54" blade angle problem - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-31-2011, 07:49 PM   post #1 of 5
ccmdvl
MTF Member
ccmdvl's Avatar
MTF Member # 57339
Question 54" blade angle problem
I had some dirt to move over the weekend and decided to use the 54" blade for the 425. If the load I was trying to push was off to one side (not in center) the blade would angle in that direction unless I kept adjusting the angle. I did not see any leaks. There was not a problem with raising/lowering.
If it makes any difference, when the mower deck is attached, it lowers if the machine is sitting for more than a few minutes (engine off). Not sure if this is normal, since I just picked up this machine over the winter.
Any suggestions?
Thanks you!
ccmdvl is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-31-2011, 08:10 PM   post #2 of 5
Deereman76
Senior MTF Member
Deereman76's Avatar
MTF Member # 41263
Garage
Default Re: 54" blade angle problem
There should be a lockout valve directly under the SCV's (where the hydro lines hook up). That should be turned all the way in which will fix that problem, but the lockout must be fully open to let the mower deck arms move freely (for mowing).
Deereman
__________________
Owner of:
X485 AWS John Deere
X465 AWS John Deere
R70 John Deere
54C mower deck (2)
Deere 47" Quick Hitch Snowblower
Deere 54" Quick Hitch Blade
52" harrow
17P cart
48" thatcher
Tow behind spreader
Deereman76 is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 08:18 PM   post #3 of 5
Mike X485
The Welcome Wagon Mod
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Quote:
Deereman
What Deereman76 said.
__________________
JOHN DEERE X748
Mike X485 is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 08:21 PM   post #4 of 5
PA318Guy
Winter returned!
PA318Guy's Avatar
MTF Member # 31960
Garage
The mower deck should slowly lower when the engine isn't running but it takes mine a day or two to drop all the way. The lockout valve is what you need though to hold the blade on an angle!
__________________
Current Machine JD 322
Former Machines: JD 318, JD 216, JD 212, 1965 JD 110
My videos: www.youtube.com/user/tkelley16341
PA318Guy is online now   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-31-2011, 08:49 PM   post #5 of 5
ccmdvl
MTF Member
ccmdvl's Avatar
MTF Member # 57339
Very good, thank you. I will take a look when I get back to camp this weekend!
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
