Let me see pics of your Suburban 3 point hitch actuators - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 06-15-2011, 05:34 PM   post #1 of 9
lawnman0515
Senior MTF Member
MTF Member # 5692
Default Let me see pics of your Suburban 3 point hitch actuators
I'm getting tired of hand lifting the 3 point hitch up all the time. I"m not sure where to start with a parts supplier or fabrication ideas. Something heavy duty with a lot of downforce is my requirement.
lawnman0515 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-15-2011, 05:47 PM   post #2 of 9
Small Fry
5000 Strong & Climbing
Small Fry's Avatar
MTF Member # 8155
Default Re: Let me see pics of your Suburban 3 point hitch actuators
The Sears does not have down force. It's not really needed with the attachments sears made. I'm not sure how that would work with these light tractors.
__________________
Small Fry is offline   Reply With Quote Quick reply to this message
Old 06-15-2011, 06:54 PM   post #3 of 9
Hugh-SS/16
Onan Lover
Hugh-SS/16's Avatar
MTF Member # 31282
Images: 15
Garage
no downforce. just handy for heavier attachments like rototillers and earthcavators
__________________
GT_80 Fan Club Member: #0001
Need Tires?Click Here!
Tractors: '68 Custom 8XL, '73 SS/16, '73 SS/16, '78 GT/18H, '78 GT/19.9
Attachments: Kwik-Way Loader, 48" Haban Sickle Bar, 42" Mid-Mount Grader, 42" 3pt Grader, 46" Snow Blade, 42" Mower, 4000w PTO Generator, 3pt 10" Moldboard, 3pt Cultivator, 42" Haban Snowblower, 46" Dozer Blade
John Deere, Mahindra CUT, Gravely, Stihl
Ellington Agway Power Equipment
74 West Rd (Rt 83)
Ellington, CT
860-875-0690
The above opinions are solely mine and do not reflect that of my employer
Hugh-SS/16 is online now   Reply With Quote Quick reply to this message
Old 06-15-2011, 08:15 PM   post #4 of 9
swatara_gap
Senior MTF Member
MTF Member # 183626
Youíve piqued my curiosity as well, so the Sears model has no downward force? How can that be possible? Well, Iím guessing through electrical limiters etc, but how does it know how deep to spool out? Whatís it do? Does it just unwind until the bail/attachment is all the way down? A photo of the controller would probably be worth a thousand words.
How much can the Sears linear actuator pick up? Iím guessing that itís at least 250 lbs, but would it go as high as 500?
I guess that itís pretty easy to take the manual one on and off, or at least thatís how it looks in the photos that Iíve seen of it, but I wouldnít like driving about with the lever hanging out there like a hook on an old railroad mail carÖ
swatara_gap is offline   Reply With Quote Quick reply to this message
Old 06-15-2011, 09:16 PM   post #5 of 9
mdigby
Senior MTF Member
mdigby's Avatar
MTF Member # 47545
Images: 5
This road has been traveled before. Search IS YOUR FRIEND...
Here are a couple of threads that MAY be helpful
http://www.mytractorforum.com/showthread.php?t=191278
http://www.mytractorforum.com/showthread.php?t=162212
http://www.mytractorforum.com/showthread.php?t=108484
http://www.mytractorforum.com/showthread.php?t=88833
http://www.mytractorforum.com/showthread.php?t=105154
The actuator on the FACTORY electric hitch has no downforce (other then gravity) because of the way the linkage works. The actuator is set up to PUSH the lift arms up, but IS NOT DIRECTLY CONNECTED to the lift arms.
You could connect it for a hitch that you built, or modified, but I think it was done this way to PROTECT the actuator form damage. It is an expensive part to replace (current cost $400 plus!!!)
BUT your original request was for pictures.
I will attempt to post pictures later, BUT right now photo bucket is "down for maintenance"
Sorry
mdigby is offline   Reply With Quote Quick reply to this message
Old 06-15-2011, 09:25 PM   post #6 of 9
stripmine
Member: Special K Club
stripmine's Avatar
MTF Member # 26454
Images: 5
Garage
It's difficult to explain the set up, but the lifting actuator isn't solidly pinned to the lifting mechanism. it will lift an attachment, but when it's lowered to the ground.. will not apply down pressure.. the attachment just floats under it's own weight.
these small tractors don't have enough weight to apply down pressure.. once the attachment hits the ground, applying more pressure would be actually lifting the rear of the tractor. all you would be doing would be cheating yourself of tracton. Most implements are designed to dig in, in the way they are made.. and don't require down force.
what would you be using.. that would require down pressure?
dave
ADDED
Maybe this will help.
stripmine is offline   Reply With Quote Quick reply to this message
Old 06-15-2011, 10:09 PM   post #7 of 9
mdigby
Senior MTF Member
mdigby's Avatar
MTF Member # 47545
Images: 5
This first picture IS NOT MINE. I posted it in an earlier thread
This is the best one I can get (right now) of the one I have on my hitch
The GT-18 carb is out of town getting worked on.
Old 06-16-2011, 12:40 AM   post #8 of 9
swatara_gap
Senior MTF Member
MTF Member # 183626
Thank you! That's answered all my questions. I hope it helped the topic starter as well. The photo was worth a thousand words, but I did understand the technical bit without photos as well...
Thanks again,
bolillo
Sponsored Links
Advertisement
Old 06-16-2011, 08:03 AM   post #9 of 9
swatara_gap
Senior MTF Member
MTF Member # 183626
I understand why the above two sleeve hitches only lift and don't provide any downward pressure. I am more familiar with the type in the photo below. Itís obvious that this linear actuator is direct push pull at all times.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
