
__________________
Tucker
Old 06-20-2011, 10:23 AM   post #6 of 25
elsimon
elsimon's Avatar
MTF Member # 6548
NAPA has a filter that will work.
Don't let your brother have all the fun. Great little machine that will give you lots of hard work.
__________________
GT_80 Fan Club Member #0003
Everything drives me crazy...it's a short drive.
Bolens 1256
Front plow, tiller w/ extn.
Sears '77 18/6 Twin "The Ghost" (she just appeared)
Sears '72 SS15 "Smurfette" (PO painted Smurf Blue) - Need: air cleaner cover
42" Deck(2), Front Plow(3), Seeder, Sickle Bar, 3pt Hitch(2), Moldboard(2), FEL, 220# Wgt Box, 130# 3pt Wgt Attach, 50# Wheel Weights (4), 2 Link Chains(2 sets), 3pt Tiller (converted from WB).
elsimon is online now   Reply With Quote Quick reply to this message
Old 06-20-2011, 11:34 AM   post #7 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
OK
It doesn't look like I'll have time to get you'all some pictures before I leave but I told my bother to make sure to get some for you guys. He will probably be on here for advice from time to time. Thank you for the advise so far.
EDIT. The departure was put off till tomorrow so I'll get you'all some pics.
Tucker
__________________
Tucker
Old 06-20-2011, 03:01 PM   post #8 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
Here are the pictures.
__________________
Tucker
Old 06-20-2011, 03:04 PM   post #9 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
Some more.
__________________
Tucker
Old 06-20-2011, 03:07 PM   post #10 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
And more.
Only rear problem the tractor seems to have other than very worn steering spindles.
Any tricks for the loose and worn steering spindles? The one wheel turns about 6 inches before the other one moves.
The snowblower chute I have. Just need it reattached.
__________________
Tucker
Old 06-20-2011, 03:11 PM   post #11 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
Last few.
I do have the attachment parts for the tiller but not the lift rod to the hydraulics.
__________________
Tucker
Old 06-22-2011, 02:01 PM   post #12 of 25
ed-nh
Bolens 1886-01
ed-nh's Avatar
MTF Member # 29037
Those pictures look great. The tractor overall looks to be in really nice condition. See just where the play is on the spindles. Sometimes it is just a worn spring pin. Mine was very sloppy and I replaced the pin that goes through and it tightened it up pretty good for only a buck. I am working on an eaton10 right now. I'll post some pictures of the internals for your viewing pleasure. They are certainly well built.
__________________
CLICK HERE
Restored:
853, 1556, 1556 Loader, custom 1856, 1669, 1886, HT23
Restored:
tillers, 3pt, sleeve hitch, E-Z Vac, mowers, single & 2 stage blowers, moldboard, front and rear pto chippers/shredders, wheelbarrow attachment, aerator
ed-nh is offline   Reply With Quote Quick reply to this message
Old 06-22-2011, 02:18 PM   post #13 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
It is definitely the steering spindle that is worn the hole through the spindle is rather oval shaped. I compared the diameter of the spindle bolt to the one in the parts diagram it appears that the PO already drilled it out bigger. It looks like i'll have to buy some replacements.
__________________
Tucker
Old 06-22-2011, 03:13 PM   post #14 of 25
ratboy
Senior MTF Member
ratboy's Avatar
MTF Member # 48289
Is that a crack in the pto just below the top bolt hole? or a shadow?
Steering spindle being worn out is a testiment to that particular tractor's reliability. The 1256 is considered by most to be the best tube frame Bolens built. That one has obviously had some hours put on it. Not to worry, it looks like it has plenty left to give. Keep your ear to the ground, someone in your neck of the woods will see you on it and start talking about others they have seen or own that are parts tractors. Keep an eye out for any H-14's or h-16's. They have techumseh engines on them and the engine usually wears out long before the tractor ( I'm going to catch some grief for that statement from the tech owners, sorry). They front ends on the tube frames were all the same. If you can't wait that long, put an inch of weld on the spindle where it meets up with steering arm. Make it easy to undo, should you ever need to take it apart.
ratboy is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-22-2011, 09:05 PM   post #15 of 25
Looknlearn
Tractor enthusiast
Looknlearn's Avatar
MTF Member # 57558
Images: 9
Garage
[QUOTE=ratboy;1763922]Is that a crack in the pto just below the top bolt hole? or a shadow?
Yes that is a crack. I haven't had time to really think about it because my full attention has currently been on the hydro.
I drained the fluid in the hydro, which BTW takes forever, and changed the filter.
When I tried to refill it, it would only take 1 quart. I have heard that it should need about 4 quarts. I read in the manual that there could be an air pocket so I tried what they recommended: running the tractor on idle while pumping the travel pedal back and forth. Is the tractor supposed to move while doing this? Mine didn't. I only tried this for a short time for fear of ruining the transmission.
Do you have to do this for awhile before the fluid level will go down?
Is there a better methods for getting air pockets out?
Emailed sambolens asking about steering spindles. He responded today saying he has them for $65 each which seems like allot to me. Maybe i'm just to stingy. Not sure what I will do. Since someone already drilled the spindles bigger then if I replace them I will need to also replace the piece that the tie rod attaches to.
__________________
Tucker
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
