x300 can't get off the fly wheel cover, help! - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 05-08-2011, 06:55 PM   post #1 of 4
jsaw14
Senior MTF Member
MTF Member # 46042
Default x300 can't get off the fly wheel cover, help!
Was going to get the x300 out for the first time this year to cut the grass. I opened up the hood and noticed that there is a lot of what looks like a mouse nest in the flywheel... I tried to unscrew the 3 hex screws with out any luck. I felt that I would strip the screws if I applied too much pressure. I put some PB Blaster on the screws as well and they did not budge.
Is that a special tool for this or some trick I don't know about to get them off?
Also I am guessing that it would be a dumb idea to start the tractor with this debris in it correct?
Thanks!
jsaw14 is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-09-2011, 05:37 PM   post #2 of 4
pawber
Senior MTF Member
pawber's Avatar
MTF Member # 33692
Default Re: x300 can't get off the fly wheel cover, help!
The fan housing & screen bolts are listed as 52 in lbs.
Uh, you are not trying to tighten them are you. Hey,just thought I'd ask.
__________________
Paul B
09 JD X300/42X deck
02 JD 724D snowblower
had a JD 214 - 11 years
had a Bolens QT16 - 7 years (talk about a whiney transaxle)
had 2 Bolens 1050's - 21 years & 3 years
pawber is offline   Reply With Quote Quick reply to this message
Old 05-09-2011, 05:51 PM   post #3 of 4
JRJ
The owners manual
JRJ's Avatar
MTF Member # 28174
Remembr those screws/bolts turn counterclock wise to remove. You could get yourself a good chisel (not to big) and a small hammer and try tapping the screw/bolt out. If you haven't ever done it, you place the chisel blade on the screw/bolt head slanted so it would force the screw/bolt in a counterclock wise direction and then start tapping on the chisel end lightly. If I remember correctly you had put some PB Blasters on it yesterday, should be ready to come off now.
No special tool need, just a socket or nut driver.
Dick
__________________
GT275
GT235
JRJ is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-09-2011, 09:21 PM   post #4 of 4
Sidponcho
Senior MTF Member
Sidponcho's Avatar
MTF Member # 38878
had a nest in mine last Spring.....just put on some cool sunglasses, and fire it up!!!
Sidponcho is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
