Sleeper trailer-6 - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Trailers We have to pull our machines once in a while...
Reply
Thread Tools Display Modes
Old 06-17-2011, 07:38 PM   #1
jdcrawler
Lindeman crawler fan
jdcrawler's Avatar
MTF Member # 10122
Default Sleeper trailer-6
The roof is done so it's time to finish the sides.
The wood in the upper right front corner was rotted out from where the roof leaked.
The rotted wood is stripped out.
Luckily the ends of the 2x2 cross braces are still good.
I made up a new curved upper corner piece and put in a new 2x2 in the corner.
The openings for the two windows on the right side are framed up.
Dry fitting the windows on this side to make sure everything is OK.
The overall height of the camper is about three inches taller that it was so there is a gap above the rear panel.
This is filled in with strips of wood.
A piece of 1/2 inch plywood is extended straight back from the angled part of the roof to strengthen this area.
There are sections of 2x2 that angle down from the roof to the back wall.
The inside paneling will attach to these so the roof area will angle straight down to the back wall.
This gap between the paneling and the roof will be used to run the wiring from one side to the other over the door.
The window opening on the left side is framed up.
There is a piece of 3/4 inch plywood in the framing above the window area.
This is so I can mount the interior light and have room for the wiring to run to it behind the plywood support.
Making sure the window on the left side fits the opening.
The left side of the overhang had this small window in it.
I haven't decided if I'm going to put it back in or not yet.
The angled 2x4 brace for the overhang runs right thru the area where this window use to be.
__________________
Ray
1945 John Deere Lindeman ( modified )
1949 Agricat crawler
1946 FMC Bean Cutler ( flat belt drive )
1948 Bolens Ridemaster - 35AA01 Ser#230
1948 Bolens Ridemaster - 35AA01 Ser#457
1948 Bolens Ridemaster - 35AB01
1953 Bolens Ridemaster 35AB03 ( modified cart )
1937 Shaw Du-All tractor conversion
"R/T" home made tractor
http://www.youtube.com/watch?v=-1aD1wn7yNE
jdcrawler is online now   Reply With Quote
Sponsored Links
Advertisement
Old 06-17-2011, 08:07 PM   #2
tiretrx
Tractor Color Blind
tiretrx's Avatar
MTF Member # 13571
Images: 8
Default Re: Sleeper trailer-6
Good progress, Ray
__________________
.....just call me Ellis
You only need two tools in life - WD40 and duct tape. If it doesn't move and should, use the WD40. If it shouldn't move and does, use the duct tape.
tiretrx is online now   Reply With Quote
Old 06-17-2011, 10:41 PM   #3
John@Reliable
Banned!
MTF Member # 37003
Thumbs up Re: Sleeper trailer-6
Looking good, as far as window? I would try to use it if possible, can be a big difference on a hot night, or even on a so/so night
John@Reliable is offline   Reply With Quote
Old 06-17-2011, 10:41 PM   #4
Oo-v-oO
3K Poster!!!!
Oo-v-oO's Avatar
MTF Member # 32338
Garage
Send a message via Skype™ to Oo-v-oO
It would probably be nice but not absolutely necessary to have some cross ventilation in the sleeping area.
__________________
-Lee, KB1GNI
"Felix qui potuit rerum cognoscere causas"
[Happiness is understanding how things work]
Oo-v-oO is offline   Reply With Quote
Old 06-17-2011, 11:59 PM   #5
hamman
HAMMAN
hamman's Avatar
MTF Member # 46389
Garage
I know that I was glad I had some cross ventilation in the bed area of our old cabover camper we had. I agreee put it in if possible. Like the progress. Thanks for the update.
hamman is online now   Reply With Quote
Old 06-18-2011, 06:35 AM   #6
Ingersoll444
ex spelling bee champ
Ingersoll444's Avatar
MTF Member # 16
Images: 14
Send a message via AIM to Ingersoll444 Send a message via MSN to Ingersoll444
Id bag the little window.. Ya, cross flow is nice, but in its new shortend size, you have that big one just off side there in the main part of the camper/sleeper. That angle support is a much needed structureal support piece for that front part, and wile you could replace it with more bracing, whats there now is simple, light, and sound... I would think you have enough windows allready in such a small aera.
__________________
Paul B
Visit The Case Ingersoll Colt Forum.
SUPER Of The Month 10/2011
Ingersoll444 is online now   Reply With Quote
Old 06-18-2011, 01:06 PM   #7
jdcrawler
jdcrawler's Avatar
MTF Member # 10122
Talked it over with my wife last night and decided to go ahead and put in the small window in the overhang.
I had taken out the original window frame with it still altogether so all I had to do was trim it off and mount it.
The window sits higher and more forward to clear the angle brace.
__________________
Ray
Old 06-18-2011, 01:16 PM   #8
dmorrill22
broke college kid
dmorrill22's Avatar
MTF Member # 38986
Images: 26
Garage
Good compromise! Looks like it will work well there.
Doug
__________________
Doug
1966 Colt 2712
- Slow restoration underway - progress to be made this summer
- Sleeve hitch
1969 Sears SS12
- Homemade snow plow (in progress)
- GM 3-wire alternator
- Duromax 16hp Repower
- Custom headlights & LED Amber strobe lights (rear)
- 155lb PC Counterweight
- 2" Receiver Hitch Adapter
- Also making concrete wheel weights
- 2 Link chains
dmorrill22 is offline   Reply With Quote
Old 06-18-2011, 08:00 PM   #9
Oo-v-oO
3K Poster!!!!
Oo-v-oO's Avatar
MTF Member # 32338
Garage
Yup, nothing wrong with that.
__________________
-Lee, KB1GNI
Old 06-18-2011, 08:51 PM   #10
hamman
HAMMAN
hamman's Avatar
MTF Member # 46389
Garage
I replaced all the old steel screws in our 1965 Fan trailer with Stainless Steel ones that I got at Mid States Bolt and Screw. Made the trailer look better and they didn't rust. JM2CW. Looks good!
Sponsored Links
Advertisement
Old 06-18-2011, 09:59 PM   #11
BOSOX
Booo
BOSOX's Avatar
MTF Member # 5420
Images: 14
Coming along nicely Ray!!
__________________
Mike
BOSOX is offline   Reply With Quote
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
