B&S keeps breaking flywheel key?????? - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Small Engines and Repair
Midwest Mower Pro
Reply
Thread Tools Display Modes
Old 06-11-2011, 01:40 AM   post #1 of 7
danriis
MTF Junior Poster
MTF Member # 58856
Default B&S keeps breaking flywheel key??????
Hi all,
I have a Craftsman riding mower with a 16.5 horse Briggs and Stratton 31H777-0202-E1 030215za engine on it.
It broke a rod which we have replaced, everyting else looks good.
Problem is, now it keeps breaking the flywheel key. We thought maybe it was the valves but they have been adjusted and the key still breaks.
What could this be? The torque on the flywheel nut? How tight should it be? Or is there something else that could likely cause this?
Thanks in advance,
Dan
danriis is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-11-2011, 07:37 AM   post #2 of 7
DLF_IN
2000 Posts and climbing!!!
MTF Member # 1844
Default Re: B&S keeps breaking flywheel key??????
Flywheel Nut torque spec is 100 ft/lbs. Make sure the crank and the flywheel taper are clean and dry.
Dave
DLF_IN is offline   Reply With Quote Quick reply to this message
Old 06-11-2011, 08:33 AM   post #3 of 7
k91
5000 Strong & Climbing
MTF Member # 19618
They shear pretty fast if they are not torqued down enough
k91 is offline   Reply With Quote Quick reply to this message
Old 06-11-2011, 09:47 AM   post #4 of 7
Walt 2002
Senior MTF Poster
MTF Member # 1229
Quote:
Dave
Many people make the mistake of thinking that the key is supposed to hold the flywheel from moving on the crankshaft. It is ONLY for positioning the flywheel on the crankshaft, the proper torque on the taper is what holds the flywheel.
Walt Conner
Walt 2002 is offline   Reply With Quote Quick reply to this message
Old 06-11-2011, 07:46 PM   post #5 of 7
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
If the nut torque is correct, you might want to lap the crank and flywheel together to make sure they are making good contact.
__________________
Remember, I'm pullin' for ya! We're all in this together!
(Red Green)
Living in The Land Of The Free - because of The Brave!
Fcubman is offline   Reply With Quote Quick reply to this message
Old 06-12-2011, 03:32 AM   post #6 of 7
danriis
MTF Junior Poster
MTF Member # 58856
Default Now it will only run full throttle?
Thanks all, we tightened the flywheel and now it's not breaking the key, HOWEVER, for some odd reason it only will run at close to full throttle.
My friend and shade tree mechanic is working on it but is stumped.
According to him all the linkages to the throttle, governor etc etc look good.
What gives?
Thanks again!
Sponsored Links
Advertisement
Old 06-12-2011, 11:44 AM   post #7 of 7
Fcubman
3K Poster!!!!
Fcubman's Avatar
MTF Member # 18953
Images: 5
Have you tried running it with the choke partially closed? If it runs better, it's running lean. Try closing the choke varying amounts, see what happens.
__________________
(Red Green)
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
