425 - Silicone sealant for rear K92 trans-axle cover / rear PTO. - MyTractorForum.com - The Friendliest Tractor Forum and Best Place for Tractor Information
Reply
Thread Tools Display Modes
Old 04-28-2011, 05:57 PM   post #1 of 11
Dunkelstar
Deere Guru
Dunkelstar's Avatar
MTF Member # 52637
Images: 38
Default 425 - Silicone sealant for rear K92 trans-axle cover / rear PTO.
Hey Guys,
I have a used rear PTO for my 425 on the way, and was wondering what silicone sealant would be best to use to form a proper seal to the K92 trans-axle? One that also has longevity, once and done.
Some type of RTV Silicone Gasket Sealant; red, black, gray, copper, or blue?
Any recommendations? Thanks in advance!
__________________
1996 John Deere 455 AWS
1996 John Deere 425 - w/ upgraded tire size, rear PTO, and 3PT Hitch
#40 Loader, 54 and 48" MMM Deck, 46" Snow-Thrower, 54" Front Blade, Agri-Fab 3PT Core Aerator, Agri-Fab Chip-n-Vac, and #80 Cart
Dunkelstar is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Old 04-28-2011, 06:50 PM   post #2 of 11
antiqueetc
Proud Member of the 1K Club
MTF Member # 4758
Default Re: 425 - Silicone sealant for rear K92 trans-axle cover / rear PTO.
I'm partial to the black silicones, but my favorite is Hylomar. Kind of hard to find and a little expensive but excellent sealer.
antiqueetc is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 07:34 PM   post #3 of 11
bvp2000
Senior MTF Member
bvp2000's Avatar
MTF Member # 28946
ditto on the black....but dont use to much! I never put enough sealant on to squash out, cause if it squashes out where you can see it, then it probably squashed out internally as well!
__________________
bvp2000
JD 455/40 Loader
JD 425 and JD 7 Cart
JD's not hidden from the wife well enough!
JD 425, JD 425AWS, JD 322, JD 318, JD 317, JD 425
JD G100, JD 318, JD 445, JD 445, JD 265, JD 455, JD 332, JD 455, JD 430, JD 318, JD 777, JD 425, JD X495, JD345 and JD 755.
bvp2000 is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 10:29 PM   post #4 of 11
Engine_Tech
MTF Member # 46741
Black...and use a thin bead around the PTO ports or you will plug things up if it oozes out.
Engine_Tech is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 11:50 PM   post #5 of 11
Maverick74
Senior MTF Member
Maverick74's Avatar
MTF Member # 35894
Black or Gray. Use gray on auto differential covers.
__________________
Previous:
2008 JD X728
1998 Cub Cadet 2185 48" MMM 42" Snow Plow...RIP
Current:
2012 John Deere X748SE
3pt hitch, Rear PTO, 7 Iron, 54 Snow Plow, 647 Tiller,
45 Loader, Kwik Forks, iMatch, Heavy Hitch, Cyclone Rake Z-10,
Box Blade BB2048L, and Rear Blade RB2060L
Maverick74 is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 12:21 AM   post #6 of 11
DeereRider
Senior MTF Member
DeereRider's Avatar
MTF Member # 55538
I like the red high temp RTV which is what I used on my K46. Autozone sells a product called "The Right Stuff" I think Permatex makes it, its an RTV in an aerosal can so you don't have to squeeze the tube. This stuff works really well sealing anything! I 've used it on automotive transmission pans and oil pans in place of cork gaskets and it never leaks.
__________________
2012 X500, 48" Edge Deck, 44" Snow Blower, 48" Plow Blade, De-thatcher, 42" Lawn Sweeper, 4 John Deere Suitcase weights, wheel weights, chains and HDAP's
2007 X300 with 245 hours, 42" deck SOLD
30" Mechanical Tiller SOLD
DeereRider is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 12:36 AM   post #7 of 11
rfowler
Senior MTF Member
rfowler's Avatar
MTF Member # 46333
Images: 1
Garage
[QUOTE "The Right Stuff" Permatex makes it, its an RTV in an aerosal can QUOTE]
__________________
2010 X728
Mulch kit
Rear Quick hitch
Rear weight bracket
10P cart
rfowler is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 10:24 AM   post #8 of 11
Nouveau Redneck
3K Poster!!!!
Nouveau Redneck's Avatar
MTF Member # 19566
Images: 1
Silicone and hydraulics don't mix well. If you're going to use silicone be very very careful that none of it ends up in any spots where it can come into contact with the hydraulic fluid once everything is back together.
Why not buy a new gasket from JD and not worry about any kind of sealant? Did the original installation instructions say to use a sealant?
__________________
Nouveau Redneck
Sean in PA
1973 Ford 4000 3-cyl gas w/S-O-S & 60 inch Woods rotary mower
2008 John Deere X500
2010 John Deere X304
2014 Kubota BX25D w/50" snow blower
You know you might be a Nouveau Redneck if...
1. You use the cup holder on your tractor to hold your cosmopolitan instead of a beer
2. Your "Santa on a tractor" Christmas yard decoration is actually a high tech digital hologram.
3. Your deer camp cuisine is better than most 3 star restaurants.
Nouveau Redneck is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 10:30 AM   post #9 of 11
antiqueetc
MTF Member # 4758
Just a note about the 'too much' caution. I keep a box of cheap latex/plastic gloves in the shop. When applying sealer I don a glove and use it to wipe a THIN coat on the gasket both sides. Much easier to get a consistently thin coat that way. And, lots easier to clean my hands!
Old 04-29-2011, 10:49 AM   post #10 of 11
Dunkelstar
Deere Guru
Dunkelstar's Avatar
MTF Member # 52637
Images: 38
Thank guys. I picked up a tube of Permatex ultra black RTV for autozone. It should do the trick. I hear you guys in regards to using a small amount. Just enough for form a seal. When the parts come in I'll get a better idea of how much to use.
Nouveau Redneck: There actually is no gasket for the rear PTO/plate. It's sealed with RTV from the factory. The JD part number is TY24344 (Clear RTV, 3 oz. tube).
__________________
Sponsored Links
Advertisement
Old 04-29-2011, 10:15 PM   post #11 of 11
Tomadvanced
Senior MTF Member
Tomadvanced's Avatar
MTF Member # 52537
In general, I like grey Permatex silicone. On engine case halves, cam boxes, manual transmissions with no gaskets (with two machined mating surfaces)I use Loctite 574. Hylomar with paper or cork gaskets. Rubber gaskets dry with grey silicone on inside corners.
__________________
2011 X729, Heated Soft Side Cab, 47" Snow Blower, 54C Mower Deck, MC519 with Power Flow, 45 Loader, 26 Gallon Sprayer, JD 48" Aerator, Spyker 12v Spreader
Tomadvanced is offline   Reply With Quote Quick reply to this message
Sponsored Links
Advertisement
Reply
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
