Sediment bowl/fuel shut off leaking - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-18-2011, 09:03 PM   post #1 of 10
Ironman03R
MTF Member
MTF Member # 6616
Default Sediment bowl/fuel shut off leaking
My sediment bowl is leaking from the shut off valve. Is there a seal inside it that I can replace or do I just need to get a new one?
__________________
Kubota B3200
Ironman03R is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-18-2011, 09:21 PM   post #2 of 10
JohnW
3K Poster!!!!
JohnW's Avatar
MTF Member # 1445
Images: 3
Garage
Default Re: Sediment bowl/fuel shut off leaking
If it is like most all of them there is a small nut that can be snugged up at the base of the stem. Just a little will do ya.
JohnW is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 10:46 AM   post #3 of 10
Steve (Magnolia, TX)
Retired - Veteran Mod
Steve (Magnolia, TX)'s Avatar
MTF Member # 251
Images: 13
Garage
Yes... you can most likely (hopefully?) just snug up the nut on the bail, at the bottom of the bowl. However... there IS a 'gasket' in there. Most common is a cork gasket, but... I have seen (or at least heard of) a neoprene O-ring being used, as well...
Steve (Magnolia, TX) is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 09:07 PM   post #4 of 10
Ironman03R
MTF Member
MTF Member # 6616
No its not the bowl that leaks, sorry for the confusion. I have a new gasket and screen in that part but the problem is the shut off is leaking right out of where the valve that the knob is on goes into it. I was gonna take the knob off and try to unscrew the valve out to see if there was anything in there to be replaced but I figured I'd ask here first.
__________________
Kubota B3200
Old 05-19-2011, 09:27 PM   post #5 of 10
souNdguy
Proud Member of the 1K Club
souNdguy's Avatar
MTF Member # 94
as was said there is a packing nut that can be snugged around the stem SOMETIMES
souNdguy is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 11:53 PM   post #6 of 10
slip knot
Senior MTF Member
MTF Member # 35095
I have some faucet packing( looks like graphite coated string) I've had pretty good luck stopping leaking shut offs with it. I dont know if you can still get it or not but it may be worth checking out a local hardware store. I've had mine for years.
slip knot is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 07:29 AM   post #7 of 10
Ken N Tx
Retired MTF Admin
Ken N Tx's Avatar
MTF Member # 117
Images: 60
Garage
Mine leaks only when turned all the way out..So I don't turn it all the way out!!
__________________
Ken N Tx is offline   Reply With Quote Quick reply to this message
Old 05-20-2011, 11:06 AM   post #8 of 10
souNdguy
souNdguy's Avatar
MTF Member # 94
a buena N oring back there can help if you don't find the packing string.
btdt
soudguy
Old 05-21-2011, 09:56 AM   post #9 of 10
Ironman03R
MTF Member
MTF Member # 6616
I picked up a new one last night since the in tank screen is missing anyway. Once I get the old one off I'll take it apart and see what I can do to fix it up for a spare.
__________________
Kubota B3200
Sponsored Links
Advertisement
Old 05-21-2011, 07:49 PM   post #10 of 10
souNdguy
souNdguy's Avatar
MTF Member # 94
you can really fix it up by soldering on a new screen to it.
many places sell brass or bronze strainer screen. that and some flux and solder.. or heck.. jb weld and you are good to go.
I've saved up old strainer taps till I get about 6 of them and do them all at once with a new oring and new screen I make / sodler up..e tc.
soundguy
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
