Help! Problem Starting Cub 154 Lo-Boy (LowBoy sp?) - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-18-2011, 06:38 PM   post #1 of 4
bigbluefan85
MTF Junior Poster
MTF Member # 59807
Default Help! Problem Starting Cub 154 Lo-Boy (LowBoy sp?)
Hey guys, any advice would be appreciated.
I have a 154 Lo Boy and when I go to start it the flywheel will turn but the engine will not turn over. A mechanic I know told me its the timing belt but apparently there is no timing belt on the low boys but instead its all gears.
Any suggestions?
bigbluefan85 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-18-2011, 06:50 PM   post #2 of 4
284 International
Senior MTF Member
MTF Member # 57073
Default Re: Help! Problem Starting Cub 154 Lo-Boy (LowBoy sp?)
What do you mean it won't turn over? If the flywheel is spinning but the crankshaft isn't turning there are some sheared bolts on the flywheel. If you mean the crankshaft is spinning but the engine isn't firing then there is a series of diagnostic steps that could isolate where the trouble is.
Check to verify spark at all plugs. Pull them one at a time, ground to something and crank the engine. You should have strong sparks on all cylinders. If not, work back and isolate.
If you have good spark, and it's been sitting, you have a fuel issue. Try a quick spray of ether. If it fires a bit, then you need to check/change your fuel, the filter, and lines. A carburetor cleaning may be in order.
284 International is offline   Reply With Quote Quick reply to this message
Old 05-19-2011, 05:32 PM   post #3 of 4
bigbluefan85
MTF Junior Poster
MTF Member # 59807
284 International,
Thank you for the advice. I am going to attempt to do what you said later this afternoon and to clarify my original post the crankshaft IS spinning but the engine is not turning over. We checked the distributor and it is not turning.
Thanks in advance for any more advice.
Sponsored Links
Advertisement
Old 05-20-2011, 01:15 PM   post #4 of 4
284 International
Senior MTF Member
MTF Member # 57073
If the distributor isn't spinning that is your problem. Others may chime in, but I would just pull the distributor. I don't know about those specifically, but there might be a roll pin that has broken on the distributor gear, or a drive from the oil pump or something.
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
