John Deere 5425 PTO question - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-26-2011, 05:40 PM   #1
kf54830
MTF Junior Poster
MTF Member # 60866
Default John Deere 5425 PTO question
I have a John Deere 2008 model 5425 cab tractor that I just bought. I noticed when hooking to my Vermeer 5410 baler the PTO shaft does not turn by hand to allow me to line the splines up and slide the drive train of the baler onto the PTO shaft. Every other tractor we have allows the PTO shaft to turn by hand. Dealer says this is just how the tractor is made, but same makes no sense to me. Anybody else have this issue or know of this issue? Thanks.
kf54830 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-26-2011, 05:43 PM   #2
SonnyT
Hoosier Born & Raised!
SonnyT's Avatar
MTF Member # 21893
Images: 26
Garage
Default Re: John Deere 5425 PTO question
Sorry I don't know. I thought they all turned?
If you need easy Picture help
Be sure to Register for Your State!
__________________
SonnyT is offline   Reply With Quote
Old 05-26-2011, 06:11 PM   #3
scm
Senior MTF Member
MTF Member # 38403
Turn the engine off and see if it turns freely. I haven't had that problem with my 5203 but the New Holland 3930 i used to have if the engine was running it wouldn't turn by hand.
__________________
2007 John Deere 5203 2009 John Deere X500 48'' deck 2010 John Deere X300 42'' deck And too many attachments to list
scm is offline   Reply With Quote
Old 05-27-2011, 08:30 AM   #4
MF283
Proud Member of the 1K Club
MF283's Avatar
MTF Member # 33230
hmm, all these years, i've just turned the shaft on the implement because i always apply a lil grease to the PTO shaft & didn't want to get grease on my hands
Ronnie
MF283 is offline   Reply With Quote
Old 05-28-2011, 04:47 AM   #5
Tx Jim
Senior MTF Member
MTF Member # 53811
Images: 1
Quote:
Originally Posted by kf54830 View Post
I noticed when hooking to my Vermeer 5410 baler the PTO shaft does not turn by hand to allow me to line the splines up and slide the drive train of the baler onto the PTO shaft. Thanks.
Most ind pto tractors have a brake on the pto.If one shuts tractor off(safest way to hook/unhook an implement pto) then normally brake will release because of lack of hyd pressure.
My JD 467 rd baler has a coupler on the pto shaft that allows one to rotate pto about 10 degrees to align splines
Tx Jim is offline   Reply With Quote
Old 05-30-2011, 10:01 PM   #6
kf54830
MTF Junior Poster
MTF Member # 60866
My 5410 baler drive train will not turn so that compounds the issue. Our other tractor is a Case IH CX90 and th PTO shaft turns on it with engine off. The John Deere tractor even when off will not turn by hand. Frustrating.
Old 05-31-2011, 08:35 AM   #7
Tx Jim
Senior MTF Member
MTF Member # 53811
Images: 1
Have you ever tried turning 5425 pto shaft with the "engine off" with the aid of a pair of slip-joint pliers?
Sponsored Links
Advertisement
Old 05-31-2011, 08:02 PM   #8
kf54830
MTF Junior Poster
MTF Member # 60866
Quote:
No not yet but I will try that next, but I am baling too much right now. We have a dry week in TN so we are cutting a lot. Once that is done and I disconnect the baler I'll try that. Thanks.
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
