Ford 600 Tractor - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-30-2011, 04:35 PM   post #1 of 10
cjfinn
MTF Junior Poster
MTF Member # 59170
Help Ford 600 Tractor
We have a 600 Ford tractor and my husband would like to know if anyone can tell him how you check to see if your hydraulic oil is correct and how much hydraulic oil it takes.
We know there are three reservoirs and they go from one to the other. Also if you are sitting on the seat on the left hand side is what appears to be a dipstick, is this where you check and if so where should it be?
My name is Lynne and I am in Ontario, Canada.
cjfinn is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-30-2011, 05:05 PM   post #2 of 10
tiretrx
MTF ADMINISTRATOR
tiretrx's Avatar
MTF Member # 13571
Images: 8
Default Re: Ford 600 Tractor
Hi Lynne, welcome to MTF. Plenty of knowledgeable Ford folks here. I'm sure help will be on the way before too long Good luck with your 600.
__________________
.....just call me Ellis
tiretrx is online now   Reply With Quote Quick reply to this message
Old 04-30-2011, 06:10 PM   post #3 of 10
souNdguy
Proud Member of the 1K Club
souNdguy's Avatar
MTF Member # 94
the sumps are seperate and in fact DO NOT go from one to the other.
trans, fill by shifter, drain underneath.. level check is a PLUG on the right side just above the running board, near your right foot.. but on trans.. not on center setion. don't remove any bolts fromthe side of the trans.. just that plug.
hyds, fill under left front of seat under left thigh.. drain underneath.. hyd dipstick on left side by pto shifter.
diffy fill behid seat, right side aft of your right but cheek kinda..
drain underneath diffy.. is a plug.. other two are large bungs.
level check is a plug on the back of the left axle trumpet mid way up.. near the flange where the trumpet bolts to the center housing.
gear oil in the trans and diffy, utf in the hyds.. or utf in all 3. utf meeting m2c134d ford spec reccomended. trans type will change the amount of oil.. but if going utf in all.. get a 5g pail.. otherwise, a 2g pail of utf, and 4g of gear oil.
soundguy
souNdguy is offline   Reply With Quote Quick reply to this message
Old 04-30-2011, 07:51 PM   post #4 of 10
cjfinn
MTF Junior Poster
MTF Member # 59170
Thanks Soundguy. Have printed out for my husband to check out tomorrow.
Lynne
Old 04-30-2011, 11:04 PM   post #5 of 10
Mike X485
The Welcome Wagon Mod
Mike X485's Avatar
MTF Member # 47023
Images: 7
Garage
Lynne, Welcome to the forum.
__________________
JOHN DEERE X748
Mike X485 is online now   Reply With Quote Quick reply to this message
Old 05-01-2011, 03:46 PM   post #6 of 10
kdmoser
MTF Junior Poster
kdmoser's Avatar
MTF Member # 33145
Hi Lynne, Welcome aboard. Always great to have another 600 series owner posting.
BTW, UTF is Universal Transmission Fluid. Available at Tractor Supply, Walmart and many auto stores.
__________________
Kurt-NEPA
kdmoser is offline   Reply With Quote Quick reply to this message
Old 05-01-2011, 03:59 PM   post #7 of 10
cjfinn
MTF Junior Poster
MTF Member # 59170
Just a short note to say thank you. Your advise helped greatly. He has it figured out now.
Again thanks.
Lynne
Old 05-03-2011, 09:46 PM   post #8 of 10
souNdguy
souNdguy's Avatar
MTF Member # 94
post back if you got any more questions.
I love the 00/01 series.. the 55-64 fords are my favorite
soundguy
Old 05-04-2011, 08:40 AM   post #9 of 10
Paul J
Senior MTF Member
Paul J's Avatar
MTF Member # 19817
Images: 1
The Ford 600 tractors, along with some other models have a seal between the front, (transmission) and rear (hydraulic) sections of the housing. Unless the unit has been rebuilt within the past couple of years and that seal replaced, the chance of cross over contamination is possible. I'd drain all the oil out of both and refresh with hydraulic oil in both compartments. The worn seal will allow the trans oil to pass through and contaminate the hydraulic fluid. The proper hyd. fluid in both compartments will eliminate that situation and with the modern formulas, the transmission will be properly lubricated. Unless you replace that seal yourself, a lot of work, a shops fee will be very expensive due to work and time involved. JMHO. PJ
__________________
REMEMBER & NEVER FORGET
We all live in the land of the free
BECAUSE OF THE BRAVE!
Paul J is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 05-04-2011, 11:36 AM   post #10 of 10
souNdguy
souNdguy's Avatar
MTF Member # 94
that seal is between the hyd section and the diffy.. not the trans and the hyd.
soundguy
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
