NH 1725 clutch replacement - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-31-2011, 07:52 AM   post #1 of 5
Larch
MTF Junior Poster
MTF Member # 29212
Default NH 1725 clutch replacement
Has anyone ever replaced the clutch on a 1725. I am having a bit of trouble with mine. I got it all back together and it seems like I have to use all the adjustment just to get any pedal. It dosn't seem right. Any help would be appreciated. Thanks
Larch is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 06-01-2011, 01:57 PM   post #2 of 5
buba
MTF MEMBER
buba's Avatar
MTF Member # 35637
Images: 2
Garage
Default Re: NH 1725 clutch replacement
sounds like ya might have the clutch disk in backwards that is usually what happens when it is
__________________
you can never have too many antiques but finding the time and money to restore them that is a problem
buba is offline   Reply With Quote Quick reply to this message
Old 06-01-2011, 04:31 PM   post #3 of 5
Larch
MTF Junior Poster
MTF Member # 29212
Thanks, I'll try flipin it.
Old 06-01-2011, 06:12 PM   post #4 of 5
Larch
MTF Junior Poster
MTF Member # 29212
I tried flippin the disc and no difference. Any other suggestions?
Sponsored Links
Advertisement
Old 06-15-2011, 11:08 PM   post #5 of 5
Tractortech
MTF Member
MTF Member # 44940
The pressure plate is probably mis-adjusted from the factory. You would have to split again, put your old pressure plate on with new disc. Measure the finger height. Remove and install new pressure plate with new disc. Measure finger height and you will probably find that the finger (or adjusting bolt) height is lower. Adjust up to old pressure plate adjustment height and you will probably be fine.
Clutch manufacturer will say that this should have been checked before installing. Most people don't because the plate should be pre-adjusted.
Tractortech is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
