54" Rear Blade Broke - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-29-2011, 11:52 PM   post #1 of 26
silver hair deere
Old as Sin
silver hair deere's Avatar
MTF Member # 4257
Images: 4
Default 54" Rear Blade Broke
Setting on my sears gt grading the large ruts from last storm , happy as a clam , then i hear a pop , so what to do , ideas needed !!
Name:	Picture 006 (Large).jpg
ID:	155386   Click image for larger version
Name:	Picture 007 (Large).jpg
ID:	155387   Click image for larger version
Name:	Picture 011 (Large).jpg
ID:	155388   Click image for larger version
Name:	Picture 012 (Large).jpg
__________________
Silver Hair Deere
1989 Sears GT
1989 GMC 1500 , NEEDS BALL JOINTS (FIXED)
1996 MTD 695 , REBUILDER (MOSTLEY DONE)
1995 CHEVY LUMINA NEEDS OUTSIDE ROD ENDS
DONE
1998 FORD RANGER RADATIOR NEEDS CHANGED
DONE
When one breaks down , i just drive another .
silver hair deere is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-30-2011, 01:12 AM   post #2 of 26
hamman
HAMMAN
hamman's Avatar
MTF Member # 46389
Garage
Default Re: 54" Rear Blade Broke
From what it looks like to me, you need to gusset along each weld when you weld it back together. You might think about adding another arm weld on each side also. Didn't look like a good penetration on the original weld. Just my thoughts.
hamman is offline   Reply With Quote Quick reply to this message
Old 04-30-2011, 09:09 AM   post #3 of 26
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
Thank you hamman ,your the only one to post a reply , will update with pictures .
__________________
Silver Hair Deere
1989 Sears GT
DONE
DONE
Old 04-30-2011, 09:45 AM   post #4 of 26
hamman
HAMMAN
hamman's Avatar
MTF Member # 46389
Garage
Take your time and get a good penetrating weld when you repair. If I have gleaned anything from the guys and gals here is take your time and do it right. It should be better than new when you get done.
Old 04-30-2011, 10:32 AM   post #5 of 26
DLF_IN
2000 Posts and climbing!!!
MTF Member # 1844
I agree with hamman. It looks as if there was a minimum penetration of the original welds. Clean well,take your time and consider adding a gusset at the top and bottom of the arms.
Dave
DLF_IN is offline   Reply With Quote Quick reply to this message
Old 04-30-2011, 11:19 AM   post #6 of 26
fabforce1
Senior MTF Member
fabforce1's Avatar
MTF Member # 18454
Thats the exact spot that mine broke, except yours broke nice and straight.
Mine got all bent up and i really have nothing to straighten it up. I have a vice and a big hammer...lol...i got it pretty straight but needs to be redone. I was in a hurry cus i needed to use it right away so i did the best i could to straighten it and re welded it and it did the job for the winter but with summer jobs coming it will need to be done better.
fabforce1 is offline   Reply With Quote Quick reply to this message
Old 04-30-2011, 11:41 PM   post #7 of 26
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
I only have a HH 135 , did the best on welds , still have to add the gussets , how do the welds look ? i did bevel the piece i welded on , also if it's not good tell me how to improve it .
Name:	Picture 005 (Large).jpg
ID:	155551   Click image for larger version
__________________
Silver Hair Deere
1989 Sears GT
DONE
DONE
Old 05-01-2011, 12:24 AM   post #8 of 26
mla2ofus
Old Stonebreaker
MTF Member # 138
The weld looks cold. If you have an O/A or propane torch, I'd preheat it real good before welding. Might want to grind that out and reweld w/ preheat. It's difficult to weld metal that thick w/ 135 amps. Just crank 'er up all the way, you don't have to worry about burnthru w/ this weld.
I'm sure you plan to, but weld both sides of the joint.
HTH,
Mike
mla2ofus is offline   Reply With Quote Quick reply to this message
Old 05-01-2011, 09:34 AM   post #9 of 26
farmtechdave
life is good
farmtechdave's Avatar
MTF Member # 46284
Images: 2
I agree the weld does look a bit cold. Also it looks as there is only one pass. I'd of ground it down and done 3 passes with preheat, a good root pass then a couple finish welds to strengthen it up.
__________________
Dave
It's gotta be Morel season soon......
farmtechdave is offline   Reply With Quote Quick reply to this message
Old 05-01-2011, 10:27 AM   post #10 of 26
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
Is it to late to pre heat and add extra weld or do i need to saw apart and start over ?
__________________
Silver Hair Deere
1989 Sears GT
DONE
DONE
Old 05-01-2011, 12:14 PM   post #11 of 26
mla2ofus
Old Stonebreaker
MTF Member # 138
I'd get rid of the weld and start over w/ the preheat.
JMHO,
Mike
Old 05-01-2011, 06:19 PM   post #12 of 26
hamman
HAMMAN
hamman's Avatar
MTF Member # 46389
Garage
I agree on oreheat. My HH140 needs a little help once in a while when I get on thicher stuff. Once I get my new garage wired this spring I will be able to use my stick welder for thicker stuff. Look like you did a good job so far.Don't foget to back weld the joints. It woun't take long to get it done.
Old 05-02-2011, 04:30 PM   post #13 of 26
oldasrocks
MTF Member
MTF Member # 59168
Bevel it in and weld with 308-15 stainless, 1/8 " . You'll never get enough pen with a wire feed.
oldasrocks is offline   Reply With Quote Quick reply to this message
Old 05-02-2011, 07:14 PM   post #14 of 26
oldasrocks
MTF Member
MTF Member # 59168
Expanding on my answer above.
Looking at the color of the metal both farther back and at the weld itself I'm going to assume it a poor grade of metal to start with. I've ran into this with some of my own equipt. The cheap rototiller I bought had to be cheap imported-read chinese- steel. Low grades shatter like cast iron does and does not weld well with standard techniques. thats why you were advised properly to preheat. But also use the stainless rod when aheres better. You could use FN-86 at $40 or so a pound but thats expensive and hard to find.
Sponsored Links
Advertisement
Old 05-03-2011, 09:57 AM   post #15 of 26
silver hair deere
Old as Sin
MTF Member # 4257
Images: 4
All i have is a HH135 mig welder . And no extra money in may . What can i do .
__________________
Silver Hair Deere
1989 Sears GT
DONE
DONE
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
